Question about Samsung Televison & Video
Help fixing a discoloration of my screen on 46in. samsung a550 it looks like solarisation but dont feel thats an adequate a summation. ...the whites are pink/red and blacks appear blue
  • Samsung Master
  • 716 Answers
Hi Brandon,
Looks like a case of bad TCon board. Please consult some good TV Tech.
Posted on May 07, 2015
johnny5846
  • 379 Answers
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Posted on Jan 10, 2009
emissionwiz
  • 78238 Answers
SOURCE: I'm having trouble installing a radio in my 1992 toyota celica
go to any auto parts store and ask for a 12 volt test light, it has a bulb inside and a pointed end like an ice pick, u attach one end to a good ground and then probe wires for power, when u have a hot wire with 12 volts the light in the handle will shine on. They cost about $6.00 at Kragen I think.
Posted on May 12, 2009
smartr10U
  • 1305 Answers
SOURCE: need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
Posted on May 31, 2009
michael_grey
  • 365 Answers
SOURCE: Need Wiring Diagram For 1984 Mercury Grand Marquis Raido
Posted on Aug 06, 2009
marshalljc
  • 51 Answers
SOURCE: I have a Hopkins Brake Control the pigtail colors
1. connect the red wire to the stop lamp switch lead on the brake control. Connect the other end of red wire to the stop lamp switch in the vehicle using the splice connector
2. connect the blue wire to the trailer brake lead on the brake control. Route the other end of the blue wire to the trailer connector at the back of the vehicle.
3. connect the white wire to the ground lead on the brake control. Route the other end of the white
wire to the vehicle’s battery. Use the ring connector to connect the white wire to the battery’s negative terminal.
4. connect the black wire to the power lead on the brake control. Route the other end of the black wire to the vehicle’s battery. Use the fuse assembly to connect the black wire to the battery’s positive terminal.
Posted on Oct 22, 2009
Sony a550 white balance
Do you try to set the white balance, wheel the camera is still in an automatic mode or in a scene mode?, because that won't work. If you keep having problems while in a manual mode, let us know, so I can look again to this problem.
Mar 19, 2014 | Sony DSLR-A550 Digital Camera
Tip
Hi. I just got my samsung syncmaster 920nw less than 6 months ago, and now i...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Jan 03, 2009 | Sony SDM-HS73P 17" LCD Monitor
CRACKED 46inch LCD SCREEN
you can find replacement panels but expect to pay $250 plus for one. You will need to take the back cover off the set and get the panel model # off the back of the panel. There should be a white sticker on the back of the panel stating the model #. You will need to get a replacement panel that matches your model # EXACTLY
Oct 13, 2012 | Sharp Televison & Video
Haze cloud picture that cut people head off...
the picture sounds like its blooming, you must turn down the screen control on the back of the fly-back transformer, or the transformer has gone defective more likely and needs replacing
Jan 27, 2010 | Televison & Video
Flickering screen
Two models of the 46 inch Sony Bravia have a screen flicker problem. On my 2008 model, starting from cold, it lasts for 5-10 min, on LHS of screen. The Telefix tech who visited said this is common with these models (46in only), a new panel is needed. Sony provides warranty on this fault for 3 yrs, so you do not need extended warranty to claim. Discuss your case with Sony or Telefix.
Jan 03, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
When I flip my Sony Ericsson W300i's up. The
thers summat wrong wit da ribbon cable u cant get dat fixed if u did it wud cost quite a bit happened to my phone
Apr 22, 2009 | Sony Ericsson W300 Cellular Phone
Samsung SPH-M300 display screen is white
your screen is broke you need a new one or buy a new phone the same thing happen to me with the same phone and it cant be fixed
Mar 14, 2009 | Samsung SPH-M300 Cellular Phone
Televison & Video Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
