Question about Welding Tools
Unit turns on but will not weld stick or aluminum. Basically no arc.
4 Suggested Answers
  • 3 Answers
SOURCE: bad tig weld job
Wow you have a lot of variables here. Let's go over some of them.1.AC current 2.100%argon shield gas 3.Check your Tungsten, it must be the recommended 1or 2% and the right size, clean and the tip rounded by meting 4. High freq. turned to continous-not just "START"
5. CLEAN,CLEAN,CLEAN your Alum. with a S.S. brush that has touched NOTHING else in in it's life!
Start here and GOOD luck
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: welding aluminum
TIG weding is next to brain surgery as far as CLEAN goes.
You must get your AL clean, either by 1. Clean with a NEW Stainless Steel brush or 2. by using a chemical from the welding house that is made just for that.
Your cup must be clean and your gas flowing at the right amount,no leaks in o-rings or hoses.
Hold your cup more vertical and keep your filler rod in the gas shield always,no in and out movement.
In short you must get everything perfect to get quality Heliarc Al welds.
Good luck, HowardRoark
co7196
  • 3433 Answers
SOURCE: Miller Syncrowave 200 wont strike arc for TIG
proper polarity?
Posted on Nov 12, 2009
What polarity do I use for tig welding aluminum, and what color electrode for miller hf-p dial arc
Jackie, watch the linked videos on tigging aluminum. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 31, 2016 | Miller Welding Tools
Tip
What are 4 common welding processes?
There are four common welding processes utilized through out the work industry today. They are :
(Stick Welding or SMAW) Shield Metal Arc Welding
(Mig Welding or GMAW) Gas Metal Arc Welding
(Tig Welding or TMAW) Tungsten Metal Arc Welding
(FCAW) Flux Cored Arc Welding
There are many many welding processes, however these are the most common. The type I am going to discuss briefly today is SMAW. The most economical and cheapest way to learn if welding is for you or not is to start with stick welding. It has the least amount of variables that can go wrong for a beginner. It is not fast paced like mig or flux core, so you have time to watch the molten puddle to see what it is doing and make necessary adjustments to correct the size, shape, and contour of your weld bead. The hardest part for a beginner is to keep the electrode from sticking to the work piece. Thus is the reason it got the name of "stick welding". There are three common ways to strike an arc in SMAW. Tap Start, Scratch Start, and the last is to place the electrode upon your fingers like a pool cue, and shoot the rod like your playing pool.
on May 31, 2010 | Welding Tools
What settings do i use to arc weld.
Not sure what machine you have, but it should be DC straight (electrode negative or DCEN) and DC reverse (electrode positive or DCEP). The polarities have different characteristics. For example, if you're planning to TIG weld, you would either use DCEN or AC (if welding aluminum). For the general stick welding process, DCEP tends to give you a deeper weld. The welding rod you buy will have recommended machine polarity and amperage range settings, you should use the recommended polarity for whichever rod you're using because different rods are designed to weld under different circumstances. But, generally speaking, most welding rods for steel will work on DCEP without much trouble.
May 17, 2016 | ARC Welding Tools
Why will it not rev up
Welder Idles but dosnt rev up so when i strike an Arc [Archive ...
www.hobartwelders.com > ... > EQUIPMENT TALK > Generator/Welders
Apr 21, 2008 - 7 posts - ‎4 authors
... is good there,I have continuity from the wire there back to the Auto Idle Module,and i... If it does not affect the idle. then check these things. ... out,,can i put a PTO cable on the throttle and pull up the RPMs when i weld? right ... Benefits of Stick?
Sep 26, 2007
SA 250 will not strike an arc
May 7, 2006
Lincoln Weld-Pak 100hd.. Need some opinions, =]
Jan 15, 2005
Aluminum repair
Mar 19, 2003
More results from www.hobartwelders.com
SA-200 Idler Troubleshooting - Weldmart Online
https://www.weldmart.com/main/.../sa200idler_troubleshooting.html
The solenoid pulls the carburetor throttle plate closed and the engine drops to idle ...Turn it off (close it) and the solenoid releases; the welder idles up. ... If it does show power-with the engine off, remove the wire and recheck the terminal. ... B. The idler solenoid is good but it will not idle up when you strike an arc, or when a ...
