Question about Panasonic Televison & Video
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
  • Panasonic Master
  • 698 Answers
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Posted on Jun 03, 2015
  • 13 Answers
SOURCE: Panasonic HDTV 1080i Lamp out
If the lamp is actually out - replace it - if the lamp is still working just reset the lamp hours - at 10,000 hours it automatically says that but it is just the lamp time needing a reset.
Posted on Jun 02, 2009
SOURCE: Panasonic pt-50lc14 lamp needs replaced.
You will find this very easy. Take the front panel off. It just pops off. Two screws..one on the out side door and one inside the door. You can do it from there. Oh yea put the back of the Tv back together....lmao.
techman
  • 3130 Answers
SOURCE: panasonic pt-50lc14 replacement lamp. i
it is described in the owners manual. If you do not have the owners manual you can get one for free off the panasonic website
Larry Dillon
Posted on Aug 05, 2009
  • 5 Answers
SOURCE: Our LCD lamp went out on our PT-50LC14 Panasonic,
It is relatively easy if you are certain that the bulb is burnt out and needs replacement!! I would prefer you read the instruction manual for important information and especially if you have never attempted to do something like this before!! Here is the link to the manual: http://www.fixya.com/support/p232593-panasonic_pt_50lc14_television/manual-7812
If you are 100% certain that you can handle this and you know for a fact that the bulb is bad, the first thing you need to do is turn the power off to the TV. Then wait one minute until the bulb cooling fan stops. You can usually hear it stop! After this has happened unplug the power chord from the outlet.
On the front side of the TV is a long grey panel that is 3 13/16" wide X 34 1/16 inches long. This panel pulls toward you and pops off, with no screws holding it in place.
Behind that grey panel, to the left of center, you will see a white sticker that says " CAUTION:HOT SURFACE". To the upper left of that sticker you will see a black phillips screw that needs to be removed along with the black panel that it holds in place ( black panel approximately 6 9/16" long x 5" high). Once the black panel is removed you will see the front face of another black box with a center grab handle. This is the bulb & housing.....it is an all in one piece and it pulls out directly towards you, once you remove the silver screw on the right side of the bulb housing. Remove this screw first!! You will know you have the correct screw because it has an arrow pointing at it. This screw holds the bulb in place.
Please be careful to pull the bulb out without touching any part of the bulb or bulb housing, as it may still be hot!! Place the new bulb in the same exact way the old bulb was removed and reinstall the silver screw that holds the bulb in it's place. Re-attach the smaller black outer cover, 6 9/16" x 5", and replace the one black screw that holds it in place. Then reinstall the long outer silver panel that covers all of this.
Once installed, please refer to the owners manual for how to reset the hours meter, or you will not have an idea of your replacement bulb life. A quick tip on resetting the hours meter.....the instruction manual tells you to push certain buttons to reset the meter. What they fail to mention is that they are referring to pushing those buttons on the TV set, not on the remote, as is implied, or left to interpretation. When resetting the hours meter, certain commands require pressing buttons on the remote and certain commands require pushing the buttons on the TV set itself....read carefully!!
I hope this helps someone install their bulb and reset the hours meter without to much trouble!!
Posted on Aug 30, 2009
johnnydiode
  • 647 Answers
SOURCE: Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Posted on Nov 12, 2009
Should I replace my lamp for my Panasonic 1080i htd t.v. pt-50LC14
Replacing a lamp won't work. There is not even one lamp in your TV. I'm afraid the lightening has done more damage than can be repaired. Even when some tech manages to repair te error, the TV can have the next error in days or weeks.
Try reading something about ESD. Electro Static Discharge and what it does to electronics. Electrostatic discharge
Apr 25, 2015 | Panasonic Televison & Video
Tip
Panasonic PT50LC14 Manual Download
Download Panasonic PT-50LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-50LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-50LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Where is the lamp housing for the Panasonic
The lamp housing is located behind the front cover panel.When you open the front panel you can access the lamp unit screw.
thanx
Jul 21, 2010 | Panasonic PT-50LC14 50" Rear Projection...
How do I reset my lamp timer on a panasonic HDTV
go into menu.... and you will find lamp setting. reset it to zero hours
Nov 17, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Turn on Power
Nov 12, 2009 | Panasonic PT-50LC14 50" Rear Projection...
I need to know how to reset an indicator light fo a panasonic pt-50lc14
Panasonic Lamp timer reset.
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
asnowman
Oct 13, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Apr 08, 2009 | Panasonic PT-50LC14 50" Rear Projection...
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
104 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
