Question about Xerox Office Equipment & Supplies
Xerox dc 250 magante ros error - Xerox Office Equipment & Supplies
  • JMJr May 07, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Do any numbers come up?
4 Suggested Answers
SOURCE: Error 3-397 Xerox DC 12
Hello, I have a Xerox DC 12 and i receive the error 3-308
Someone can you help me or information about me ???
Thank you.
Posted on Feb 23, 2008
  • 8 Answers
SOURCE: Xerox DC 12 Error : 9-667
Hy there
Try to replace the print drum unit.
this is the information of the error code
9-667 VH/VM Out Of Range RAP
Description
The selected LD value was out of range.
Initial Actions
·Refer to BSD 9.1 and BSD 9.15 for the following procedure.
·Clean the ESV Sensor.
· Check that the P/J141 on the ESV Sensor, and PJ 422A on the IOT Drive PWB are firmly connected.
Procedure
Perform the following in the order listed.
·Go to the IQ 38 Charge Corotron HVPS RAP and check the Charge Corotron HVPS for proper operation.
·Ensure that the Charge Corotron Wire and Grid are in good condition.
·Go to FLAG 6 and FLAG 7 on BSD 9.1. Check the wires for an open circuit or a short circuit. If the wires are good, replace the ESV Sensor ( PL 5.1 ). If the problem continues, replace the IOT Drive PWB ( PL 9.2 ).
·Replace the Drum CRU ( Machine Consumables).
Posted on Mar 10, 2008
  • 155 Answers
SOURCE: xerox DC 3535 error 116-332
Simultaneously press and hold the 1,the Stop
and the Power Save buttons on the Control
Panel,if problem continues repeat the same
with
6,the Stop and the Power Save buttons
4,the Stop and the Power Save buttons
3,the Stop and the Power Save buttons
Posted on Aug 28, 2009
How do we remove. 061-325 xerox 250
It seems you will have to replace cyan \ black ros (laser assembly)
Mar 09, 2017 | Xerox Office Equipment & Supplies
Error 061-321 xerox workcentre 5024 - Xerox Office Equipment & Supplies
061-321 ROS Motor Fail
BSD-ON: CH6.5
The number of rotation of the ROS Motor did not come within the standard range within the specified time (5 s) after the ROS Motor On.
Cause/Action
1. Turn the power OFF and ON.
2. Check whether the Drum Cartridge is installed.
3. Check the ROS Motor (Output Check [061-001]) for operation failure.
4. Check the LD +5VDC power supply of the LD PWB J140 pin-8.
5. If no problem is found, replace the following parts in sequence:
• ROS Assembly (PL 2.1)
• ESS/MCU PWB (PL 18.3)
http://turbobit.net/upqkewkg8xjt.html
Feb 18, 2017 | Xerox Office Equipment & Supplies
I have xerox dc 250 machine, it shows fault code 077-909, paper jam at tranfer module but i checked there is no paper in it??
Hello friend, you are not alone !!!!
From http://www.copytechnet.com/forums/xerox/28764-dc-250-fuser-problem-077-909-a.html
At the bottom of the page it says.......
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
Sep 03, 2014 | upbright AC / DC Adapter For XEROX...
Xerox DC12 gives error 14-372 please HELP!!
ERROR 14-372 ROS MOTOR FAIL , ITS THE MOTOR THAT ROTATES THE POLYGON OF THE LASER BEAM , ITS LOCATED , BELOW THE SCANNER UNIT AND OVER THE COPY/PRINT CTG. 13R557/13R558 . IT CAN BE ONE OF 3 THINGS THE ROS ASSY. (LASER SCANNER UNIT OR ROS) , IOT DRIVE PWB(THE PC BOARD BELOW THE NVM AND IOT-SYS) OR A PROBLEM ON THE WIRING HARNESS / POWER SUPPLY. WE CAN REPAIR THOSE UNITS OR I CAN PROVIDE YOU THE PART NUMBERS IF YOU WANT TO ORDER THEM NEW FROM XEROX . diesco_cxl@hotmail.com
Mar 23, 2009 | Xerox DocuColor 12 Printer
ROS Trouble with Xerox DouPrint N17
The ROS is the laser. Believe me you can replace the machine for less than the cost of a laser. The Polygon motor is most likely bad in the laser. I would guess in the $500 range for the laser
Dec 09, 2008 | Xerox DocuPrint N17 Laser Printer
37 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
