Question about Saws
Miter saw base wont rotate. how to disassemble? It's a kobalt 12 inch compound miter saw
Kazong
  • 152 Answers
SOURCE: craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Posted on Jan 13, 2008
jyackle5
  • 8197 Answers
SOURCE: Makita 10" Compound Miter Saw LS1040 manual?
Here you go.
This is the ls1040
http://www.makita.com/en-us/Assets/images/Products/LS1040/owners_manuals/LS1040.pdf
This is the ls1040f
http://www.makita.com/en-us/Assets/images/Products/LS1040F/owners_manuals/LS1040.pdf
Posted on Mar 12, 2009
  • 323 Answers
SOURCE: Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Posted on Oct 31, 2009
airnailer
  • 109 Answers
SOURCE: 12 inch compound miter saw wont turn on. was
check fuse box/ circuit breaker,,make sure its plugged in,,,check cord, switch, and the connection of the cord to the switch,
Posted on Dec 02, 2009
  • 33 Answers
SOURCE: My blade gaurd will not automatically rotate out
MS12502 has a solid arm actuation to move the blade guard, this is either bent, broken, unattached or otherwise not functional. sometimes the moving parts get full of sawdust and a major cleaning is all thats needed. generally all woodworking tools should be blown out with air after each use or end of day.
actual model number of your saw would be more helpful.
I need manual for Kobalt sliding miter saw 71/4"
try going to the store where you got it. sounds like a LOWES product
Jul 03, 2014 | Bosch 12" Compound Miter Saw 3912
How do you adjust the laser from side to side on a Kobalt 10-in 15 Amp Slide Compound Laser Miter Saw
goto https://www.lowes.com/pd/Kobalt-10-in-15-Amp-Single-Bevel-Sliding-Laser-Compound-Miter-Saw/3512785 and scroll down to guides and documents download PDF
Dec 22, 2017 | Measuring Tools & Sensors
Bosch Glide Miter Saw get stuck at 45 degree bevel to the left
Adjusting the miter angle involves two cast surfaces sliding against each other. If those surfaces have some irregularities, high spots on the two surfaces will bind against each other. You may have to disassemble the rotating table from the base and do some filing or grinding.
Dec 29, 2013 | Makita Tools 12" Compound Miter Saw -...
User manual for 251946 kobalt sliding compound miter saw
Try to find it on amazon, Amazon com kobalt saw manual, they have great amount of books, so, maybe you are lucky. I hope this helped. Cheers
Dec 02, 2012 | Bosch 12" Compound Miter Saw 3912
How to change the blade?
I don't know if this will help you much but I've got a DeWalt 14 inch chop saw and a 10 inch miter saw and they both have a small lever on the right hand side of frame just behind blade If you depress this lever and slowly rotate blade until it drops into place this locks the blade for changing. Hope this helps you. Thanks.
Nov 22, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
I need manual for kobalt sliding miter saw sm2505lw
Call-18883Kobalt and they should be able to help you. Listen for the prompts to make sure you get the right service agency for miter.
Sep 15, 2010 | Bosch 12" Compound Miter Saw 3912
How to turn the base for compound cuts
Is there not a piece metal at screw handle to push down on top,or pull up on bottom, then rotate?
Jan 13, 2010 | Saws
Table and base not level (co-planar). Extension wings higfher than base as well.
Just read thru most of the user manual and they do not address this situation. Most major adjustments they list as Service Center meaning they might have to completely disassemble and find out hy this saw is not accurate, wish I had better news.
May 10, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
Saws Logo
359 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
