How do I put it on channel 3? - Televison & Video
    Sergeant:
  • 268 Answers
If you are asking about using a standard CRT Monitor with some device that has a Channel 3 TV output, you have to either have a tv tuner device between your monitor and the device you want to connect to, or find video outputs on the device other than the TV channel out in order to connect to a monitor. Monitors work with video signals. TV's work with radio signals. These two inputs are not the same thing. Channel 3 is a specific radio frequency signal that must be converted to video to be displayed by a TV. Computer monitors do not have the circuitry installed to convert radio frequency signals to video. Therefore, strictly speaking, there is no easy way to 'put' a CRT Monitor 'on channel three'.
Posted on Apr 25, 2015
Find the channel to run DISH
Channel 3 is normal for that. Always have it on channel 3 on the TV set. Then you can work with it. Check your stuff and see is there a switch to set for channel 3 or 4, if none present, put it on 3, then start from the menu to set it up with remote.
Oct 07, 2014 | TCL 39" LED LCD 1080p HDTV - TVs & Home...
Lost remote sand need to be ablr to put TV on channel 3 for DVR hookup. problem is i had clean antenna and the channel is 3.2. or 3.1 who do i fet to channel 3 manually?
go to your menu button bring up add/delete start at 1 and and when it gets to 3 add it add 4 also just in case 3 doesn't work ! or go to ebay and buy a remote that is what i did .. good luck
Jul 03, 2014 | Emerson LC320EM2 32" LCD HD Television
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
What channel do i put for input for model number SB315
Needs to be on channel 3. Make sure you have good input with video going and do a channel scan. It will stop on 3 and memorize the channel.
Nov 20, 2011 | Televison & Video
My Tatung flat screen cannot be put on channel 3, and the remote is dead. Channel 3 is required to access cable
Try using channel 4 instead. There should be a switch on the cable box to switch it to channel 4 instead.
Nov 10, 2010 | Tatung V27DMBX 27 in. LCD Television
Aveis LT15AP3
AVEIS LT15AP3; WHEN CHANGING THE CHANNEL BY LAST CHANNEL OR BY PUTTING IN ACTUAL CHANNEL , IT DOES NOT CHANGE TO CHANNEL I PUNCHED IN BUT TO CABLE CHANNEL 3. IF I TURN TV OFF AND HAVE THE CHANNEL I WANT ON, IT COMES ON THAT CHANNEL. THEN IF I CHANGE CHANNEL IT GOES BACK TO CHANNEL 3. HELP????
Apr 14, 2010 | Televison & Video
Channel problems
Do any of the channels produce sound?
Aug 15, 2008 | Visonik V418XT 125W x 4 Car Amp Car Audio...
I put the wall cable to the vcr and the cable to the tv to the vcr, and i put the vcr on channel 3 and want to record channel 31, it records channel 3
you state here you put the vcr on chanel 3 but you want to record 31. put the vcr on chanel 31 to record
Aug 01, 2008 | Televison & Video
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
