Question about GE Dryers
I have a GE dryer model number DBVH512EF0WW and it's showing a error code E61 what does that mean I've unplugged it and plugged it back up still showing code
    Sergeant:
  • GE Expert
  • 448 Answers
Main control board replace Board
Posted on Apr 25, 2015
SOURCE: Frigidaire LEQ2152ES Electric dryer
Just to verify does it also beep six times? This model has the actual pushbuttons. Press all buttons lightly and see if any release. Disengage button.
Posted on Jan 03, 2008
  • 77 Answers
SOURCE: dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Posted on Apr 21, 2009
SOURCE: ge adora dryer #dhdvh52efoww has code E61 and does not work, how can i fix it
Turning off in the middle of cycle and code E62
Posted on Aug 25, 2009
protek480
  • 1714 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
SOURCE: GE Dryer error code E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code “E00”shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error “E00”code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
Posted on May 21, 2010
My dryer won't power up. The model number is dbvh512ef0ww.
Check the circuit breaker, then I would check the belt switch- if the belt breaks, the machine will not tumble GE Dryer Switch WD21X10261
Jul 27, 2016 | Dryers
I have a GE dryer and it's reading the code E61 what does that mean
For GE dryers, the E61 code indicates a problem with the wiring or the control board. The dryer is sensing the wrong voltage between the hot and neutral lines of the incoming wiring. First check your wiring/fuses/circuit breakers. If your wiring is OK, then the control board is probably faulty.
If you post a comment with the model, I may be able to point you to the appropriate parts. I hope this helps.
(note: if you have an electric dryer using 220V, you may want an electrician to check the wiring.)
Apr 25, 2015 | GE Dryers
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
Apr 25, 2014 | Frigidaire Dryers
Error code e61
Identification
  • GE dryers use three-character codes that display on LCD screens. Every code starts with "E" and is followed by a two-digit number.
Power Failure
  • When your home loses power, the "E01" error flashes on the screen. Reset the dryer memory by unplugging the device, waiting 30 seconds and plugging it back in. The error code will disappear.
Thermistor Errors
  • Errors "E02," "E03," "E04" and "E05" are thermistor errors. The thermistor, when operating properly, reads the temperature of the dryer. Errors E02 through E05 indicate the thermistor must be replaced.
Effects
  • When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
Control Board Errors The control board sends signals from the controls to the dryer. When this fails, errors "E61," "E80" and "E81" appear. Contact GE service or install a new control board for the dryer
Jan 15, 2013 | Electrolux Dryers
No heat, power good. 120 each leg. drum turns. ran diagnostics. no error codes. t07 reads 73f, to8 reads 74f, t09 reads 5.01. suspect heater element is open. model is DBVH512EF0WW. would have thought error...
better but the restring kit comes in bracket # WE11XM30 heater assy mica heater but i would check tstat on top left of heater 2nd thermstat in ward rivited on metal plate thats usually the bad one and the thermistor on blower assy # WE4M336 or get complete asymbley 512 on parts break down and 240 on parts breakdown thermistor
Jan 31, 2011 | GE DBVH512EFWW Dryer
Sep 25, 2009 | Electrolux EIED55H Dryer
GE Microwave JES1334WD Code -P3-
Are you sure it's not F3? That would be a shorted keypad ("membrane panel").
That's usually not too big a job for a DIYer, but if you'd like, we can do that for $39.95 plus parts.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
One good test is (with power unplugged) to unplug the keypad, then plug the oven back in and see if the error code shows up.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 16, 2008 | Microwave Ovens
SEQUENCE (cont.)
(t02)
Mar 16, 2007 | GE DBVH512EFWW Dryer
Dryers Logo
187 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
