Question about Protect A Bed P0135 Premium Waterproof Mattress Protector Queen with Water/Bedbug Proof Pillow Case 2 Pack Standard
Oxygene sensor - Protect A Bed P0135 Premium Waterproof Mattress Protector Queen with Water/Bedbug Proof Pillow Case 2 Pack Standard
    Top Expert:
  • 10,875 Answers
Protecters dont sense oxygen
Posted on Apr 25, 2015
2002 toyota avalon engine check light on P0078 and P007C
P0050 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 1)
P0053 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 1)
P0054 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 2)
P0055 HO2S Heated Oxygen Sensor -Resistance (Bank 1 Sensor 3)
P0056 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 2)
P0059 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 1)
P0060 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 2)
P0061 HO2S Heated Oxygen Sensor -Resistance (Bank 2 Sensor 3)
P0062 HO2S Heated Oxygen Sensor -Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heated Oxygen Sensor -Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heated Oxygen Sensor -Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector -Range/Performance
P0066 Air Assisted Injector -Circuit Malfunction or Circuit Low
P0067 Air Assisted Injector -Circuit High
P0068 (MAP) Manifold Absolute Pressure /(MAF) Mass Air Flow - Throttle Position
Correlation
P0069 (MAP) Manifold Absolute Pressure / (BARO)Barometric Pressure Correlation
P0070 Ambient/Outside Air Temperature Sensor -Circuit Malfunction
P0071 Ambient/Outside Air Temperature Sensor -Range/Performance Problem
P0072 Ambient/Outside Air Temperature Sensor -Circuit Low Input
P0073 Ambient/Outside Air Temperature Sensor -Circuit High Input
P0074 Ambient/Outside Air Temperature Sensor -Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit Malfunction (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit Malfunction (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake valve Control Solenoid Circuit Malfunction (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit Malfunction (Bank 2)
Mar 22, 2013 | 2002 Toyota Avalon
How do you change oxygen sensors on a 2000 hyundai sonata
Locate the two oxygen sensors on either side of the Sonata's catalytic converter on the exhaust manifold. The Sonata's oxygen sensor is gold and shaped liked a spark plug.
  • 2 Remove the Sonata's wiring harness from the end of the two oxygen sensors using your fingers. Do not damage the end of Sonata's wiring harness.
  • 3 Remove the two oxygen sensors from the Sonata's manifold using the oxygen sensor wrench.
  • 4 Apply the anti-seize compound to the threads of the Sonata's two new oxygen sensors.
  • 5 Install the two new oxygen sensors to the Sonata's manifold using the oxygen sensor wrench. Re-attach the wiring harness to the two new oxygen sensors using your fingers.
  • Oct 31, 2011 | 2000 Hyundai Sonata
    Location of oxygen sensor on 2004 blazer check engine light keeps coming on. Replaced sensor no change. At bank 1 sensor is not connected when tested.
    Removal & Installation
    Raise and support the vehicle.
    Support rear of the powertrain frame.
    Remove four rear frame bolts.
    Lower the frame no more than 73.2 mm (3 inches).
    Disconnect the rear oxygen sensor electrical connector.
    Remove the rear oxygen sensor from the rear exhaust manifold.
    To install:
    Install the rear oxygen sensor in the rear exhaust manifold. Tighten the rear heated oxygen sensor (HO2S) sensor to 41 Nm (30 ft. lbs.).
    Connect the rear oxygen sensor connector.
    Raise the frame.
    Install the four rear frame bolts. Tighten the frame bolts to 100 Nm (74 ft. lbs.).
    Lower the vehicle.
    Heated Oxygen Sensor Bank 1 Sensor 1 (HO2S 1/1)
    WARNING: Handle the oxygen sensors carefully in order to prevent damage to the component. Keep the electrical connector and the exhaust inlet end free of contaminants. Do not use cleaning solvents on the sensor. Do not drop or mishandle the sensor.
    CAUTION: Remove oxygen sensors with the engine temperature above 48C (120F). Otherwise the oxygen sensors may be difficult to remove.
    A special anti-seize compound is used on the oxygen sensor threads. New service sensors should already have the compound applied to the threads. Coat the threads of a reused sensor with anti-seize compound P/N 5613695 or equivalent.
    Fig. Showing the location of the HO2S Bank 1 Sensor 1
    Heated Oxygen Sensor Bank 1 Sensor 2 (HO2S 1/2)
    CAUTION
    WARNING: A special anti-seize compound is used on the oxygen sensor threads. New service sensors should already have the compound applied to the threads. Coat the threads of a reused sensor with anti-seize compound P/N 5613695 or equivalent.
    Fig. Showing the location of the HO2S Bank 1 Sensor 2
    Remove the heat shield.
    Disconnect the heated oxygen sensor electrical connector.
