Question about In Microwave Ovens
Do you have any clue, why. I've had three microwave ovens to go bad in the same kitchen receptacle.
  • In Master
  • 932 Answers
Tom,
I would suggest having a licensed electrician check out that outlet. You may have a more serious problem and you do not want to have a short that could cause a fire.
Posted on Apr 27, 2015
Accidently locked microwave model#ME18H7045FS can't unlock HELP
try this. In future, the make helps :>) Also it is 'SF' not 5F. ME18H704SF
To Set:
Touch and hold the CANCEL/OFF Pad for
three seconds. The Display shows "LOCKED"
and the oven beeps.
To Cancel:
three seconds. "LOCKED" disappears from the
Display and the oven beeps.
Read more: http://forum.appliancepartspros.com/microwave-repair/441562-locked-microwave.html#ixzz4klZNPoYN
http://www.appliancepartspros.com
Here is your manual
Samsung ME18H704SF User Manual Setting The Time Child Lock Options Kitchen...
Here is the full details on you microwave from Samsung
OTR Microwave with Ceramic Interior ME18H704SF Owner Information Support...
Jun 22, 2017 | Microwave Ovens
I have a kitchen aid over the range microwave that makes a humming noise ehen off. Almost sounds like a buzzing transformer. ykhms1850ss-0 Is the model.
Possibly the wall receptacle has been wired with black and white wires reversed and/or the green ground wire not connected.
I had a GE microwave that periodically would buzz white operating but eventually the buzzing stopped.
Sep 16, 2016 | Microwave Ovens
Microwave oven extension cord?
That receptacle is only for the microwave . However , the amps that the lighting would use is probably minimal . You should have two female outlets in the one receptacle so go ahead and try it. The worst case scenario is you pop a circuit breaker and remove the lighting from that plug.
Feb 07, 2014 | Microwave Ovens
No power to clock or microwave. Have checked breakers.
The main fuse in the microwave oven has probably blown, caused by a defective door.
Feb 07, 2011 | Jenn-Air JMC7000 Microwave Oven
GE PVM2070SMSS Microwave, Unit runs for a sec then shuts off.
Obvious thing is to try plugging in a different receptacle to verify if it might be bad wiring in your kitchen. Make sure to use a different circuit, maybe in different room. If it is the circuit, then likely cause is those plugs with push in back wiring. Replace with ones that wire screws to.
Aug 28, 2009 | GE PVM2070SMSS Microwave Oven
My new microwave is completely dead
good day,
hope this link below will solve your problem.
kitchen appliances
May 24, 2009 | Panasonic NN-H504WF Microwave Oven
Power out on Whirlpool over-the-stove microwave
Yes, There are fuses inside the keyboard panel. I would have to take a look at the manual for the specific model you have to identify the easiest way to check the fuse.
Before you go that far check above the hood and see if you can locate the plug end of the microwave. Most installations have a dedicated receptacle above the exhaust vent and microwave. It is usually a space too small for good storage so most housewives store small items and cookbooks in this space. It is usually the culprit for a microwave suddenly going out without someone placing metal inside the oven and heating it.
Heating a metal object or operating a microwave for an extended time will usually blow the fuse.
r_craig@basicisp.net
Jan 06, 2009 | Bosch HMT9626GB Microwave Oven
Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
