Question about Kitchen Ranges
How do I reinstall inner glass for kitchen aid oven
    Top Expert:
  • Kitchen Ranges Master
  • 52,086 Answers
Remove door by tilting out to first stop then lift door off the hinges . there are several screws around the outer edges that need removed the lift the inner shell off use caution to not drop glass . reverse procedure to replace it .
Posted on Apr 25, 2015
    Sergeant:
  • Kitchen Ranges Expert
  • 448 Answers
Model # AGE ? needed for exact details
Replace inner glass on kitchen aid wall oven
This can be quite a difficult issue to deal with.. This is really a job for a pro technician, honestly. But if you should choose to try it. Remove the oven door from machine, by opening door slightly and looking at hinges you should be able to be able to slide a small arm on the hinge that locks the hinge and stops the door from closing. You then hold door and move toward closing it and lever the hinges out of their space and carefully place door on floor. Then you have to disassemble the door and remove glass. The video below IS NOT EXACT but will help you with what your up against.
Feb 02, 2015 | Ovens
Glass inside oven door is dirty. Is it possible to disassemble the door to clean the glass?
You can remove the oven door and dis-assemble it to clean it but you are looking at quite a task to do so.. Most of the kitchen aid brand requires two pins to be inserted into the door hinges while the door is in the open position to allow the door to be open. When you have inserted the pins into the hinge start to close the door and the pressure of the hinge spring will be applied to the pins allowing you to now lift on the door removing it from it's slots in the face of the oven. The hinge will slide out of the oven face.
Once you have the door removed you can begin the task of taking the door apart. Lay the door inside part down on a table or counter, remove the screws from the bottom of the door trim (piece that holds lower part of glass) and remove the trim. Now you should be able to slide the outer glass downwards (some models required side trims to be removed also). Now you can remove the handle assembly and then begin to remove the inner door liner and inner glass package.
Be careful and pay attention to screw size/location.
Take pictures at each step to aid in re-assembly!
Good luck!!
Aug 14, 2010 | KitchenAid KERC607 Electric Kitchen Range
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Finding replacement part # 4164235 for inner door glass
I am looking for a Kitchen Aid part # 4164235, a Window Pack for the inner door of my Kitchen Aid Oven door.
May 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Kitchenaide KGST307 cracked inner oven window.
Open your oven door and look at the hinges. You should see a drop down thumb lock on each hinge that you pull down and after you do so, lift up on the door as to close. The door will catch on these thumb locks and then at this point continue to lift up on the door as you pull the door out at the bottom. Reverse directions to reinstall.
Apr 05, 2009 | KitchenAid KGST307 Gas Kitchen Range
Kenmore inner oven glass cracked (911.93411002
I suggest you check www.repairclinic.com
They will answer your questions and may even have a better price on the replacement glass.
I have no affiliation, but have been pleased with their service.
Mar 20, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Broken inner glass on kitchaid range how to remove the door
screws near the hinge, make sure to get oven/tempered glass sometimes the screws are located in the crack between the oven and door on the bottom
Jun 12, 2008 | KitchenAid KGST307 Gas Kitchen Range
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
Kitchen Ranges Logo
76 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
