Toys Logo
S
Seth Rupprecht Posted on Apr 25, 2015
Has dynashift - will not shift from low to high range (tortoise to hare) even after replacing both solenoids.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Sep 07, 2008
SOURCE: When useing 4x4 high range
likely needs a shift motor on the transfer case.
Anonymous
  • 916 Answers
  • Posted on Jan 06, 2009
SOURCE: Hello, I own a 93
The transmission is controlled by the Transmission Control Unit (TCU).
Throttle position, rpm, and speed are input parameters to the TCU. The TCU has a default set of shift patterns. These shift patterns change over time based on your specific vehicle setup and driving habbits.
The shift patterns are only slightly affected by driving habbits over many driving cycles. But, changing the relationship between the throttle position and the actual speed being reported by the speed sensor can have an immediate effect on shift patterns.
While your speedo may now be correct, the realtionship between rpm and thottle position has not been corrected. That would take a gear change in the differentials.
The TCU can be reset to an inital learn base line. When this is done, the TCU will instantly learn the dynamics of your setup.
Any shop with an advanced ODB scan tool can reset the the TCU. The dealer or a transmission shop would be preferable.
You really should change your differential gears as opposed to resetting the TCU
This information was posted by ftgiles here
Anonymous
  • 4 Answers
  • Posted on Jan 11, 2009
SOURCE: four wheel drive won't engage
Possible the front acutator is in operative. First check the wiring, since it runs under the axle tube, the check for power at the acutator plug in, if power there acuator faulty. If no power start with fuses. hope this is a starting point for you.
skoch76
  • 9 Answers
  • Posted on Jan 28, 2009
SOURCE: 2004 f250 won't shift into 4wd low range.
I'm pretty sure the truck has to be at a complete stop with the transmission in neutral before it will accept your low range input selection. Unlike 4wd high.
Anonymous
  • 10319 Answers
  • Posted on Jan 06, 2011
SOURCE: first gear drives fine but
the symtoms all refer to a sticking piston it the valve body
2answers
Where is the four wheel module located on a 2001 f350 7.3 l lariat 4x4 nothing on the four wheel drive works and I checked all the fuses and are all fine
Have it check for DTC'S - diagnostic trouble codes ?
GEM Diagnostic Trouble Code (DTC) Index
GEM Diagnostic Trouble Code (DTC) Index DTC Description Source Action C1728 Transfer Case Unable to Transition Between 2H and 4H GEM CARRY OUT the electronic shift function test. REFER to Function Test - Electronic Shift in this section. C1729 Transfer Case Unable to Transition Between 4H and 4L GEM CARRY OUT the electronic shift function test. REFER to Function Test - Electronic Shift in this section. P0500 Vehicle Speed Sensor (VSS) Malfunction GEM GO to Pinpoint Test F . P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure GEM GO to Pinpoint Test H . P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure GEM GO to Pinpoint Test I . P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure GEM GO to Pinpoint Test E . P1815 Transmission 4-Wheel Drive Mode Select Short Circuit to Ground GEM GO to Pinpoint Test E . P1819 Transmission Park/Neutral Position Switch Short Circuit to Ground GEM GO to Pinpoint Test F . P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure GEM GO to Pinpoint Test E . P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short to Battery GEM GO to Pinpoint Test E . P1828 Transfer Case Counterclockwise Shift Relay Coil Circuit Failure GEM GO to Pinpoint Test E . P1830 Transmission Transfer Case Counterclockwise Shift Relay Coil Short Circuit to Battery GEM GO to Pinpoint Test E . P1832 Transmission Transfer Case Differential Lockup Solenoid Circuit Failure GEM GO to Pinpoint Test G . P1834 Transmission Transfer Case Differential Lockup Solenoid Short Circuit to Battery GEM GO to Pinpoint Test G . P1865 Transmission Transfer Case Contact Plate Power Short to Ground GEM GO to Pinpoint Test E . P1866 Transmission Transfer Case System Concern - Servicing Required GEM CARRY OUT the electronic shift function test. REFER to Function Test - Electronic Shift in this section. P1867 Transmission Transfer Case Contact Plate General Circuit Failure GEM GO to Pinpoint Test E . P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure GEM GO to Pinpoint Test G . P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short to Battery GEM GO to Pinpoint Test G . - For All Other DTCs GEM GO to Section 419-10 .
