Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Where can I get a diagram/schematic of the spring linkage throttle area?
    New Friend:
If Sears Parts Direct couldn't held you like Salvagedrover suggested . I'm assuming you are talking about a Kohler Motor ? If so I'm quite sure I can take some pictures off one of the machines I have here . Let me know if you've had any luck with the earlier suggestions . If not I'll take some photo's and forward them to you . When you answer with your findings this far be really specific as to which area you are looking for . That way I can get as many pic's at different angles to hopefully help you .
Posted on Apr 27, 2015
    Sergeant:
  • Craftsman Expert
  • 417 Answers
Sears is pretty good at providing parts breakdowns to customers searching for them. The nice thing is, they are displayed in a way that shows you how all the parts are assembled as well, I suppose so you can determine which exact part you need. Anyways, go to the sears website and towards the top of the page should be a tab for parts. Put in your model and serial number, then fish around for the particular parts group diagram you need. It's pretty easy, don't over complicate it by thinking about it, just try sears.com and look around a bit, I'm sure if you're confident enough to repair your own machine, (or just incredibly cheap,) you can figure out how to navigate the site to find what it is that you want.
Posted on Apr 26, 2015
2 Suggested Answers
  • 16 Answers
SOURCE: I had to repair pull cord, in doing so I took the
go to sears.com and look up the actual engine number. they have a section for lawn and garden and in there there is a link to their parts lookup and they are very detailed. but you will need a pulse tach to set the govenor back to where it was and if it spun the govenor open too far due to the govenor not being hooked up, it could have came apart inside the motor and you will need to take it to a shop. as far as setting the govenor once you get it all back together, you need to push the throtle wide open and turn the govenor shaft in the same direction then tighten it down. yeah its not hard if you have done it before but if you havent and cant understand what i just said, save your time, and engine and have a shop fix it. and i havent seen a motor in my 9+ years that you had to remove all of that to fix a recoil rope.
Posted on Feb 04, 2010
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
I need a diagram or schematic of the carb showing the throttle and choke linkages so I can set my linkage for choke and throttle
U need a service manual unless you know someone who knows what is what. Nest time you will take a picture in advance before you disassemble something.
Jul 18, 2015 | Garden
Throttle linkage diagram for toro 22035
This is the site I use frequently. There is a blowup diagram of the linkage. http://www.partstree.com/parts/?lc=Toro+Consumer&mn=22035
Dec 13, 2014 | Toro Garden
Governor linkage on toro snowthrower model#38415
If I cross reference the engine correctly it is a TEC HSK 850 so the follow service manual should be what you need.
Nov 03, 2014 | Garden
2008 yardman lawn mower 13.5 hp. has a high idle speed and does not slow down, need diagram for throttle control
Throttle cable should pull a SPRING, which pulls the governor, which pushes/pulls the carburetor butterfly valve.
Aug 12, 2014 | Yard Machines Garden
maybe someone took off the linkage cable what you need here is
to find a schematic of your unit and that should tell you where everything goes on the unit .you should be able to download a
schematic from the web!
Nov 09, 2013 | Garden
The Throttle linkage on the carburetor came off where does it go
on the inner butterfly linkage on the carburetor closest to the engine
Feb 27, 2013 | Mtd 22" Yard Machine Push Mower
I need the linkage diagram for a 20 hp briggs and statton model 407777-0167
Besides the service manual you can view parts diagrams at a dealer like www.arcolawn.com. You can purchase the service manual at a dealer and it will show you how to hook it up.
The throttle linkage hooks up to the throttle shaft closest to the engine. the governor spring attaches the governor arm to the throttle linkage.
The choke cable attaches to the shaft farthest from the engine. I hope this helps.
PS your engine has two factory service bulletins on it.
Joe
Feb 15, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Tecumseh 6hp engine
I have a 6hp tecumseh mower. "Centura Le". I prime it it runs..stop priming and it dies. I think it needs a new fuel pump/or filter. I can't locate on mower, will you advise?
Thank you
Jul 11, 2008 | Karcher 2500 PSI Pressure Washer
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
67 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
