Question about Samsung Refrigerators
I have Unplugged the power,cleaned the freezer, plugged back the power, now control panel flashing 33 E and non of the buttons is functioning. How to fix it Thanks, Samsung refrigerator RF323TEDBSR
  • Anonymous Apr 26, 2015
    I let the refrigerator to work with that error of 33E overnight and this morning the error was gone. Thanks AR
You may find the blast chiller fan has an issue
perhaps its failed... causing only the bottom of the freezer to go frozen or worse...
its inside the panel at the back of the freezer unit 6 screws and perhaps some plastic caps on them
the plastic caps may be the fixings so take them out carefully
you can take the panel off check its not jammed with ice and the blade moves/spins freely
if its not moving mostly its gone...
or hard to move the vanes then its sized up bearings
if you cant hear it wiring anyway..
try to leave the freezer etc off for several days with the door open
can take like 10 days to fully clear out the ice from inside tubes etc {not good}
inside the back of fridge freezers apart from the fan
is a fast heat element for frost free and fast defrost and freeze
so all must work and be clean
at the base of the back unit is a V shaped channel that takes away the water from the freezer blast unit
so if the tube at the bottom of the V shape inside the back cover gets blocked
water builds up and it will never defrost properly for less than 5 or 6 days then freeze up fast
as the water sits in the back cover
so
to solve it you need to
take the 6 screws out the freezer back plate
ease it off and then clean out and fully defrost the freezer unit
watch out for any sensors mounted to this freezer panel
and the V channels in the fridge and freezer with pipe cleaner brushes from the local home brew shop and salt
and add some salt too the V channels and pipes
they lead to the evaporator tray mounted above the warm compressor so as to get rid of water from iside
but they only work till too much ice builds up
and your defrost ritual goes like past 3 months or 6 months for a 3 star freezer
so you need to do the above
then test again
make sure of good clearance and clean the back out 4 " off the wall
sometimes !! there is a thermal fuse on the heating element of the freezer inside the back panel unit of upright freezers
the scenario is the fan goes the heating element overheats the thermal fuse goes
and the freezer reports an error
you may find you have to replace the fan and thermal fuse ...
and a really good clean of the V channel and pipes and evaporator
and move it off the wall
hey presto
so some food for thought...
most often just a clean
and perhaps a new fan
most often it just gums up the tubes and defrost not too often
then the fan jams
perhaps burns
if you find you cant find the exact fan
just use a universal fan type from ebay etc
about a 10 er or less and do some metal work too fit it
ive done this with over 10 units
and now they work magic
usually its the fan that fails and an ice monster grows
and the freezer packs in
and perhaps the heating fuse goes
so ... this is the issue for sure
Posted on Apr 25, 2015
  • Samsung Master
  • 2,355 Answers
On a Samsung Refrigerator model , press and hold both "Power Freeze" and "Power Cool" buttons simultaneously until chimes sound. This will reset the flashing 13 E code.
We have a Samsung RS2534WW Refrigerator and this morning the freezer stopped working.
Hi!
This is what the manual says:
The refrigerator does not work at all or it does not
chill sufficiently
Check that the power plug is properly connected.
Is the temperature control on the display panel set to
the correct temperature? Try setting it to a lower tem-
perature.
Is the refrigerator in direct sunlight or located near a
heat source?
• Is the back of the refrigerator too close to the wall?
I'm adding a link to the manual. Hopefully, it will help :) http://manualsbrain.com/en/manuals/947955/?page=29
Jul 17, 2017 | Samsung Refrigerators
Dear Sir, I have Unplugged the power,cleaned the freezer, plugged back the power, now control panel flashing 33 E and non of the buttons is functioning. How to fix it Thanks
What brand and model washer do you have? The E33 error could be a problem with the low-water level pressure switch. On some Zanussi washers, the problem could be at the control circuit board. You'll need to check the wiring (resistance). A visual inspection might reveal soot or another sign of a failed component.
Please add a comment with more information to get specific diagnostic and part suggestions.
Apr 25, 2015 | Washing Machines
My Kenmore Upright Freezer Model 25326432100 flashed "ER."
My freezer was purchased in February, 2004. It is a self defrosting freezer but ice has started forming along the bottom shelf and back wall. Also, after cleaning the freezer the other day it has stopped clycing. The freezer will stop running only if I turn it down to the #1 setting and then it will not come back on. If I turn it up to a higher setting the compressor will not stop running. It ran for over 24 hours and would not cycle unless I turned it off or set it at the #1 setting. When I unplugged it and pulled it away from the wall, there was a green water spot the size of a dinner plate underneath the freezer. Help!! Very Unhappy this freezer is only 6 years old. S in Phila.
May 31, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
I have a frigidaire upright frost free freezer model number is FFU2065FW3 I put in a new electronic temperature control Board and when I plugged the freezer back in, the control board was flashing "E" and...
OK, this is a failed controller board, any E4* is Power supply & Controller Board, probably caused by a power spike.You need to get the unit looked at to see if it is able to be repaired, and if parts are available. If you wish to try and repair this yourself, you must get a service manual, to do so, and to be able to order parts.
Apr 03, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
Washer stuck
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 01, 2009 | Kenmore 42822 Front Load Washer
Control panel locked light is on
ck for a button with hold to lock under it hold button 3-5 sec
Jul 02, 2008 | Whirlpool GEW9250 Electric Dryer
Fedders window model A6Y12F2B "New Unit",,only 10 days in use! Just stopped working No Power To Master Panel Air Conditioner Not Working Fuse Panel/Breaker ok,Outlet ok,,power to plug...
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Jun 22, 2008 | Fedders Heating & Cooling
Refrigerators Logo
111 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
