Question about Kenmore 2982 800 3.5 cu. ft. Top Load Washing Machine
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
    Sergeant:
  • Kenmore Expert
  • 448 Answers
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Posted on Apr 25, 2015
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Will not empty water
Good day,
That's always a bad lid switch. Check out this tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
May 08, 2010 | Whirlpool Washing Machines
I filled my washing machine with clothes tonight and it got to the end of the short cold wash cycle and had stopped running so I pushed in the knob then pulled it back out and then pushed it back in and...
It sounds as if the machine doesn't spin during the spin cycle. Normally the agitator stops spinning, fairly quickly, if the lid is opened during the spin cycle.That safety circuit includes a switch mounted under the opening and is set by a tab on the lid that protrudes thru a small hole in the top of the washer. The most likely failure on most Kenmore models is that switch, broken or loose, the tab on the lid broken, or the two misaligned. I would need the model number of your washer, located on a tag on the bottom of the lid to be more specific
Jan 07, 2010 | Kenmore Washing Machines
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Wash cycle does not start!
if only rinse cycle work. it mean the cycle timer in no good. you need to replace it. i will tell you the cost of it later.
Feb 05, 2008 | Whirlpool LTE5243D Top Load Stacked...
Kenmore 2982 800 3.5 cu. ft. Top Load Washing Machine Logo
154 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
