Question about Kubota Garden
Hi I just bought a kubota t1760 riding mower used. It will go forward but seems slow not real slow and the forward and reverse petal is lose cause u have to wiggle it slowly to stop completely.
  • 396 Answers
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Posted on Oct 10, 2009
dolharoobang
SOURCE: troy bilt pony riding mower will go in reverse but
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
Posted on Nov 14, 2009
kel1guy2002
  • 3740 Answers
SOURCE: lawn mower has hydro gear transaxle reverse was
Most of the time when this happens the reverse shift linkage is too short. It is usually cause by either a bent linkage or worn linkage bushings.
The internal shifting fork can be bent inside the transmission which is rare but does occasionally happen... most of the time it is a linkage problem. Also check on the side of the transmission to make sure the shifting lever has not moved from the original position on the Yoke shaft.
Thanks for using FixYa.
Kelly
Posted on Mar 29, 2010
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
  • 21 Answers
SOURCE: my T1760 blows white smoke for 60 sec when starting
You have to check for a coolant leak into the cumbustion chamber. This unit is liquid cooled. Check coolant level and check head bolts for torque
Posted on Apr 25, 2010
How do I replace the main drive belt on a Kubota Lawn Tractor T1760?
Try looking that up on youtube. They have some excellent videos on belt replacement. Luck.
Dec 14, 2015 | Kubota Garden
Forward and reverse appear to be getting slower
hydro drives have a habit of failing
There is a requirement to change the oil on a regular basis so it is possible that the viscosity is changing from contaminants and
oxidization
best talk with your local Kubota service dealer and see if there is a problem other than oil
Nov 13, 2015 | Garden
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna riding mower modle yth20k46 that move very slow
The link rod from the petal to the transmission straightened out at the rear bend. Take it off and bend it slightly further to make it go forward faster. The 1/2" nut above where the rod connects to the transmission is adjustable to set it where it doesn't move when your foot is off the petal. Loosen it a bit and you can move the petal slightly forward or backward to adjust it. Depending on how much you bent the rod it won't take much adjustment. Re-tighten and try it out. It may take a few tries. Good luck!
Mar 17, 2012 | Husqvarna Garden
Reverse has got real slow, forward is slowing down to.
yea i know i did the trick i bought 2554 huq i have a lever shift i cut the platic on the reverse tp make it longer and it go much faster. now for floor pedal need make a bracket higher on pedal should make go down further and faster too.
Jul 30, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Hi, I have a Kubota T1760 ride on mower that has a problem with the transmission. The mower goes fine backwards but struggles forward. Sometimes it goes forward but lacks power. Most of the time it...
my kaboto had the same problem ,kaboto dealer quoted me $2500 to fixand so i attempted to fix it myself and did so for $6.50 and its working like a new one
Mar 10, 2011 | Garden
My T1760 blows white smoke for 60 sec when starting
it could be your choke stuck, but check you oil level and smell it does it smell like fuel. if so have your carb check out. Little lube on the chock lever. you may want to have your compression check and a leak down test done.
Oct 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
63 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
