Question about Polaroid FLM-3734B 37 in. LCD HDTV
Speakers in TV making a buzzing noise.
The speakers in my TV are making a buzzing noise. I have tried replacing the speakers, but nothing changes. I have also disconnected and reconnected the speaker cable under the main power board. Still no change. What is wrong? Thanks.
  • Polaroid Master
  • 3,462 Answers
Try a reset to default settings. If that does not clear it I would suggest that it is either a hardware fault or interference
A constant buzzing might be interference from the power control card. What happens if you move the set elsewhere. Also, try it on another aerial, maybe there is a problem there....perhaps
Posted on Jun 17, 2015
SOURCE: Polaroid FLM-323B HDTV Loud Buzzing
or you can cut off the end of some old headphones and plug it into the side headphone jack.  works for me.
Posted on Sep 06, 2008
  • 4234 Answers
SOURCE: Picture is blank when tv is turned on when cold.
There are likely to be many poor connections in the power supply section that are causing this. If you can solder and the unit is no longer under warranty, you can try resoldering any connections that appear grainy or have rings. That may resolve the problem. If not, than one or more capacitors have changed value enough for the internal circuits to mal-function. This will take some test equipment to locate easily. Try resoldering first and update this with the results. I'll try to locate the most likely parts that could cause this.
Dan
Posted on May 01, 2009
romsky79
  • 822 Answers
SOURCE: Buzzing sound coming from TV Speakers and any external speakers
change your pre-amp ic sure it will work. or maybe cold solder from the board.
Posted on May 05, 2009
  • 41 Answers
SOURCE: Humming noise through Tv speakers. Goes away if I
If the noise is coming in through the onboard tuner then repair may the only option. If you have a DVD or VCR and can connect the line level inputs (look like stereo connections) then do so and use that input, if the sound persists there then it is likely the audio circuitry - also a repair item.
Bypassing the TV sound system involves connecting your cable box, DVD or VCR (using the tuner from that unit select channels) audio output to a stereo system and then the TV becomes a big monitor (picture only)
Posted on Jan 03, 2010
SOURCE: audio makes a siren noise, speakers pop and sound
no signal from my pc
Posted on Feb 11, 2010
Emerson tv problems
If you are using a cable or satelite box, the problem could be from mismatch of the volume level between the TV & the source. This is solved by properly adjusting the 2 volume levels to eliminate the buzz.
The issue could also be either your speakers or Input/Output PCB.
Also be sure it is coming from the speakers.There have been some issues of buzzing caused by vibrating transformers on circuit boards,
Jul 24, 2014 | Emerson LC320EMXF 32 in. LCD TV
Speakers had a buzzing/vibrating noise. had them replaced. still making same noise. happens on very low and loud volume. any idea what it could be? possibly the sound board?
maybe just poor speakers.....had a similar problem with an old sony. Replaced the speakers twice and always had a noticeable buzzing. Try running external speakers (computer speakers will work) at low volume to see if you hear it in those. If so, you may have sound board issue.
Jan 03, 2011 | LG 37LG30 37 in. LCD HDTV
Buzzing noise
you have to replace a capacitor in powersupply
c208 2200uf/16v
Apr 19, 2010 | LG 42LC2D 42 in. LCD HDTV
My speakers are not plugged into any soundcard but are buzzing
May be a short somewhere, speakers always have a little white noise and buzzing, usually nothing you'll notice.
May 28, 2009 | AOpen MA-691 Computer Speakers
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
Speakers Make a Very Loud Noise that Increases
try uninstalling drivers and reinstall them.
also remove latest M.S update as some update cause more trouble than they are worth
May 21, 2008 | Audio Players & Recorders
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
Mar 08, 2008 | Vizio L37 Television
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
Speakers making loud buzzing noise
From your alternator, Make sure none of your RCA's are near a power wire, check your grounds as well.
Jan 09, 2007 | Pioneer TS-D690R Coaxial Car Speaker
Polaroid FLM-3734B 37 in. LCD HDTV Logo
87 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
