Question about Garden
I have a 50" hydrostatic troybilt. It will not engage consistently. Have to fiddle with the knob several times before it will engage. When engaged, belt appears wobbly, perhaps loose? Tension issue?
  • Garden Master
  • 2,478 Answers
You hit it. If belt is wobbly it loose.
Posted on Apr 25, 2015
  • Anonymous Apr 25, 2015
    So, is there a simple way to adjust the tension? I didn't see anything in the manual about tightening the belt. Or do I need a new belt? This one didn't have many hous on it, but perhaps it was stretched when removed for the season?
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
  • 12 Answers
SOURCE: how to adjust belt tension 42" raftsman lawn tractor cutting deck
Note: This is about a different mower, but it might be similar enough to yours.  If not, please disregard.  Thanks!
I had a similar issue with our mower, a 2006 Troy-Bilt Pony model 13AN77TG766 (17.5 HP, 42 inch deck): when I pushed the handle down to engage the blades, it took a good ten seconds or so to start the blades turning; even then, they didn't have enough power to cut the grass.  And on any height setting lower than 5, they wouldn't turn at all.
The cause was on page 19 of the manual <URL:http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02243a.pdf>: Figure 17 shows the "PTO" cable attaching to a hole on the edge of the deck idler bracket, but it was shipped from the factory attached to a hole in the middle of the deck idler bracket, about 3 cm (1 in.) closer to the front end of the machine.  I reattached the cable to the original hole, and the belt is now good and tight; the blades engage as soon as I push the handle down.
Now, today, I'm having problems with the belt popping off the right-hand idler (hopefully just needs the deck stabiliser rod adjusting).
Always remember to remove the spark plug wire before you go near the blades; and watch for hot, sharp, and/or pinching surfaces.
Posted on May 19, 2009
  • 10865 Answers
SOURCE: I have a craftsman riding lawn mover 42" model #917270812
Hi Paul It sounds like the belt is worn, stretched, or possibly just two long for your machine. Save yourself a lot of aggrivation by checking your operator manual and getting exactly the right belt for your mower.
You don't say how old your machine is but if it has been mowing for many, many hours, the tensioning spring may need to be replaced. If that is the case you can order a new one at Sears.com
Posted on May 20, 2009
  • 41 Answers
SOURCE: blades not engaging
Tim, first turn key on engage and disengage blade button. See if you can hear the clutch making a clicking noise. If not check switch., if not your problem is in the clutch.
Posted on May 29, 2009
  • 95 Answers
SOURCE: craftsman 15.5hp 42'' changed hydrostatic fluid
Purge the transaxle by pulling the freewheel lever at the back of the transaxle.With the lever in the freewheel position run the engine full speed with clutch out,work the forward/reverse control back and forth 10 times and then try it.Also make sure that if you had the wheels of that you didn't lose a wheel key.
Posted on Aug 16, 2009
Testimonial: "Tried what you said now at least the wheels do turn a little. Gonna let it sit and see if i can purge it some more."
SimplictyYRZ01 hydrostats not engaging
The only thing the two hydrostatic drives have in common is a drive belt that ties them to the crankshaft. If both side quit at the same time that belt is most likely the problem.
Jul 09, 2016 | Garden
Heal lever won't press down to engage transmission on hydrostatic transmission
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - Hydro-Gear Transaxle:218-3010L I got this tractor as part of the deal when I ... After spraying the heck out of it and pressing the brake pedal down several ... I pull on the handle in the back and it moves the lever but still won't move. ..... while in the air and turning the wheels with the transmission engaged? mtd lawn tractor wont pull hills
Oct 18, 2009
briggs trouble
Jul 5, 2008
Peerless transaxle repair, Husqvarna mower
Oct 13, 2006
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Missing: heal
HYDROSTATIC TRANSMISSIONS - Small Engine Information
smallengineinformation.com/?page_id=370
Jan 14, 2016 | Garden
Troy bilt troubleshooting
what are you trying to troubleshoot? heres the troybilt link to get you started
http://www.troybilt.com/equipment/troybilt/lawn-mowers/lawn-mowers?facet=cas_f9_ntk_cs%253A%2522Zero%2bTurn%2bTractor%2522&sortBy=3?cm_mmc=Google-_-Mowers-_-Zero%20Turn-_-Sponsored&gclid=CjwKEAjwi6OeBRCCrZqp-qaQhhISJACrfbtAq_Hepy9R8IgJYw_E9HkmY0pum-PDxyoqjOrFfOWq-hoCAknw_wcB
Jul 17, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
How to turn park break on. I have a troybilt rzt mustang
If it is the same model I just purchased, to engage the parking break you simply push both handles out to the side. That's the only way I know to engage it.
Jun 15, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Snowblower problems
www.troybilt.com/equipment/troybilt/snow-throwers
Dec 15, 2013 | Garden
Pull start not turning engine. not engaging
www.troybilt.com/equipment/troybilt/ownercenter
Take it off and you will see a pawn(s) that stick out and engages the flywheel when the rope is pulled. You will also see why that is not happening. Stuck ,broken or stripped pawn maybe.
Aug 24, 2013 | Troy-Bilt 25cc 4-Cycle Straight-Shaft Gas...
I have Troy Hydrostatic 46" when I attempt to
If you lower the blade deck and get down near the mower, you can see the blades belt on top of the deck. If it is intact, with the engine off, have someone try to engage the blades. A tensioner should move into place to tighten the blades. If it is not, follow the engagement lever to under the dash to see if there is a cable broken or a rod detached.
Post back.
Gary
Sep 11, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
Troybilt Rototiller. Most likely the Pony model. Tiller is about 50 years old. Belt slips. I put on a new belt last year. Is there any adjustment of the pullies to tighten the belt?
On the engagement lever where it locks in.The lock block will wear on the bottom or the engagement lever gets bent.What we did was weld a brace to the engagement lever and maybe a little build up on the block where the wear is.
May 08, 2011 | Garden
Water/steam knob came out
Hi
If the whole steam valve and not just the knob came out you will have to remove the top.
Apr 17, 2009 | Starbucks Saeco Italia Digital Barista...
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