Idler control for sa 200 lincoln welder - American Welding Society
Dec 08, 2015 | Welding Tools
If I turn the ac dc switch while what dose it do to the wielder. Now im not getting any juice to wield .thank you
Changes between AC and DC voltage at the electrodes.
Q: What Type Of Stick Welder Works Best For All-Around Use?
A: A welder with an AC/DC output, whether its an electric arc machine like Miller\'s Thunderbolt or a gas engine drive like Miller\'s Bobcat.
DC welding offers advantages over AC for most Stick applications, including: easier starts; fewer arc outages and sticking; less spatter/better looking welds; easier vertical up and overhead welding; easier to learn "how to weld" and a smoother arc. DC reverse polarity (electrode positive) provides about 10 percent more penetration at a given amperage than AC, while DC straight polarity (electrode negative) welds thinner metals better.
Q: Does An AC Output Have Any Advantages?
A: Yes, if you need to weld on material that\'s become magnetized from friction, such as when hay, feed or water constantly rub against a steel part. A DC output won\'t work because of "arc blow," where the magnetic field blows the molten filler metal out of the weld puddle. Because an AC output alternates between polarities, it enables you to weld magnetized parts.
Aug 19, 2014 | Computers & Internet
Miller Trailblazer, welds great for about 30 minutes. Then I loose my arc. It will spark but not maintain the arc. I let it cool off for 15 to 30 minutes it will weld for another 15 to 30 minutes.
Sounds pretty normal. These units are not rated to weld continuously. They might only be rated at 5-10% for cheap welders and longer for better ones. They are never designed to run continuously. You need to get into the higher end ($$$) before you get that ability.
You can try to blow cool air into the unit to help it cool. Sometimes this can extend the work time.Basically you can try that or work to your temp cut off limit as you have been or upgrade to a better unit. That is about all you can do.
Apr 04, 2011 | Miller Trailblazer 302 Welder Generator...
I have a miller microwave 200. what settings should i use for aluminum welding? dcep, ac, dcen? i'm using a3/32'' tungsten and trying to weld on 1/4'' alum plate. the weld is not turning out to be a smooth...
I think you mean you have a Miller Synchrowave 200.
Typically, you would want to use AC below about 250 amps. In this case (to keep it simple), use AC, adjust your balance to about 4, use an 1/8" pure tungsten, pure argon at about 20CFh, and set the panel at 170amps to get things started. For general purpose, use 4043 filler.
Now - these are just generic settings, but they will get you going.
Jan 12, 2010 | ARC Welding Secrets Book - Mig/tig/oxy/arc...
I dont know what kind of metals this wire type can do, it says fire power 1440 u235 flux wire, but not sure what kinds of aluminums or steels it can weld. Im a certifed MIG aluminum welder, but this is a...
Usually a flux core only welds steel. It is a higher penetration weld than a MIG. Usually it acts similar to 6011 rods in SMA (Shielded Metal Arc) welding -- a.k.a. stick welding -- if you're familiar with that. I don't believe there is such a thing as flux wire for aluminum. There may be stainless wire for it, but I've never seen it. It probably could also be used for building up cast iron and cast steel, but nothing structural. I have a Chicago Electric one and I love it -- simple and it penetrates hard. My 90 amp will weld to 3/8" without breaking a sweat and if I baby it will go to 1/2" or better. It is difficult to go much lower than 12 or 14 gauge though due to the high penetration.
Nov 28, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
I fix the transmission but it still leaks the transmission oil
Did you replace the rear main seal? This is where it usually leaks transmission fluid. Unles there is a crack on the housing, which can be welded with a mig welder(Gas Metal Arc Welding). Welding aluminum requires the use of a mig welder, and inert gas called argon. The machine itself cost 500 to a few thousand dollars. I have one in my shop just in case I need to weld aluminum.
Nov 14, 2009 | 2000 Dodge Caravan
Bad tig weld job
Dec 18, 2008 | Welding Tools
Welding Tools Logo
431 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
