While painting, a red wire came off. Why doesn't it work now?
    Sergeant:
  • 406 Answers
Try to figure where the wire connects...they are usually formed for a direct connection...follow it and search for a connector it will most likely show some brightness from being connected..good luck..
Posted on Apr 25, 2015
Old elec. wiring is showing verdigris ( grease ) on the plaster surface! what do I seal the surface before painting?
ask your "local paint store" manager first...
if they do not know, I suggest washing down the wall, scratching it lightly with sandpaper after it is dry, then apply an alcohol based primer to seal the grease. I would then prime with a good latex primer before final coating. If you are painting pastels, or very dark colors (red, Blue, Black), tint the primer toi as close to the color you want.
Good luck
Neil
Sep 23, 2014 | Tools & Hardware - Others
So. I took the Body cover off My New Bright Wolf Pro R/C Truck And The Red and Yello Wires came out the back, I thought they went to the motor, but they dont.. They go to a sencer of some kind for the...
The sensor is a resistive load sensor. The resistance changes as the motor gets hot. Solder the wires back onto the board and whilst keeping the model off of the ground, put it into drive mode. If it doesn't go, then wet your finger and bridge the two solder points on the sensor. Don't worry, you will not get any electric shock as the voltage and current are too low.
If it still doesn't drive, then wiggle the motor wiring at the motor. If still nothing, then press lightly on that sensor pcb. There may be a broken track on it. If it is broken, then you cannot solder it. You then need to go to Maplins (if in the UK) and buy a small bottle of pure silver paint. Where the solder points meet the circuit resistive track (it'll be black carbon looking), paint one blob of silver conductive paint onto each of the track beginnings. Let those dry (five minutes) and then try it. It should work. The silver paint will only work if the wet finger trick on the black carbon track works. If no carbon track, then it may be a thermal resistor (thermistor). Replace it. Maplin sells them too, so just buy a few different types (very cheap) and temporarily solder one in place until it works.
Aug 19, 2013 | New Bright Remote Control 1:12 Scale Pro...
Thermostat doesn't activate unit
Put a volt meter on the red wire and the C terminal. You should get 24 volts AC. If not then the control transformer is shot
Jan 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a Kenwood kdc bt945u and it installed correctly to my knowledge but doesn't work. At all. I used a voltmeter and I'm getting power from my battery. I plug the constant from the battery into...
the yellow wire or BATT wire goes to the battery,,
the red wire goes to the ignition
the black wire goes to the ground.
to find these on your old car harness use the volt meter, The batt wire will have power with the keys out the ignition (only one to do so) the red will have power only when the ignition is off,,
for the black use a metal part of the car's body scrape off some paint, a part with a bolt will do fine.
the reason its spits the cd out is cause its not hooked up right.
Dec 29, 2012 | Car Audio & Video
How to clean a clogged belt sander
I assume you mean you want to clean the belt itself? You can use a rubber stick made for this. It looks and smells like a giant pencil eraser, about 1 inch square and about 10 inches long. However, if the belt is clogged with melted paint, that won't do much - but a stiff wire brush works OK. If the wire brush doesn't work, get a new belt. You can avoid the melted paint buildup (or at least reduce it) if you keep the sander moving rapidly over the surface, and use a good quality scraper to remove as much paint as possible before sanding.
Sep 19, 2012 | Makita 9404 4'' x 24'' Belt Sander
Red and blue light stays on but it cuts on and off, what's the problem? It comes on and works but the red light stays on along with the blue light..when the speaker cuts out, it acts like its trying to...
hi there
The reason for this is the ground is weak to the amp make sure that the post that your ground wire is screwed down to is tight also make sure that is touching bare metal if there is paint on bottom side use wire brush to get the paint off so it is bare metal a weak ground can mess the amp up and make it not work at all hope this helps you have a wonderful day
Aug 23, 2011 | Kenwood KAC-7204 Car Audio Amplifier
Jenson a300hlx 300 watt amp
DISCONNECT THE GROUND WIRE. SAND ALL THE PAINT FROM THAT AREA AND REGROUND IT. WHAT I WOULD RECOMMEND IS DRILLING A HOLE THROUGH THAT TRUNK, SAND THE PAINT AWAY FROM WHERE THE GROUND WIRE WILL GO AND BOLT THE GROUND WIRE TO THE TRUNK BOTTOM. THE PAINT WILL CAUSE THE AMP NOT TO GET A SOLID GROUND
Feb 21, 2009 | Jensen A300HLX Car Audio Amplifier
Pioneer AVIC-N2 does have unlock code?
no, this radio has no security code... Check to see that you have power on the yelow wire at all times, Power on the red wire when the key is on, and make sure the black wire is grounded well. something could have been disconnected at the paint shop.
Jan 03, 2009 | Pioneer AVIC-N2 Car DVD Player
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
