Question about GE Dryers
Model number DBVH512EF0WW for my GE dryer is reading E61
    Top Expert:
  • GE Master
  • 47,775 Answers
Check the door switch.
Posted on Apr 25, 2015
5 Suggested Answers
SOURCE: ge adora dryer #dhdvh52efoww has code E61 and does not work, how can i fix it
Turning off in the middle of cycle and code E62
Posted on Aug 25, 2009
Daniel S
  • 4323 Answers
SOURCE: I have a GE Front
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. Hope this helps...please post back for further assistance.
Daniel
Posted on May 08, 2011
  • 72 Answers
SOURCE: I have a GE front
It sounds like the timer is bad.
Posted on Aug 31, 2011
heatman101
  • 43501 Answers
SOURCE: Ge Dryer 4 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Posted on Sep 10, 2011
My dryer won't power up. The model number is dbvh512ef0ww.
Check the circuit breaker, then I would check the belt switch- if the belt breaks, the machine will not tumble GE Dryer Switch WD21X10261
Jul 27, 2016 | Dryers
GE Model DBVH512EF0WW drier will not start will just buzz.
John,
If you have a warranty on the dryer, this would be the time to use it. If not, call the nearest SEARS repair center and let them send a tech out.
Sep 21, 2015 | GE Dryers
I have a GE dryer and it's reading the code E61 what does that mean
For GE dryers, the E61 code indicates a problem with the wiring or the control board. The dryer is sensing the wrong voltage between the hot and neutral lines of the incoming wiring. First check your wiring/fuses/circuit breakers. If your wiring is OK, then the control board is probably faulty.
If you post a comment with the model, I may be able to point you to the appropriate parts. I hope this helps.
(note: if you have an electric dryer using 220V, you may want an electrician to check the wiring.)
Apr 25, 2015 | GE Dryers
Ge Dryer 4 years old model DBVH512EF0WW no heat power is good to dryer heater ok thermostats ok PROCESS OF ELIMINATION LEADS ME TO a power board above drum, diagram says it has some relays on the...
heatman101;
Sep 10, 2011 | GE DCVH515EFWW Electric Dryer
No heat, power good. 120 each leg. drum turns. ran diagnostics. no error codes. t07 reads 73f, to8 reads 74f, t09 reads 5.01. suspect heater element is open. model is DBVH512EF0WW. would have thought error...
better but the restring kit comes in bracket # WE11XM30 heater assy mica heater but i would check tstat on top left of heater 2nd thermstat in ward rivited on metal plate thats usually the bad one and the thermistor on blower assy # WE4M336 or get complete asymbley 512 on parts break down and 240 on parts breakdown thermistor
Jan 31, 2011 | GE DBVH512EFWW Dryer
Dryers Logo
117 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