    Remove the heated oxygen sensor.
    To install:
    Install the heated oxygen sensor. Tighten the heated oxygen sensor (HO2S) to 41 Nm (30 ft. lbs.).
    Connect the heated oxygen sensor electrical connector. CAUTION
    Ensure connectors are securely installed beneath harness heat shield to prevent damage.
    Install the heat shield.
    Lower the vehicle.
    Heated Oxygen Sensor Bank 2 Sensor 1 (HO2S 2/1)
    CAUTION: Handle the oxygen sensors carefully in order to prevent damage to the component. Keep the electrical connector and the exhaust inlet end free of contaminants. Do not use cleaning solvents on the sensor. Do not drop or mishandle the sensor.
    Remove the air deflector.
    Disconnect the front oxygen sensor electrical connector.
    Remove the front oxygen sensor from the front exhaust manifold.
    Fig. Showing the location of the HO2S Bank 2 Sensor 1
    To install:
    Install the front oxygen sensor in the front exhaust manifold. Tighten the front HO2S sensor to 41 Nm (30 ft. lbs.).
    Connect the front oxygen sensor electrical connector.
    Install the air deflector.
    Lower the vehicle.
    Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
    Thank you for using Fixya, and have a nice day.
    Oct 12, 2011 | Cars & Trucks
    Where is the bank 1 sensor 1 o2 sensor located in a 2006 hyundai sontata gls v6?
    The bank has to do with which side of the engine. The 'Sensor 1' indicates that it is upstream of the catalytic converter.
    Heated Oxygen Sensor Removal & Installation Heated Oxygen Sensor (Front) (2.4L) hyundai-04-24-5822.gif
    Heated Oxygen Sensor (Bank 1/Sensor 1) (3.3L) kia-04-00-5213.gif
    Heated Oxygen Sensor (Bank 1/Sensor 2) (3.3L) kia-04-00-5214.gif
    Heated Oxygen Sensor (Bank 2/Sensor 1) (3.3L) kia-04-00-5215.gif
    Heated Oxygen Sensor (Bank 2/Sensor 2) (3.3L) hyundai-04-33-5855.gif
    Jan 13, 2011 | 2006 Hyundai Sonata
    Have a oxygen sencor and dont know were to put it in at thanks....
    WELL WHICH OXYGEN YOU REPLACING THE UPSTREAM OXYGEN SENSOR MOUNTED IN EXHAUST MANIFOLD AND THE DOWN STREAM OXYGEN SENSOR LOCATED IN THE EXHAUST SYSTEM AFTER THE CATALYTIC CONVERTER .YOU NEED A OXYGEN SENSOR SOCKET TO REMOVE IT.TO REMOVE OXYGEN SENSOR CRANK VECHICLE TO GET OXYGEN SENSOR HOT BECAUSE HARD TO REMOVE WHEN COLD.BECAREFUL DONT GET BURN ON EXHAUST MANIFOLD WHEN REMOVING OXYGEN SENSOR.AND WHEN INSTALLING NEW OXYGEN SENSOR USE ANTI SEIZE COMPOUND ON SENSOR THREADS.BUT MOST OF THE TIME NEW SENSOR WILL HAVE ANTI SEIZE COMPOUND ON IT.
    Dec 08, 2010 | 2002 Jaguar S-Type
    My 2003 Kia Optima check engine light keeps coming on. I was told "Bank 1 Sensor 1" needs to be replaced. Where is Bank 1 Sensor 1?
    P0130 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 1.
    P0131 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 1.
    P0132 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 1.
    P0133 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 1.
    P0134 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 1.
    P0135 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 1
    Jun 23, 2010 | 2003 Kia Optima
    My check engine light has come on in my 2006 Pontiac G6 after 2 and a half years. What could possibly be wrong since I keep my car serviced and the guys had just told me that my car was in tip top shape?
