1st with mover off verify that both handles move same amount forward , I use a string to measure them , they both have mechanical stops that do bend and move sometimes
second locate control body valve , (thing that handles connect too) there should be a pump pressure adjust (allen key) on the side of this your gonna need to make small adjustments and try it , is difficult to do if you don't have a lift to elevate wheels of mower (but is possible without ) but takes patience
SOURCE: My zero turn Toro dont want to start, the battery is good and starter
On mine the arms have to be out the blades have to be off and the parking brake has to be on for it to start hope this helps.
SOURCE: My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Testimonial: "Thank You very much for your support on this matter. "
SOURCE: My 42" toro zero turn
the drive belt pulley probably needs replacing or the belt popped off the pully
SOURCE: zero turn toro will only go in a circle
each side has a pump release lever on the rear did one side get pulled out to the push position?or not go all the way back after releasing it
