Question about Samsung RF4287HA
The refrigerator makes ice but the dispenser does not work.
  • 954 Answers
Try this informative video on YouTube.com: https://www.youtube.com/watch?v=I6Sgbo-CB3s I also like this site: http://www.hometips.com/repair-fix/freezer-ice-maker.html I hope this helps!
Posted on Apr 26, 2015
3 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: water dispenser
Can you pull you refrigerator away from the wall and carefully remove the cover over the area where the water feeds the refrigerator. There should be a set of plugs one for dispenser and other for the ice maker. Make sure both sides are plugged into the dual water control valve. I did try to pull your model number up so I could help you better, but the model number above your post goes to an oven. Maytag and Samsung sometimes places parts in places that are hard to point out. Tis could also be a dispenser lockout. If you find the problem this would be something that commonly happens an assembly line. If you find the correct model number I will send you a service manual. Either way I am here to help, Thanks,Sea Breeze
Posted on Jan 17, 2010
richroth
  • 9472 Answers
SOURCE: It doesn't make ice, water dispenser works, ice maker motor knocks
What is the model number of the unit?
Posted on Nov 13, 2012
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Why water to icemaker , none to water dispenser , replaced water inlet valve fghs2655pf1 or 4a32520097
Refrigerator Not Making Ice? Water Inlet Valve Test - Fridge ...
? 2:47
https://www.youtube.com/watch?v=aXIX73EI1Z4
May 15, 2012 - Uploaded by RepairClinic.com
This video demonstrates how to test a water inlet valve on a refrigerator. ... Ice maker or water dispenser not ...
Refrigerator Ice And Water Dispenser Not Working - Repair ...
www.repairclinic.com/...---/Refrigerator-ice-and-water-dispenser-not-wo...
How It Works: Refrigerators · How It Works: Refrigerator Icemakers · How It Works: ... Most Frequent Causes for Refrigerator ice and water dispenser not working.
Nov 18, 2015 | Refrigerators
Why won't ice dispense from ice maker?
Pull out the ice storage bin from the refrigerator. Empty the bin if it is full. Add some ice into the bin. Reinstall bin into refrigerator. Make sure the refrigerator door(s) are closed. The ice will not dispense if the door(s) are open. Press the ice dispenser with a glass underneath it to start dispensing ice. Listen for a whirring sound. If there is a sound, then the auger that moves the ice cubes is working. Check the ice shoot in the door to see if it is blocked with ice. If you don't here any whirring sound the motor that runs the auger is probably bad. Then you will have to replace the whole ice maker assembly.
Jul 20, 2014 | GE Refrigerators
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Ice dispenser not working
Ice auger in freezer compartment not working. Common problem with GE side by sides I know of at least 3
Jan 21, 2008 | Amana ACD2232HR Side by Side Refrigerator
Samsung RF4287HA Logo
140 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
