My washer is sometimes getting stuck on the rinse cycle and I have to restart the washer for it to work, then after going through the normal cycle the clothes are still dripping with water, Help?
  • Thomas lawson Apr 25, 2015
    It's an admiral, if that helps
    Sergeant:
  • 448 Answers
Model # AGE ? Needed for better info on your washer. sounds like door lock .
Posted on Apr 25, 2015
5 Suggested Answers
SOURCE: Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Posted on Jan 29, 2008
jsrock516
  • 5911 Answers
SOURCE: Washing machine stops in rinse cycle.
Okay...I asked you a question in your other posting before I saw this one. This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plunger on the lid itself. Make sure the plunger is not broken off. This will also keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and agitate, but will not start the rinse or drain cycles. If you wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Feb 11, 2008
  • 1028 Answers
SOURCE: Soap left in clothes
hope you are using he detergents (high effeciency low suds) also if you have soft water oversudsing can occur even with he ..try reducing amount ..also have been told tide he detergent tends to suds more so may try switching detergent brands try runing washer with no soap no clothes begore next load to flush out any detergent that may remain ..be sure to run washer with bleach no clothes on short cycle peroidically to avoid mold/mildew odors that front loads tend to acquire after a few months use and leave door open if possible between uses..let me know about detergent thanks
Posted on Jul 15, 2008
  • 1214 Answers
SOURCE: Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Posted on Feb 04, 2009
My Maytag Neptune front load washer (about 12 years old gets stuck between 7 & 8 (minutes) in the rinse cycle and won't progress beyond.
It has reached it's use by date, It will just keep on needing repairs , save some money and buy a new one.
Jan 04, 2016 | Maytag Washing Machines
For some reason my GE GBVH6260 washer cycles are getting hung up on either the wash or rinse cycle. Some days it will stay stuck in the wash cycle & some days it will stay stuck in the rinse cycle for...
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
Jul 10, 2017 | Washing Machines
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
The washer keeps filling and won't stop. Sometimes can get it to stop on the wash cycle but won't stop filling at all on the rinse cycle. Any solutions?
I get this question a lot. Washer is flooding the house, water everywhere, won't stop. The first thing I say is unplug the washer. If the water is still coming in,(which it will on a stuck valve) shut off the water faucets. If that is not possible shut the water meter off. If you can stop the washer with the timer then I would say instead of a bad valve you have a plugged water level pressure hose. Look at this diagram: water%20level%20operation.jpg As you can see the rubber tube from the bottom of the tub allows air pressure to push against the switch till it shuts down the valve and starts the wash cycle. Remedy this problem: Simply remove the tube from the switch and blow it out. Use them lungs!. Get that sand and trash out of the sump. Reconnect the hose tightly and pump out any standing water. Then restart the machine. If you have a good tight connection the machine should start working like normal. No parts needed! LOL!
Sep 12, 2009 | Maytag Performa PAV2200
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
