Question about Kata T2 - 8" IPS ANDROID 4.1.1 TABLET
In reseting the unit
How many minutes it takes in pressing the volume before the reset menu will appear?
How do I reset my Lenovo tablet
You did not say which tablet you have. For Ideatab Android tablet, start with battery fully charged and tablet OFF. Press and hold Volume Up and Power at the same time until menu appears on screen. To navigate the menu, use Volume Down to move through the menu choices, Volume Up to select the current menu choice (like an Enter key) and Power button to return to previous menu. On the "Factory Menu", move down to "Clear eMMC" and select that option. You should see a message that data is being cleared. This may take several minutes to complete. Wait for it. When it completes, the tablet should be reset to the way it came from the factory so you will have to set up again user ids, wifi passwords, download apps, etc.
Dec 23, 2014 | Lenovo Tablets & eReaders
My zeki stuck on the zeki logo
You need to do a factory reset!
  1. Make sure your tablet has a full charge
  2. Press and hold the Volume - button and tap the Reset button
    (The reset button is located between the HDMI and USB ports)
  3. Continue holding the Volume - button until the boot screen appears
  4. Release the Volume - button
  5. Use the volume controls to navigate to "Wipe data/Factory reset"
  6. Press the power button to select
  7. Navigate to "Delete all user data"
  8. Press the power button to select
Your tablet will take several minutes to reboot to a factory default setting.
Oct 19, 2014 | Tablets & eReaders
How do I do a factory reset on my certified mid-73005 tablet
  1. Press and hold Power button to turn off your tablet.
  2. Press and hold Volume Up and Power buttons at the same time for about 10 seconds.
  3. Once see the menu, select wipe data / Factory reset. (Use Volume keys to scroll up/down. Use Power button to select)
  4. It will take about 2-3 minutes to reset.
  5. Then your tablet will boot in.
  6. Set up and use as normal.
Sep 29, 2014 | Tablets & eReaders
I put a password on my android tablet and now i dont remember the password
Make sure you backup your files by connecting it to a PC (if you have access to one) via USB cable,you will have to do a hard reset, otherwise there is no other way to get past the lockscreen (unless you have a recovery option with your email address)
Below is the process to tell you how you can hard reset your Samsung tablet (should work with any tablet):
  • Ensure that the Samsung tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Powerbutton in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
  • Once your device is hard reset and rebooted successfully, you will see that the unlock pattern obstruction is also gone, and you can now set a new unlock pattern on your Samsung tablet.
Oct 21, 2013 | Tablets & eReaders
How to unlock my coby
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Aug 18, 2012 | Coby Kyros 716829701508 Tablet PC
My Coby Kyros MIDI 1125 tablet is passworded.how can I bypass that to reset it?
Step 1- Power the unit off. Press and hold the "Power Button" image002.jpg till the "Device Option menu image003.jpgappears.
Step 2- Click on "Power Off image004.jpg and select "OK" image005.jpg.
Step 3- Once the unit has been turned off. Press and hold the "reset" image006.jpgbutton and "power" image008.jpg button simultaneously for eight seconds.
Step 4- The following screen image009.jpg will appear. Press the "reset" image006.jpgbutton.
Step 5- The Android system recovery screen image010.jpg will appear.
Step 6- The "Home and Menu" image011.jpg button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". image012.jpg . Press the "reset" image006.jpgbutton.
Step 8- The following screen will appear. image013.jpg.
Step 9- Press the Menu" image014.jpg button to select "Yes- delete all user data".
Step 10- Press the "reset" image006.jpgbutton.
Step 11- The following screen will appear image015.jpg.
Step 12- Press the "reset" image006.jpgbutton to reboot/restart the unit.
Aug 18, 2012 | Coby kyros Tablets & eReaders
Wont start up the screen only displays the android logo i've tried pressing the reset button many times but still the same
Try a master reset:
  • Turn off the unit.
  • Plug the unit into an electrical outlet.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Oct 08, 2011 | Coby Kyros 7" Touchscreen Tablet
How can i reset my coby tablet
Aug 20, 2011 | Coby Kyros 716829701508 Tablet PC
I have a coby Kyros and I forgot the password and can't get in. how can I take the password off?
*******This procedure will delete all items (file's) and entries on the MID7015******
Aug 18, 2011 | Coby Kyros 716829701508 Tablet PC
My tablet keeps stopping unexpectedly at the home screen and there is no way to stop it. can you reset this unit?
Are you trying to wipe the data with the reset? This will get you back to factory settings. It is entirely possible that there are apps on the tab that need to come off and have caused a problem.
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
Mar 04, 2011 | Samsung Galaxy BBSPHP1 Tablet PC
Kata T2 - 8" IPS ANDROID 4.1.1 TABLET Logo
35 people viewed this question
Top Kata Tablets & eReaders Experts
Are you a Kata Tablet and eReader Expert? Answer questions, earn points and help others
