Question about Home
How do I reset the memory? - Home
How to retrieve photo's when camera has been reset. I accidently hit the reset button & there are no photo images on my camera/memory card.
You can retrieve photos from camera with memory card recovery software, recommended asoftech photo recovery as it helped me before. Download the software from link below
Memory card photo recovery
You may also take a look at this tutorial
Nov 02, 2011 | Samsung Digimax S630 Digital Camera
I have forgotten my security code
Please use one of the below Samsung secret codes to format your phone:
There are actually two codes that you can actually use to
reset the password. Below are these codes. Please dial them
up and have the problem solved.
*2767*3855#
*2767*2878#
Through this mean the security code will be reset to 0000.
This will allow you to format the phone easily.
If the problem is same follow another step
Please hard-reset the phone.
Please note that this will erase all data in phone memory and storage memory! It's better to save all your data on a memory card before resetting the phone.
To do hard reset:
Press "Main Menu" > "Settings",
Tap on the "System" Tab,
Tap the "Hard Reset" option,
You can choose the type of memory you want to reset, either Main and Storage Memory.
OR
Just click on "Clear Memory" button to reset the phone completely.
Your phone will be restarted and reset to factory settings.
Hope this helps.
Jan 10, 2011 | Samsung Alias 2 SCH-U750 Cell Phone
My HP 48GX just displays a black (all pixel) display screen with one vertical stripe down the middle. I tried reset button and now it displays 2 vertical stripes (the new one divides the right half in...
I just had this exact problem so I reset the memory as instructed below. Know I am back in business. Memory reset A memory reset will return the HP 48 to its factory-default state, which will erase all stored user memory. Use this feature very carefully.
  1. If necessary, turn the calculator on.
  2. Press and hold the ON+A+F keys simultaneously.
  3. Release all three keys at the same time. This should cause the calculator to display the message "Try to recover memory?"
  4. Press the A key to attempt to recover memory or the F key to erase the user memory. When A is pressed, occasionally the objects in memory are recovered in new sub-directories of HOME labeled D.01, D.02, et cetera, although there is no guarantee that all of the variables will be recovered. Pressing the F key will cause all information stored by the user to be erased from calculator memory. This will also affect any RAM card that is merged with main memory. If the card is not merged or it is write-protected, it will not be affected by this reset.
Hardware symptoms and solutions I. The display screen has a blue/purple blotch of color, even when the unit is off The screen is damaged, and the calculator requires service. Please contact HP . II. All of the pixels on the screen are lit (blue)
  1. Try to adjust the contrast by holding down the ON key and repeatedly pressing the [ - ] key.
  2. If the screen is still dark, try to halt the system using the keyboard.
  3. If this does not correct the problem, try to reset the system using the reset hole with the batteries removed.
  4. If this does not work, remove the batteries and let the unit sit for 48 hours. After 48 hours, replace the batteries. If the problem persists, attempt a memory reset. Although removing the batteries for 48 hours should erase the user memory, performing a memory reset will ensure that the calculator is reset to its factory defaults.
  5. If the problem persists, the unit requires service. Please contact HP .
Dec 30, 2010 | HP 48gx Calculator
How to cancel memory lights on canon mx310
First try to press the reset button for 5 sec or more and see if the memory will reset this way ..
If not ..look in the menu for memory and see if it has reset /delete feature on the memory options ..if not..open the front door to get into the maintenance mode..and after that look for memory reset ..
Another way to reset a canon printer is as follows :
http://www.ehow.com/how_6833747_reset-ink-mx310.html
Oct 28, 2010 | Canon Office Equipment & Supplies
Any one knows how to format phone memory of 7210 supernova
There are two types of reset Soft and Hard reset.Soft reset restores only settings whereas hard reset resets entire phone memory
For soft reset *#7780#
For Hard reset
*#7370#
Oct 27, 2010 | Nokia 7210
Trying to clear the memory of a Xerox Faxcentre F116. Do you know the steps to accomplish this?
One needs to know what they are doing when resetting memory to the machine.
When resetting the machine, one needs to consider, the loss of memory data on the copy cartridge counter in the machine.
When resetting memory a copy toner cartridge needs to be in stock with a counter reset card.
Erasing memory will wipe out the old copy/toner cartridge odometer setting, resuling in "Replace toner/cartridge" error.
Please clarify which memory area is being erased.
Aug 05, 2010 | Xerox FaxCentre F116 Plain Paper Laser
Doesnt read memory card
go to menu/settings and security reset then enter 0000 and that will reset the phone or you can seek your manual for the that.
Dec 27, 2008 | LG RUMOR Cellular Phone
Need to reset memory
how do i reset mfc 420cn printer?
Feb 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Problem eith bluetoth
Hello
You could try doing a master reset but you will lose all data / contacts /pictures/ on your phone
Steps to do a master reset
Settings/general/master reset/reset all/continue
Phone will restart
Darrin
Jan 04, 2008 | Sony Ericsson W550i Cellular Phone
RESETING PHONE MEMORY
If its your memory card you want to format goto
"Extras > Memory > Options > Format Mem Card"
If it's your phone memory, there isn't a quick way to do this.
To find out whats on your phone memory goto
"Tools > File Manager > Options > Memory details"
But if you don't want to keep anything on your phone, just goto to Fliemanager and delete everything, you should probably do a factory reset as well.
Oct 29, 2007 | Nokia 6680 Handheld
Home Logo
534 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
