Question about Canon imageCLASS MF8180C All-In-One Laser Printer
Check printer open and close cover - Canon imageCLASS MF8180C All-In-One Laser Printer
    Sergeant:
  • 268 Answers
A general error message asking you to open the cover over the glass (usually) and check for something in the paper path or on the glass. This message is usually covered in the user manual for the printer. Make sure the cover is completely back down and/or latched before hitting the print button.
Posted on Apr 25, 2015
Check printer cover mesage
Open that cover and close it using some force is quick and the costumer can do it also.
The perfect solution for a technician:
The machine detects the opening of the lower door on the left side (under the manual tray) as a cover open. There is one sensor for paper jam and cover open. If the lower right door is open, the photointerruptor is free. If you close the right lower inner door, it is blocked, and when it is closed, and there is a paper in this section the sensor is free. Sometimes the edge of lower inner door doesn't makes the sensor moving, insted of crushes up. Then a little amount of grease can help you.
See attachment:
Nov 07, 2012 | Canon imageRUNNER 1600 Laser Printer
Message says COVER OPEN CLOSE COVER but the cover is closed
The problem could be due to the printer cover sensor getting stuck or the cartridges in the carrier. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
2. Open the printer cover and remove both the cartridges.
3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power source to reset it.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for errors.
8. If no error appearsl, open the printer cover and reinsert the other cartridge. Check for errors.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
10. Load some paper. Try to print again.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 11, 2011 | Lexmark X125 All-In-One InkJet Printer
It shows "remove any obstruction
Open the printer cover and access the cartridge area. Remove both cartridges. While the cover is open, check for any obstructions in the cartridge carrier's path. Check for any loose transparent strip (encoder strip). If cartridge area clear from these, Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, open the printer cover and reinsert the cartridges. Close the cover and try to print again.
May 27, 2011 | Lexmark X4650 InkJet Printer
Open the top cover and insert a toner cartridge. message shows when i try to print but top cover already closed properly
check on the left hand side of where the top cover opens , in the inside there is a clip along with a senor
check that it si not stuck . if that doesn't work, open the top cover hold in the cancel button or the bigger play button ( differs printer to printer ) or both for approx 10 - 20 seconds , you will see all the lights flash remove the toner , re-insert the toner & close the top cover . This will reset the drum unit & the printer status. Alternativly switch the printer off ( with top cover closed ) hold in one or both buttons and turn it on for approx 10 - 20 seconds again , you will again see all the lights flash, Your printer will reset its status And clear its page count .
also try open the back cover close the front then the back , press cancel or play button twice there after.
( this is a common diagnostic procedure with small laser printers )\
Please post back if this doent solve the issue
Thanx
May 27, 2011 | Canon LASER SHOT LBP-2900 Printer
Close printer cover error when cover is closed
The cover sensor might have dislodged or not in its proper position. You could try to reset your printer to determine if there's a hardware fault. Remove the cartridges from your printer. Close the cover. Unplug and replug your printer into the power source. When the printer turns on completely, reinsert your cartridges. Check if error appears again. (Error: 'Cover open, please close the cover')
Feb 17, 2011 | Lexmark X2250 All-In-One InkJet Printer
Front and rear cover open but all covers are closed
hello check again properly.i think front cover is open
if you replace toner and didnt close front cover properly or you open it and didnt close properly.
Sep 09, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Says can't print because top cover open when it's not. Tried resetting by pulling plug, re-opening and closing top cover.
this is the common problem of 5150 printer .you just open the top cover ,in your right hand you can see a black moving part it may not working properly. try to move back and forth many time ,then close and check your printer.
Feb 12, 2010 | HP DeskJet 5150 InkJet Printer
Where is the Printer Cover on the Canon Fax 8500? The fax is asking to Check the Printer Cover.
The printer cover is the cover that you open to remove the cartridge. Open it and check that the cartridge is inserted correctly. Remove and reinsert cartridge then close the cover. Check all around the m/c to make sure all doors are closed.
Sep 24, 2009 | Canon FAXPHONE L80 Laser
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Epsom C1100
cover "B" should be on the back of the printer. when you open the main back door at the bottom there is a little flap that will fall down, this is a sliht design flaw as you have to make sure that this is in an upright position before closing the main back door. from past experience its usualy hit and miss at getting it to work unfortunatly
hope this hepls
Pete
Sep 28, 2008 | Epson Aculaser C1100 Printer
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
81 people viewed this question
old marine
old marine
