Question about Pool & Spa
Pump keeps turning on automatically every couple of minutes for 10 beats.Found no leaks. debris in one way valve? how to fix?
  • kris mcquade
    kris mcquade Apr 26, 2015
    grundfos CH2 pump
  • 1,631 Answers
What do you have?
Make & Model?
Posted on Apr 28, 2015
Water pump gives a brief burst of "on" every 10 minutes or so even when taps not activated
It could be leaky check valve . The check valve keeps water from run back into the tank. It may be stuck partway open or dirt or scale may be keeping the valve from shutting tight . Hope this helps.
Dec 26, 2013 | Flojet Quad Series Water System Pump...
Landa pressure washer LT 4035-4000 psi. Why is it losing pressure and continually pulsating?
If the pump is pulsating rapidly most likely valves are leaking or debris under valve keeping one or more from closing. If the pump pulsates slowly, comes up to pressure then low pressure then repeats, problem is pressure regulator /bypass. Or you could have a combination of both. Try lowering the pressure to lowest setting to see if slow pulsation stops. As parts age within pump and debris hinder operation you can no longer operate at full pressure. To make the pump last, use highest pressure as needed and everyday work using only 60 to 75 percent of capacity.
Mar 19, 2013 | Garden
There was a leak i undid the mottor and repaired it but some oil spilled out, now there is no leak but little pressure and mottor does not stop
A "chattering" pressure washer pump can be caused by many things. You could have a bent or damaged inlet line, or the water supply might be too low. Fixing these is simple, but checking on the water supply is critical. Never let the water supply run low for any extended period of time. Other causes of a chattering pump include water that is too hot, you may have air in the pump system or a stuck float valve. A power washer pump that is vibrating, but not chattering could be the result of air in the system or debris stuck in the valves. Catching these pressure washer problems early and knowing what causes them will save you a trip to the repair shop, especially when it comes to the low-water issue.
Troubleshooting Low Nozzle Pressure
Low nozzle pressure is a common complaint generally caused by one of the following:
1. Plugged nozzle tip.
2. Inlet screen plugged.
3. Insufficient flow in gallons per minute (not pressure) to the pump.
4. Unloader valve stuck open due to debris lodged under the check valve ball.
5. Customer use of shutoff-type quick connectors.
6. Plugged hose.
Troubleshooting Pressure Washer Soap Injector
When a soap injector is not working properly, the problem is generally fairly easy to isolate. Check the following:
1. If you have interchangeable tips, make sure the Black, soap tip is installed. Soap injectors will not work when high pressure nozzles are installed.
2. Be sure that the soap injector valve is turned on, and turn selector valve to desired setting.
3. A piece of debris may be caught in the injector valve, injector ball valve, or orifice. Disassemble and clean the injector.
4. If you have an adjustable nozzle, be sure it is in the low pressure position(away from the gun) to draw soap.
Thanks
Apr 01, 2012 | Garden
My Legend cleaner (8 yrs. old) starts off fine but after a few minutes runs very slowly. any ideas what may be causing this?
First check the metal screen inside the fitting that connects to the pool wall. Make sure it is clean. If there is no inline screen on the feed hose then the jets inside the pool cleaner could be clogging. If there is a screen that keeps getting clogged with debris(like every couple days) then there is a problem with your pool filter or multiport valve that is allowing dirt to pass into the pool cleaner and the pool. Also it could be the back-up valve hanging up(due to a bad bearing or bushing) The back-up valve is the large canister on the feed hose about 3-6 feet above the cleaner. Check for holes in the feed hose and in the cleaner tail.
May 31, 2010 | Pentair White/Gray Legend Platinum...
Hard to start after it sits u have to keep cranking for at least 30 t0 45 sec
When you turn on the key the fuel pump relay causes the pump to run for one second to bring the fuel manifold presure up. If the vehicle has 'sat' for a long time, this one second is not long enough and so the engine is struggling to get enough fuel to fire. Try turning the key on and off every couple of seconds for about a minute, then turn the key to the start position. The engine should now start. Do not touch any controls such as the throttle, the computer will take care of all this.
Mar 17, 2010 | 2001 GMC Jimmy
Silvia leaking water
Hi
The solenoid valve needs back flushing the correct way with a espresso machine detergent like Cafiza, or Joe Glo. Place a 1/2 teaspoon in a blind basket. (don't come with Silvia). Place blind basket in portafilter and brew like making espresso, but run pump for no more than 5 to 10 seconds or until the pump starts to change tone (slow down). Stop the pump when either of these things happen or Silvia can be damaged. Repeat the pump 5 to 10 times leaving a 1 minute wait between cycles, or the suds comming out the 3 way valve turns pure white, with no coffee stains in the foam. Remove the portafilter and rinse then reinsert and repeat the cycles to rinse the internals. This should take care of the problem. If not you may have to replace the 3 way.
Nov 12, 2009 | Rancilio Silvia Espresso Machine
Pool cover pump quit working without warning. was not in deep water. pump is clean, no cracks or compromised wire. air vent hole not plugged. tried in a couple different outlets (power source) then put in...
take the cover off of the automatic shut off and check for debris. Most cover pumps have an auto shutoff and most of them have the type of valve that can be inoperable due to debris getting into the valve.
Oct 07, 2009 | Pool & Spa
Works for about 15 minutes and then stops. pressure is very strong, no debris to be found anywhere
Sounds like a bad flow valve K70181. It is probably cracked and works only when you help it start. The valve has a lifetime warranty. Check with a local pool store for warranty.
Aug 28, 2009 | Pentair Kreepy Krauly Inground Automatic...
Automatic water dispenser not working/bypass valve leaking alot
Dear Rodeo mary,
Before you do anything else, please first defrost the fridge. Yes, turn it off and leave it open for a couple of hours until all the ice in all compartments has melted. Clean it and put it on again. Is it ok ? Please let me know.
arturocruz.
abwakhweya@yahoo.com
Jun 02, 2009 | KitchenAid KBRP20ERSS Stainless Steel...
NEFF S5456 DISHWASHER
Have you tried it on a different program? I have nearly always used the AUTO program - however i have used the 50 degree program 3 times now and it completes the (much longer) wash without sticking on one minute. Will try it on auto again to see what happens. I found it useful to turn the end-of-wash buzzer on (to loud) to remind me when (if) it completes the program.
Sep 30, 2007 | Neff 24 in. S5456 Built-in Dishwasher
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
