Question about Philips SRP1103/27 Universal Remote Control featuring Simple Setup Black
Vol button does not working, pushed button more 15 minuts but not working
If its a uni
try to re enter the code
if not try a £1 uni remote from the £1 shop
works a charm for me...
Posted on Apr 25, 2015
  • Philips Master
  • 5,631 Answers
If it is a Universal Remote, probably you are not using the proper code If there is no better code, try to follow the procedur for inexistent code. If still you won't get a workable code, you have three option:
- Buy the original remote
- Buy another universal remote of some other brans and check if works
- Live with corrent, accespting that you can't modify the volume.
It will not reset when you push the reset button.
don't know what tablet you are talking about, but on most you need to hold it down for 10-15 seconds. and on some you hold down power button and vol + at same time for 10-15 secs. on iPad hold down center button and power button for 10=15 secs.
Mar 27, 2015 | Tablets & eReaders
Why won't my tablet turn on?
I had same issue, it is some sort of glitch in either the mfg or the software. Keep trying but try not to be to forceful with the buttons. I sometimes have to push it over 30 times to get a result. a lot of the time i will just plug it in walk away and they come back about 5 or 10 minutes later and try again. Try different button sequences. Hold down power for 30 seconds remove and add your external SD cards. Hold power and push vol down. Hold power and push vol up. various sequences with plugging in charger as well. I know it is very frustrating but try not to lose your temper with it. Good luck.
Aug 02, 2014 | ASUS MeMO Pad HD 7
I don't know how to set the clock for a MA4203 model
I couldn't find the information for your particular model, but I did figure out the general procedure for Memorex alarm clocks currently in production:
  1. Make sure power is turned off (no radio or whatever playing). Press the Time Set button (on some models, this is the Skip Search Back button for an iPod docked in the unit).
  2. When the display blinks (on one model, the volume control knob lights up), press the Hour button (Vol. -) to set the hour, then press the Minutes button (Vol. +) to set the minutes. On the model with the light-up volume control, rotate the volume control knob to set the time.
  3. When you have the time set, either wait 15 seconds or press the Time Set button again to start the clock.
Setting the alarm works the same way on single alarm models, but the Alarm Set button may be the Skip Search Forward button. Dual alarm models have separate Alarm A and Alarm B buttons.
Feb 05, 2011 | Memorex Audio Players & Recorders
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
How to set clock
go in to the menu by holding the button down for a second. find the clock adjust, put in the correct time. if you make a mistake repeat steps till you get it correct.
Sep 19, 2010 | Kenwood KDC-MP235 CD Player
Clock settings
For the mp235... the manual wasn't accurate. See below...
To set the clock, push the source button until you're in standby mode. Hold the left knob down (volume ctrl) until menu comes up. Either push the left knob OR move the right up or down (can't remember which) until you see Clk Adj. Push the vol ctrl knob (I think). Then, the knob on the right goes left right for minutes/hours, and up/down for the other. I believe you can push the vol knob then once its set.
Jun 20, 2010 | Kenwood KDC-MP205 CD Player
How to increase volume
To change the ringer volume: while the phone is on the hook press the Vol + or Vol - button. The phone rings according to the current setting. Tap the Vol + or Vol - button to adjust the volume one setting at a time. The phone stores the setting after the last button press.
To change the speakerphone, handset, and headset volume: while the phone is in use in the desired mode, press the Vol + or Vol - button. The phone stores the setting after the last button press.
The above is from pages 14-15 of the manual at
http://www.rca4business.com/products/pc/pdf/instruction-book/25424RE1.pdf
Jun 11, 2010 | General Electric RCA-25424RE1 4-Line...
Parental lock code has been lost how can i unlock and reset code
Without a model number I'll have to list several solutions.
Push Vol Down and Chan Up on the set at the same time, Then go to password screen and enter 0000.
Reduce Vol to minimum and hold Vol Down on set and Vol Down on remote.
Hold Vol Down on TV while pushing "TV" button on remote for 3 seconds.
With TV OFF, press and hold Vol Down on TV and "Clear" on remote for five (5) seconds.
Press "Menu" button on TV and "TV" button on remote for 3 seconds.
Some models use the Vol Down button on remote instead of "TV" button on remote.
With Remote go to Parental Menu and enter 2211 for code.
Go to parental Menu and press Mute, Display, Clear, Reset in sequence on the Remote.
Press "Menu" button on the set and Vol Down on Remote for 3 to 5 seconds.
With remote go to parental screen and press Chan Up and Vol Up on the front of set for 3 to 5 seconds.
Jun 05, 2010 | RCA DRD485RG DirecTV DTV Receiver
I need to learn to reset the time on my Sharp Remote Control Watch
It's a 3 step process, which I discovered by trial & error:
1. Push the top Vol. Button
2. Push the Sel. Button. The hour number should start flashing.
3. Push the lower ch. button, each push will advance the hour setting by one hour. Repeat until you have the desired hour. That's all I needed to do, but repushing the Sel. button should highlight the minutes setting and the lower ch. button will advance the minutes as well.
Chris Hee
Nov 05, 2009 | Watches
I have a panasonic model pt-52lcx15 and replaced the lamp part # ty-la1000. It works fine but I can't figure out how to reset the timer, do you have instructions for this, they weren't included with the...
Hi, I have the fix for you....EXIT out of the message telling you to reset you meter. Now you need to push the - vol (neg vol) button on you set, at the same time push the split button on your remote (very bottom of the remote is the split button with the vcr controles) You need to push these at the same time for 20 or more seconds and you will recieve a message that the metter has been reset. Exit out of that message and all should be fine. Took me about 15 minutes to get to a tech to walk me through it.
Jan 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Philips SRP1103/27 Universal Remote Control featuring Simple Setup Black Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
