Hi, i herd a loud popping noise now my washing machine wont turn on at all there are no lights showing on the main board. please help thank you
    Top Expert:
  • Washing Mach... Master
  • 42,122 Answers
Check the house fuse board for a circuit breaker off
if that is the case get an electrician to check the machine as it has short circuited
Posted on Apr 26, 2015
  • Noli Morales
    Noli Morales May 02, 2015
    The same thing happen with my washing machine, I did check my house circuit breaker and I re-set it. But my washing machine wont turn on still.
I have a Hotpoint Aqualtis wash/dryer which stopped working with a 'F12' fault. Now when I turn the socket on I get an immediate really loud whir/buzz.
possibly the main drive belt has either snapped or jumped off the pulley and this allows you to turn easily by hand the whir/buzz sounds like system in coming into play but with no belt to drive nothing more happens, the front lower portion of the machine could be the water pump working overtime unable to drain ???
May 09, 2016 | Hotpoint Washing Machines
The city turned off the water to fix a main line and then turned the water back on. The first time I started the washer after this happened, I heard a loud pop noise and the water began gushing into the...
SOUNDS LIKE THE WATER INLET VALVE COIL BLEW A SEAL? DOES IT STILL POUR WATER IN AFTER UNPLUGGING IT? IF NOT THEN U MAY HAVE AN ISSUE WITH THE TIMER OR BOARD SENDING ELECTRICAL SIGNAL TO THE INLET VALVE? BUT THE POP LEADS ME TO THE INLET VALVE CHECK IT WITH A MULTI METER
May 25, 2014 | Asko W6661 Front Load Washer
LG WM2487HRM washing machine will not do spin cycle. Get a loud humming noise, no error code. Just replaced the hall sensor, but still getting the same results. No change. Any suggestions?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 07, 2011 | LG WM-2277HW Front Load Washer
Last night our TV made a loud popping noise then the picture went out. We still have sound but have trouble turning the TV off. What could this be and is it fixable? Thanks, Anne Marie Orcutt
Question shows it is Vizio L32 lcd tv and symptom shows back light inverter board for defective for some reason and loud noise would be popping of any chip on inverter board.
Shopjimmy..com has replacement boards of that model on reasonable price and local tv repairman will replace defective board after checking/ testing the tv.
Hope these info will help.
Thanks.
May 11, 2011 | Vizio L32 32 in. LCD HDTV
Have a vizio 42plasma about 4yrs old. a lil bit ago i started to get red an green flashes thru the pic then the other day i herd a pop an the screen went black. when i turn it on now the pic/image comes...
The main tv Tuner signal board is dead.That the board,where the incomming broadcasting signal cable plug into it.Try website like Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Feb 26, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
Washing machine showing fault code F.03 could you tell me the fault and how to cure it. thank you rob.
may be there's a loose connection to the main board , very simple to fix just pop the top off ( be sure to unplug your machine before you start) and reseat the ribbon connctor to the main board, also reseat a ribbon connection in the bottom of the machine ...........so if your machine shows f 03 give the above a go, good luck.
Sep 25, 2009 | Washing Machines
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Hotpoint aquarius wd440g washer/dryer
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Jul 27, 2008 | Hotpoint Aquarius WD63 Front Load...
GE prodigy
A loud popping noise could be a fault in the electrical capacitor (aka condenser) near where the power comes into the machine.
Disconnect it from the power and see if there are any black steaks or burn marks on the outside of the capacitor. Not too expensive to fix if you can do it yourself.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please delay the rating and add a comment with more details so I can try to help you further. Cheers, D
Jun 14, 2008 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
