Question about Dryers
I have a becCo senser dryer I paused the button today and it won't come back on any suggestions what I can do
    Sergeant:
  • Dryers Expert
  • 448 Answers
Did you try opening and close door some will not start till door was open and closed once Or unplug wait 2 min plug back in should reset if not board interface or control board stuck button
model # AGE ? needed to get better details
Posted on Apr 25, 2015
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Jan 03, 2016 | Fisher and Paykel Dryers
Dryer is stuck on paused and won't spin. Turned off and re-started but the motor ran for a few seconds and then went to paused again.
Good Morning Jill,
So I see that you were drying bath mats and the dryer got stuck in a "Pause" mode and even if you cancel and restart it shows "Pause" on the display. I would suggest resetting the dryer. What you will need to do is either unplug it or you can shut the power off at the circuit breaker. When you do this you will need to leave it off for at least 2-3 minutes. Cut the power back on, start any cycle. If you are still having trouble not being able to start the dryer and "Pause" showing, I suggest you either contact the manufacturer or your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Mar 25, 2014 | Electrolux Dryers
My frigidaire dyer comes on then the pause message appears. These are new appliances.
Hello barbarada180 - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Jan 02, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
My dryer is locked and I have a tub full of wet clothes. Sorry, can't find the manual how to fix.
If it's your washer that is locked, the manual suggests you press the START/PAUSE/UNLOCK button. It says the lid will unlock once the washer movement stops and it might take several minutes if it was spinning at a high speed. You can resume the cycle by pushing the Start/pause/unlock button again.
I really hope this is the answer you need. There is nothing more frustrating than a load of wet laundry. If this helps, please come back to Fixya and rate my advice. Thanks and good luck!
Jul 29, 2011 | Whirlpool Dryers
Turned on Dryer today; problem; Estimated time remaining window shows CL (no time) Non of the time buttons selected show time in window. Dryer runs forever; gets hot and drys clothes. Pause button does...
The Child Lock feature is activated and it can be deactivated by pressing and holding the DRY LEVEL button for 3 seconds or until the CL display is cleared.
Indicate the exact model number of the dryer if the control panel doesn't look like the one shown above or if no button with the small "PRESS & HOLD 3 SEC TO SET CHILD LOCK" (DRY LEVEL) marking is found.
Mar 06, 2011 | LG DLE2514 Electric Dryer
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool electric dryer
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
