Programmed it to 70 and was still going at 78. Does not turn off. Just installed it. What do i do?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Cnristine, if it was 'just installed'....I would double check the wiring as the problem you describe could be related to incorrect connections in the control circuit.
Posted on Apr 28, 2015
  • 5,631 Answers
Remove your defective thermostat and buy a new one
Posted on Apr 25, 2015
How do I get my spa to heat up? please provide me instrctions
turn up heat if it doesnt go check temp if it seems odd replace temp sensor ohm it out if 78 ohms at 70 degrees its ok then check heater element fuses and element
Oct 03, 2014 | Pool & Spa
Thermostat is following a schedule when none is set
Your Lennox thermostat could be defective, but it may have been programmed by some inadvertent button pushing. The thermostat also has certain default settings such as a low limit that will trigger heating if the indoor temperature becomes too low (to prevent freezing of pipes).
Feb 09, 2014 | Heating & Cooling
How many amps should my alternator be in a 78 mark v
it depends ford made several alternators ranging from 40 -70 amps, if i were to guess if the lincoln is loaded it probably has a 70 amp alternator.
Jan 25, 2012 | Lincoln Mark V Cars & Trucks
Need to know the torque on head screws for honda accord 93 2.2lt ex
On 1990-93 Accords, tighten the bolts to 29 ft. lbs. (40 Nm) on the first pass, 51 ft. lbs. (70 Nm) on the second pass, then tighten the bolts to their final torque of 78 ft. lbs. (108 Nm).
May 29, 2011 | 1993 Honda Accord
What does recovery mode mean?
the unit has been set up in the installer set up for recovery... this is for when you are running a program on the thermostat and say you have it set for 5:00 p.m. to come n and run at 70 degrees the revovery is where the thermostat knows at 5:00 p.m. it will not be 70 degrees so determines run time and may come on several hours before your programmed time in order to be 70 degrees at 5:00 oclock.... you can turn it off so that the program will only come on and go off at desired programmed times... you will have to get into the installer set up feature usually requiring to hold down 2 of the buttons at the same time... hopefully you have your paper work on the stat still if not repost with a request for a manual or instructions good luck to you...
Jan 09, 2011 | Honeywell TH4210D1005 Heater
My home too is stuck at 78 degrees with the Chronotherm IV
a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
Trouble with newly installed thermostat
did you program your own temps, if not i believe this is part of default program!
Jun 30, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
283 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
