Question about Waring Commercial Perfetto Panini Grill or Tostato Toasting Grill
The top grill plate is not getting hot - Waring Commercial Perfetto Panini Grill or Tostato Toasting Grill
When using grill knobs get to hot to turn stoves 600 sidl
you are missing the heate plate that stops the knobs from getting hot go to ebay and put your model in and look for heate plate or some thing like that
Oct 12, 2012 | Ovens
Nonstick coming off
No, the Teflon Coating is applied when the plates are red hot during manufacture
Jun 19, 2010 | George Foreman GGR62 Grill
Having trouble cleaning the plates after we grill without wrecking the plates...any suggestions? Have tried hot, soapy water, goo gone bbq cleaner, mild scrubbers, and also spraying with PAM before we...
when it's hot lay wet paper towels on them.. no soap remove towels when they stop sizzle. Now just make them wet and sprinkle coarse salt on the grills and scrub with a short brissle wok brush.. the kind with the stiff bambo brissels... remember no soap to clean and no pam when you cook just oil and keep very very clean and it will never get dirty. you may have to keep grill on low untill ready to clean or reheat before cleaning.
Apr 08, 2010 | Coleman Roadtrip Grill LXE 9949-750
Crossover channel for burners is broken where can i get replacement
i have a jenn air grill, i have bought new burners & heat plates, i still cant get it hot enough to cook a steak, i have replaced the fuel tank& regulator, what gives? any suggestions
Mar 28, 2010 | Brinkmann 810-8410-S Stainless Steel...
Top plate does not get hot, bottom plate is ok
The element could have a very fine crack in it, not readily visible. You must use a voltmeter to test if the element is getting power when the switch is turned on. If it is getting power, then the element is bad. If no power, then test the switch to see if it is sending power when turned on.
Jul 07, 2009 | Cuisinart GR-4 Griddler
Brinkman electric smoker
The pan for the wood chips is a round shallow (1/2 or so high) pan, about 8 inches in diameter, that sits right on top of the heating element. The element doesn't get too terribly hot, so you could probably substitute a foil pie plate or even a double wrapped package of aluminum foil with some holes punched in the top. When you see the smoke - its time for the meat!
Good eats!
Pat
Jun 29, 2008 | Brinkmann Smoke' n Grill Electric Double...
George Foreman G5 Grill
With the unit unplugged, check the elements to see if one has become unseated. A gentle push should seat them. Some elements are plug in & can come unseated.
Jan 21, 2007 | George Foreman G5 Indoor Grill
Waring Commercial Perfetto Panini Grill or Tostato Toasting Grill Logo
156 people viewed this question
Top Waring Kitchen Appliances - Others Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
