Question about Garden
What is the square thing on my yt3600 yamaha riding mower it has fuel line going from gas tank to box and from box to carbureter
  • Garden Master
  • 2,478 Answers
Its your fuel pump or a fuel filter
Posted on Apr 25, 2015
5 Suggested Answers
SOURCE: GAS LEAKING OUT OF TANK INTO CRANKCASE IN A RIDING MOWER
Gas in the oil usually means the carburetor float is to high or the float is sticking. Hope this is of some help. donnyb60
Posted on Mar 21, 2009
  • 376 Answers
SOURCE: Poulan ride on lawn mower will not run by itself--if you pour gas into the intake it will run until the sm amt runs out
It could be your fuel shutoff solenoid is not working or is stuck from gum, varnish or rust in your carb bowl. The fuel shutoff solenoid is located on the bottom of your carburetor. To check it, have someone, or yourself if you can reach the ignition switch, turn the key to the on position and back off several times while you listen by the carb. You should hear a click each time. If not, the carb will have to be taken off and cleaned and checked. You will probably find water and/or rust in your bowl plugging up the main jet. Best to take it to a shop.
Posted on May 16, 2009
  • 218 Answers
SOURCE: Mower won't start
Hi..my name is Keith and some mowers do have a fuel pump..if the fuel tank is lower than the carb...and they are operated by vacuum thats created in the crankcase and they are usually located on the carb...but i would check to see if some trash didnt stop up your fuel line..also..if you have old gas in it..a lawn mower engine doesnt or wont run on it..i hope this has helped..if not..write me back
Posted on Jul 01, 2009
  • 138 Answers
SOURCE: craftsman riding mower shuts off after approx 20 mins of use.
ran into this problem twice this season, about drove me crazy - finally traced the problem to the anti-backfire solenoid [the little cylinder at the bottom of the carburetor that holds the float bowl on] - after running fine for 20 minutes or so [it varied], the coil would release the plunger and shut off the gas flow. as soon as you turned off the key and turned it back on, it would start back up - replace the solenoid and problem vanished
Posted on Aug 17, 2009
I have a murray riding mower, 10hp, 30'' I filled my gas tank and 2 days later the gas was gone. but I did not see a leak. in the tank
check to see if gas running out of carberator also check your oil make sure gas is not in there if it is or fuel running out of carb replace needle and seat in carb check for cracked seam on gas tank also make sure fuel line not leaking
Sep 15, 2014 | Garden
Xl 1000 manual
look on the front of the carburetor and see is there a square cover with 4 screws I think you should have something look a digram gasket that is the fuel pump it need to be replace make sure the fuel line is not kink or bent.
Aug 11, 2014 | Craftsman Garden
Why am I leaking gas from somewhere under my tank?
Well...A fuel line may have split due to heat, Or a bad clamp on the filter or fuel valve, If it carbureted, then You may have a leaky fuel bowl gasket/ Stuck float/bad float/or a out of adjustment float.
Oct 24, 2013 | Yamaha YZF-R1 Motorcycles
What fluid is used for the Hydrastatic transmission on a Yamaha YT3600
best advice is to contact the dealer and ask for the type of oil you are to use.
Apr 21, 2013 | Cars & Trucks
My mower seems to have low fuel pressure. Gas filter is new, lines are clear but sometimes the engine starves for fuel. The filter has almost no gas showing in the clear globe when running. Is the black...
Yes it is a vacuum fuel pump. Remove the line to the carburetor and place a clear container to catch fuel. Crank the engine and watch to see how much fuel is being pumped. It could either be a weak fuel pump or the pickup line in the fuel tank is starting to rot, depends on how old the mower is. The pickup line in the fuel tank is rubber, and sitting in fuel for many years can break the line down causing it to fall apart. It should be noticeable more if the fuel tank is below 1/2 tank. Hope this helps, Daniel.
Jul 04, 2011 | John Deere 22HP Hydrostatic 42" Riding...
How to repair a gas line on a sst18 john deere lawn mower
make sure the tank is empty and then remove the clamps holding the line on the tank and the carb take the whole thing with you to service center and ask for a direct replacement for your fuel line (may also include a fuel filter)...good luck
Apr 07, 2010 | John Deere Air Cleaner Bowl For Tractors
21hp Vtwin riding mower quits after it runs out about one half tank of gas and the outside temp is hot (90) degrees. Filling the tank I can then start the engine and it rus ok. What is going on?
THE V-TWINS HAVE AN EXTERNAL FUEL PUMP AND IS GRAVITY FED FROM THE TANK TO THE PUMP. MAKE SURE THE FUEL LINE IS IN GOOD SHAPE AND THE FUEL LINES ARE BELOW THE FUEL TANK LEVEL ANT TIME THE FUEL LINE GETS ABOVE THE FUEL LEVEL IN THE TANK FUEL WILL STOP FLOWING TO THE FUEL PUMP CAUSING THIS PROBLEM
Aug 10, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
