I have a 2011bulletBHS.How does the Furance work with out using propane.Works fine with gas. When using elec.the fan comes on for 4min then shuts off.Help. Email me a anwser.Ryan_nickerson@hotmail.com
  • Ryan Apr 25, 2015
    I should really read stuff before I post.
    Will the furnace work with only using electricity?? It works fine using propane
    Top Expert:
  • Heating & Co... Master
  • 46,364 Answers
Propane is gas or have I gone nuts too
Posted on Apr 25, 2015
  • Ryan Apr 25, 2015
    Propane. Sorry
  • Ryan Apr 25, 2015
    Sorry. Will the furnace work on electric alone.
  • 12 Answers
SOURCE: the gas does not light
get a new unit dont play with propane it goes bang!!
Posted on Nov 01, 2009
  • 288 Answers
SOURCE: I have a propane furance in a mobile home. When I
if you are getting power to the gas valve, then all of the safety switches should be closed. if you have any drain lines off of the inducer fan and at the bottom of the heat exchanger, make sure they have a trap and have water in them. the pressure switch may be the culprit.
Posted on Dec 09, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: propane gas model VP2800BT ..fan runs continuously
Sounds like a bad fan switch. It is a small sensor attached to the heat exchanger and is designed to turn on at a specified temperature. When the unit is cold, take an Ohm meter and test for continuity across the switch. It should be open if good. If it shows a completed circuit, replace it.
Posted on Dec 27, 2009
  • 102 Answers
SOURCE: the heater works properly for about 30 seconds and
There should be a flame sensor somewhere near the burner it will be a single wire going to a steel rod. Try cleaning this.
Posted on Dec 13, 2010
  • 120 Answers
SOURCE: hi my miller gas furance burner comes on but the
sounds like the fan motor maybe bad. take the fan door off and see if you can spin the fan. if not the motor will need to be replaced. if it does turn you will need a volt meter to test the input voltage.jumper the fan door switch and lite off the furnace.with the volt meter on the high speed wire you should see voltage in about 60/90 sec. if you have voltage once again the fan motor is bad. if no voltage your furnace is cycling off on your t-stat or your board is bad.
Posted on Mar 23, 2011
Procom propane heater works fine until the fan comes on then it shuts down, works fine with fan running if the front cover is off ??? anything??
Sounds like when the cover is on it over heats. You need more air ventilation. Check for dirty filters or screen. Check whole machine. Not sure if that's the answer. Good luck.
Dec 26, 2016 | Procom Heating & Cooling
Blower inop on auto or manual. burner inop.
Hi check out the fan control afc see if it is clean , check out pressure switch and the flame sencer
Feb 21, 2010 | Coleman Propane Forced Air Heater...
I have a propane furance in a mobile home. When I turn the thermostat up the furance comes on a heats the room to the set tempature. after the room cools back down the thermstat clicks but the burner will...
Dec 09, 2009 | Coleman Propane Forced Air Heater...
The gas does not light
Oct 31, 2009 | Reddy Heater RLP100 Portable Forced Air...
Lenox Gas Furance Summer Fan Not Working
Just curious, there sometimes is a safety switch on the door to the fan unit so no one gets hurt opening it to change filters ...etc... make sure all the doors are on tightly
Jul 30, 2009 | Dryers
HEATER WAS WORKING FINE TILL I HAD PROPANE TANK TOPPED OFF
The Pressure Regulator may be stuck, Try closing the propane valve releasing the pressure,, gently tap the regulator( on the propane inlet side) and Very Very slowly open the propane tank valve, and attempt to light
Jul 30, 2009 | Hayward H Series
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
Dec 09, 2007 | GE Profile JGS968 Gas Kitchen Range
Heating & Cooling Logo
124 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
