Question about Rinnai Heating & Cooling
The heater is not igniting when switched on - Rinnai Heating & Cooling
ITS A MASTER TORPEDO HEATER 165,000 BTU
Posted on Jan 07, 2016
What model what type of heater
its ok to mention not working
but more info please on the fault
the maker model type issue
then we can find you more details and manuals etc...
Posted on Apr 25, 2015
I have a el/gas water heater with ign. switch in cabin switch does not come on when WH does not ignite also the cabin heater doesn't ignite either, are both ign. units normally on same circuit ?
I would start with the thermocoupler that is or usually located behind a removable panel on the WH and check the other items for one also.
Dec 04, 2015 | Cars & Trucks
BernzOmatich3200n
Repairing Benzomatic Patio Heater
The above link unfortunately states Benzomatic no longer provides parts for their patio heaters. There may be a comparable generic part out here that you can substitue for the original part.
Tall Propane Patio Heater Starting Striker Switch
The second link shows an igniter switch that may work. You can find other possiilities by doing a search on the web for" Propane Heater igniter switch"
May 16, 2014 | Stainless Patio Heaters - Steel Deluxe...
Both front and rear heater fans don't work, mechanic says it is an ignition switch?
Both "blower" fuses are fed by the ignition switch. If there is no power to those fuses than the switch is the likely problem.
Jan 22, 2013 | 2005 Chevrolet Venture
2002 kia spectra color code ignition switch diagram pdf
PART COLOR LOCATION 12 VOLT CONSTANT WHITE/BLACK (+) and WHITE (+) IGNITION SWITCH HARNESS STARTER RED (+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 YELLOW (+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 BLUE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 GREEN (+) IGNITION SWITCH HARNESS
Dec 27, 2011 | 2002 Kia Spectra
The heater is showing me ac, and is not letting my heater to light up
its either a bad vaccum switch that is closed and cant open or its a ignition control module or (fenwall) not sending power for it to open open panel and slide down cover there is two round black saucer looking switches replace them or jump them by connecting wire to both leads bypassing the switch if heater turns on need vaccum switch if not ignition control module
Jan 24, 2011 | Hayward 400fdn Low Nox Nat Gas Swimming...
I have a G6A-7E electronic ignite water heater.
Make sure propane is on and getting to your stove burners ok, first, then try switching it back on. If it fails to ignite, shut switch off and try a couple of times, if still no ignition, get back to me.
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
LO service message
LO is ignition lockout. The heater has tried to fire three times without success. It is usually the prressure switch but can also be the temp limit switch or the vent pressure switch. Locate and jump one at a time to find faulty switch.
Aug 15, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool Heater
You can light the pilot with a B.B.Q. lighter.
Nottoohandy. Backwash you filter, make sure it's really clean. If that doesn't work it could be the pressure switch. You can by-pass the switch with a piece of wire to see if it fires up. If it does, it's the switch. There is a picture of the switch in the manual.
C
May 20, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
95 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