    P0016 - Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A
    P0030 - Heated Oxygen Sensor (H02S) Heater Control Circuit Bank 1 Sensor 1
    P0031 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 1
    P0032 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 1
    P0036 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
    P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2
    P0038 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 2
    P0050 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
    P0051 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 1
    P0052 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 1
    P0053 - HO2S Heater Resistance Bank 1 Sensor 1 (PCM)
    P0054 - HO2S Heater Resistance Bank 1 Sensor 2 (PCM)
    P0056 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
    P0057 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 2
    P0058 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 2
    P0068 - Throttle Body Airflow Performance (PCM)
    P0100 - MAF Sensor Circuit Insufficient Activity
    Jun 25, 2009 | 2006 Pontiac G6
    Oxygen sensor
    you need to borrow the oxygen sensor wrench from autozone or whereever you bought the sensor. Section 03-14: Engine Controls, Electronic 1996 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION -------------------------------------------------------------------------------- Heated Oxygen Sensor (HO2S) SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Oxygen Sensor Wrench T94P-9472-A Removal and Installation Disconnect battery ground cable (14301). Refer to Section 14-01 . On 3.0L (4V) engine remove cowl extension and right side of leaf screen. Disconnect engine control sensor wiring (12A581) from heated oxygen sensors (HO2S) (9F472). Do not remove harness connectors from the brackets. Raise vehicle on hoist. Refer to Section 00-02 . NOTE: If excessive force is needed to remove a heated oxygen sensor, lubricate the heated oxygen sensor with penetrating oil prior to removal. Remove heated oxygen sensors from exhaust manifolds (9430) using Oxygen Sensor Wrench T94P-9472-A. To install, reverse Removal procedure. Apply a coating of anti-sieze compound to threads of heated oxygen sensor. Tighten heated oxygen sensors to 34-46 Nm (26-34 lb-ft).
    Jun 13, 2009 | 1996 Ford Taurus
    How do you replace the oxygen sensors on a 1995 merc sable with a 3.0 ltr motor
    they just unscrew from the exhaust pipe.
    1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
    1. On 3.0L (4V) engine remove cowl extension and right side of leaf screen.
    1. Disconnect engine control sensor wiring (12A581) from heated oxygen sensors (HO2S) (9F472). Do not remove harness connectors from the brackets.
    1. Raise vehicle on hoist. Refer to Section 00-02 .
    1. NOTE: If excessive force is needed to remove a heated oxygen sensor, lubricate the heated oxygen sensor with penetrating oil prior to removal.
    1. To install, reverse Removal procedure. Apply a coating of anti-sieze compound to threads of heated oxygen sensor. Tighten heated oxygen sensors to 34-46 Nm (26-34 lb-ft).
      Heated Oxygen Sensors—3.0L (4V) Engine
    May 02, 2009 | 1995 Mercury Sable
    O2 Sensor on a 1996 Cadillac Eldorado
    Hello mrsalbert, my name is JShreader. Thank you for choosing fixya.com
    Depending on which oxygen sensor you are looking for...there are several of them throughout the Exhaust System. I will start out by giving you a brief description of what and oxygen sensor is, and they're general purpose.
    DESCRIPTION
    Four Heated Oxygen Sensors (HO2S) are mounted in the exhaust system where they monitor the oxygen content in the exhaust stream. There is an oxygen sensor mounted in each exhaust manifold and one on each end of the catalytic converter. the oxygen sensor located in the front exhaust manifold is the Bank 2 Sensor 1 (Front) sensor. The oxygen sensor located in the rear exhaust manifold is the Bank 1 Sensor 1 (Rear) sensor. The oxygen sensor located in the Y-pipe ahead of the catalytic converter is the Bank 1 Sensor 2 (Pre-converter) sensor. The oxygen sensor located in the catalytic converter outlet is the Bank 1 Sensor 3 (Post-converter) sensor.
    OPERATION
    An oxygen sensor acts like a battery because it creates its own signal voltage once it reaches operating temperature. This voltage is produced when the oxygen content in the exhaust stream is different than the oxygen content in the atmosphere. A lean condition (high oxygen content in exhaust) will produce a low voltage (near 0 volts) and a rich condition (low oxygen content in exhaust) will produce a high voltage (near one volt). The PCM provides a reference signal voltage (0.45 volt) and a ground to the sensor. The PCM reference voltage is necessary because the oxygen sensors do not provide their own voltage until they reach operating temperature.
    HEATING ELEMENT
    the oxygen sensors also incorporate a heating element inside of the sensor housing. This heating element is energized with the ignition On and allows the sensors to reach operating temperatures quickly. The PCM can then use oxygen sensor information sooner after engine start-up.
    PCM INPUTS
    The PCM uses oxygen sensor information during Closed Loop operation to constantly adjust fuel control to reduce exhaust emissions. Because the oxygen sensors provide information sooner after engine start-up, exhaust emissions are reduced. Faulty oxygen sensors will cause various driveability conditions and will set a DTC.
    That being said...I uploaded a .pdf for you of pictures showing the locations of ALL the oxygen Sensors on your Vehicle. You can download it by clicking HERE.
    I hope this helps you. If you have any more questions or need any more diagrams, please don't hesitate to ask...Thanks again, JShreader!
    Apr 01, 2009 | 1996 Cadillac Eldorado
    Protect A Bed P0135 Premium Waterproof Mattress Protector Queen with Water/Bedbug Proof Pillow Case 2 Pack Standard Logo
    966 people viewed this question
    Top Protect A Bed Home Experts
    john h
    Tom Chichester
    Are you a Protect A Bed Home Expert? Answer questions, earn points and help others
