Question about Intex Pool & Spa
Intex spa, I have power to the spa's GFI plug but, there is a loud, constant beep and no lights on the LED monitor. What's wrong?
No response when I push any of the buttons. Nothing in the manufacturer's book
    Top Expert:
  • Intex Master
  • 6,465 Answers
That means you have a short check heater element and pump motor
Posted on Apr 27, 2016
  • dawn
    dawn Mar 19, 2017
    How would I check this?? Have same problem n can't find schematic anywhere
  • Bob Asper
    Bob Asper Jul 02, 2017
    Dawn, did you get your problem fixed? I'm having the same issue.
SOURCE: my intex saltwater chlorine generator & filter beeping forever!!!
hello our pool chlorinator keeps comming up low salt 91 no matter how much salt we put in this is frustrating why is this happening ,,,please help
Posted on Jul 01, 2009
  • 5245 Answers
SOURCE: qo260gfi not tripping
Question is not fully clear.
2-pole 240Volt gfci circuit breaker requires the white wire be connected to neutral busbar.
Easy solution for 240Volt spa that comes with gfci:
Replace spa gfci with regular non-gfci breaker.
Install 2-pole GFCI breaker in main panel, and connect wire to spa breaker.
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
Having 2 breakers is not a problem.
Having 2 GFCI on same circuit is a problem.
Posted on Apr 19, 2013
  • 32 Answers
SOURCE: The water froze in my intex spa and control beeps. Cant turn temp up. What do I do?
Try using a blow dryer to unfreeze the water.
Posted on Jan 11, 2015
  • 1631 Answers
SOURCE: We have a LED code showing on the new Intex pure spa. E97 Dry-fire Protection. What does it mean
Dry fire protection is when the heater has a call to heat but it is sensing NO water flow, therefore heater will be disabled.
A dry fire is when the heater comes on with NO water flow - damaging your heater beyond repair.
Causes: No water in tub, closed valves, clog restricting water flow, or the pressure/flow switch had failed?
Posted on Apr 11, 2015
  • 1631 Answers
SOURCE: I keep getting a E96 code on my intex pure spa and
Intex Calls it a "System Error" - they recommend to Unplug, let rest, then plug it back in. If fault continues, call their service center,
But we have found that it is a poor quality GFCI Cord End in the 1st place and replacing it almost always fixes the problem.
DO NOT ELIMINATE THIS PIECE OF LIFE SAVING EQUIPMENT!!
Look here for a good replacement:
Leviton 16693 15 Amp 120 Volt Grounded Compact Automatic Reset Right Angle...
My intex pool pump model 633t Wont turn on after i dropped the plug what Did i do
test the gfi plug possible popped or damaged if popped just push reset
Jul 27, 2017 | Intex Pool & Spa
Control panel randomly beeps during filter/heating/standby modes with no LED readout codes. Reset unit no help. What to do?
It looks as if though, you are under the Intex curse.
I say this, because you really left no specific information about your pump. So by the wording of your question, where you mention beeps, heating, and LED readout, I'm presuming you have an Intex product?
The Curse I mentioned is because of historical and frequent premature failure of components, with no available parts to repair or replace. They make these with the intention of not to expect a long life of the product.
They would rather you replace the complete component. You have to understand one thing, these things are produced in mass quantities, by the gazillions, in China, and then unleashed into the unsuspecting world, budget minded people, hoping to get a satisfactory product, lasting forever.
I know, that statement is way out there!. But I see this so many times with customers coming into our pool and spa store. And after some conversation, it appears that that was the understanding when they purchase a product from Intex.
and the old adage comes to life and is so true... You get what you pay for.
my advice to you, is what I give to all of my other customers, in this same situation = call the manufacturer or the representative, and squeak. And squeak loudly.
maybe they'll hear this squeak, as squeaks are irritating, and hopefully for your sake, they will oil it.
Support Intex
Jun 14, 2015 | Pool & Spa
My intex portable spa was working fine now it only has a long beeping noise and nothing on control pad will work. Help
Unfortunately, it sounds like your controller has failed? Try turning power off for 30 minutes, NOT 29 1/2
Then turn it back on.
This will reset all short term memory in the logics, of circuitry.
If still non operational, unfortunately Intex Sells NO repair parts, they build these in a such a way to replace complete components.
So...
Sqeak and squeak loudly!
Maybe you will get some help from Intex?
look here...
http://www.intexcorp.com/contacts
Jun 12, 2015 | Intex Pool & Spa
Intex spa has power but just makes a loud constant sound. Lights go on. Pump will not flow water. What happened? Was working just fine for 2 months. Is it fixable?
It looks it would be worth fixing, first I would check the power, the plugs and voltage. it has heat so it requires the proper power cords to supply it,
If all checks out I would contact intex, if there is not any warranty, I would search your area for a electric motor repair shop, tell them its a spa pump with a heater,
I would be happy to look at it for you at no charge to see whats it's fault is. I'm in central Florida.. here are the error CODES. best of luck.. Jay
Dec 31, 2014 | Intex Pool & Spa
My spa won't turn on an just beeps.
sounds like temp sensor is either loose or bad if only two weeks old call who you bought it from should be warrantied
Jul 27, 2014 | Intex Pool & Spa
Intex spa
You have a bad GFI plug. Replace it and you should be fine.
Apr 13, 2014 | Intex Pool & Spa
My system just quit working like it is not getting electricty, what can I do?
Is it getting electricity? Check the breaker ... check the plug ... are you plugged into a GFI? Check the GFI
Aug 24, 2010 | Intex Automatic Salt Water System for ...
My pump stopped working after 1 month. It was running loudly then kicked the GFI in the plug and wont reset now.
unplug from gfi reset and plug something else in and see if it works, no then bag GFI, yes then sounds like pump is faulty return to place of purchase i would not recommend trying to fix yourself as some one could get electrocuted in pool if theres any mistake
Jul 07, 2009 | Intex Easy Set 530 Gallon Swimming Pool...
After going thru the Start up set up our Intex
After setting the time did you remember to re-lock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep? Several minutes later the Green LED should come on indicating the cycle has started.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
620 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
