Question about Miscellaneous
My daughter has an e300 scooter. I have replaced batteries and control unit. The scooter trips the circuit breaker constantly. It will ride for about 30 seconds then trip. Ideas please?
    Top Expert:
  • Miscellaneous Master
  • 42,190 Answers
Check for a wire from the circuit breaker to the motors
it may be touching the motor where it goes into the case and be shorting out.
check the motors as if they are burnt out then it is the same dead short result.
Posted on Aug 03, 2015
Therinnaiguy
  • 1420 Answers
SOURCE: breaker keeps tripping
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
Posted on Sep 12, 2007
watugot
  • 290 Answers
SOURCE: Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Posted on Nov 20, 2007
TJBENGR
  • 121 Answers
SOURCE: my ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Posted on Apr 22, 2008
jbjaxiis
  • 95 Answers
SOURCE: GFI plug trips when pluged in, no reset
You are trying to draw too much power from the dedicated electrical line, or you may have an outlet that is needing replaced. Try to use another plug, in another room to test
Posted on Jul 21, 2008
shastalaker7
  • 1515 Answers
SOURCE: I have 60 amp circuit breaker on my electrical a/c
You're unit is a 31/2 ton according to the numbers.Normally, breakers will only be in a half way posistion when tripped. Yes, under most conditions, the fuse will blow before the breaker trips. I have seen this many times, the breaker may be weak, burned, loose wires and so tighten wires, check the condition of the breaker.It sounds like the breaker even though it is 60 amps, is the problem and you should replace it with out hesitating. This will solve you're problem. When you pull the breaker out, look at the metal clips that snap in on the buss bar to see if they have been overheating.And the buss bar its self. You will know. I am sure this will take care of you're problem. Good Luck,
Shastalaker7
Posted on Dec 07, 2009
Testimonial: "Thank a lot this was very helpful"
My victory 3 loses power. After about 13 minutets of riding, the motor gets hot and trips the circuit. Batterey meter when the throttle is pushed, goes to yellow before it trips the breaker. After a...
either a battery or cable problem long stretch would be breaker and lastly motor if cables get hot try replace them first with larger wire sounds like a resistance problem assumeing your batteries are good and motor brushes good
Jul 01, 2014 | Pride Mobility Victory 3 Wheel Electric...
Do UPG 12 volt 7ah batteries work as good as "RAZOR BRAND" Batteries?My scooter is an e300.Do you know if by chance,the e300 scooter needs razor batteries only?I got generic ones,and they are terrible
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
Mar 19, 2014 | Razor E300 Scooter
Razor e300 Continually needs to be reset continuously need to restart my e300 because stops, only has 2 week old, initially worked perfect, then reset again run until stopped again.
I posted a similar issue about the same scooter. If you do replace the batteries and still experience the same issue, check the wiring for loose wires and possibly replace the fuse.
After replacing the fuse and connecting wires, my scooter doesn't pop the fues with every use anymore.
http://www.fixya.com/support/t7752702-ride_scooter_turns_off
Feb 07, 2014 | Razor E300s Electric Scooter With Seat
Scooter keeps stopping randomly. The battery level near to the speed lever drops quickly to red, scooter stops. Turn it off then on again and fine for a bit - then same happens?
These units are 24 volt systems. If the voltage at the controller drops below 18 volts the controller will cut out. Shutting the unit off and back on resets the controller. Since your battery gauge is dropping into the red when accelerating your batteries are suspected to be bad. If the batteries LOAD test fine then check your battery harness and circuit breaker wiring for a loose and / o r hot connection after riding it.
Oct 28, 2013 | Hurricane Pride Pmv Mobility Scooter Candy...
Is there a fuse inside the Razor E300 electric scooter and if so where is it located?
All electrical product have some kind of fuse or circuit protector. Should be either inline with the battery and be a blade type fuse (trace the wiring), or on the outside of the scooter near where you plug it in and it will be the festoon type. Check the blown fuse for the correct amperage replacement.
Oct 13, 2011 | Razor E300 Scooter
I ride my scooter and then it turns off..the button pops out and when I push it back in it will work for a few moments then stop again.. is the battery done?
I posted a simliar question. I ended up taking my scooter to a battery store that is licensed to work on razor scooters. They ulitmately concluded the wires to the popup fuse itself were loose. They replaced the popup fuse as well just incase. I have now been using the scooter without the fuse popping every 50-100 feet.
Jan 11, 2011 | Razor E300s Electric Scooter With Seat
Clucking sound when riding
Neil, I do not have a solution, but however have the same exact problem. Son got an E300 for Christmas. My daughter also received an E200. The E200 works fine, but the E300 makes a clunking noise when the throttle is engaged. Also the E200 can make it easily up the drive way, but the larger and more powerful E300 can not. Any help with this would be greatly appreciated. Thanks, Ron - ronsmith@komcepts.com
Dec 25, 2010 | Razor E300 Scooter
When i charge my e300s for 8 hours and plus. And when i ride it the battery goes back to low in 2 mins pls help.
Hi and Welcome to FixYa, I am Kelly. You did not mention the age of this scooter or an estimate of the hours it was used. This sounds like the plates in the battery have deteriorated to the point that the battery must be replaced. Old batteries will self discharge do to corrosion or multiple re-charge residue that causes internal battery plate shorts or there is no longer enough plate material to provide the amperage necessary to operate your scooters motor. The only remedy is to replace the battery. If it is relatively new... then there can be a short in the chassis wiring. I doubt there is a short in the wiring as the controls seem to be functioning normally per your comments.
I have over 40 years of real world battery experience autos, aircraft, battery packs et al. This just sounds like the battery life has been reached and the battery needs replaced.
Thanks for choosing FixYa,
Kelly
Nov 14, 2010 | Razor E300 Scooter
Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
May 02, 2010 | Electric Mobility Mobility Electric Power...
Not working
If the circuit breaker tripped,then the unit is trying to work and the remote is certainly telling the unit operate, otherwise it could never trip the breaker if it did not receive a signal from the remote. Your problem may be with the outside unit that te compressor is stalled (having a hard time starting ) and this will cause the breaker to trip. You need a porfessional to diagnose if it is the starter control, or relay, or capacitor, or bad compressor, or bad terminals.
Nov 28, 2009 | Coffee Makers & Espresso Machines
Miscellaneous Logo
41 people viewed this question
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