Your best bet , take it to a qualified repair shop that has the diagnostic tool to trouble shoot .
Principles of Operation
Transfer Case - Electronic Shift
The four-wheel drive, electronic shift-on-the-fly feature electrically shifts the vehicle transfer case between 2WD, 4X4 HIGH, and 4X4 LOW. The system mode is selected by the operator through the mode select switch (MSS) on the instrument panel. The operator is informed which mode the system is in by two instrument cluster indicators, one for 4X4 HIGH which is 4X4, and one for 4X4 LOW which is LOW RANGE (in 4X4 LOW both the lamps are on). Shifts into 4X4 HIGH can be made at any speed. When shifting into 4X4 HIGH with the vehicle stationary, tooth blockage may occur, preventing shift completion. When the vehicle is driven above 8 km/h (5mph) the shift will complete. When shifting in or out of 4X4 LOW, the generic electronic module (GEM) requires that the vehicle speed be less than 5 km/h (3 mph), the brake pedal be applied, and the transmission in NEUTRAL (automatic transmission) or the clutch pedal be depressed (manual transmission). (The digital transmission range [TR] sensor informs the GEM when the automatic transmission is in the NEUTRAL range position.)
The gearmotor encoder assembly is mounted externally on the transfer case. It drives a rotary cam which moves the mode fork and the range fork within the transfer case between the 4X4 HIGH, 4X4 LOW, and 2WD range positions.
The GEM uses two relays to control the gearmotor encoder assembly shift between 4X4 HIGH, 4X4 LOW, and 2WD modes. The GEM controls the pulse vacuum hublock (PVH) solenoid which supplies engagement and disengagement vacuum to control the hublocks.
The GEM accomplishes shifts by interpreting inputs from:
  • mode select switch (MSS)
  • vehicle speed signal (transmitted from the ABS system)
  • gearmotor encoder plate position
  • brake pedal switch
  • digital transmission range (TR) sensor (automatic transmission)
  • clutch pedal position (CPP) switch (manual transmission)
  • ignition switch
Based on these inputs, the GEM controls the shifts into 2WD, 4X4 HIGH, or 4X4 LOW with the following outputs:
  • low to high relay (clockwise)
  • high to low relay (counterclockwise)
  • pulse vacuum hublock (PVH) solenoid
  • gearmotor encoder assembly
The electronic shift-on-the-fly (ESOF) system has a feature which allows the driver to override the vacuum operated hublocks. When the front hublocks are manually turned to the LOCK position, the hublocks are locked at all times, overriding the vacuum operated system. If the front hublocks are manually turned to the AUTO position, the hublocks can only be locked by turning the MSS to 4X4 HIGH or 4X4 LOW position.
My power chair is so slow, not sure what the speed is but, its slower then walking pace.
check with your operators manual and you may find a switch that has the markings of a hare on one side and a tortoise on the other
that will be you low and high speed settings
Trouble code in a 2003 kia Sedona PO106
These are the only ones I have listed
P0100 Mass Air Flow or Volume Air Flow Circuit Malfunction.
P0101 Mass Air Flow or Volume Air Flow Circuit Range/Performance problem.
P0102 Mass Air Flow or Volume Air Flow Circuit Low Input.
P0103 Mass Air Flow or Volume Air Flow Circuit High Input.
P0107 MAP/BARO Circuit Low Input.
P0108 MAP/BARO Circuit High Input.
P0110 A/T Circuit Malfunction.
P0115 Engine Coolant Temperature Circuit Malfunction.
P0116 Engine Coolant Temperature Circuit Range/Performance Condition.
P0117 Engine Coolant Temperature Circuit Low Input.
P0118 Engine Coolant Temperature Circuit High Input.
P0120 Throttle Position Malfunction - Circuit A.
P0122 APP/TPP Sensor Switch Low Input - Circuit A.
P0123 APP/TPP Sensor Switch High Input - Circuit A.
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control.
P0130 Oxygen Sensor Circuit Malfunction - Bankicon1.png 1 Sensor 1.
P0131 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 1.
P0132 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 1.
P0133 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 1.
P0134 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 1.
P0135 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 1.
P0136 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 2.
P0137 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 2.
P0138 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 2.
P0139 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 2.
P0140 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 2.
P0141 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 2.
P0170 Fuel Trim Malfunction - Bank 1.
P0171 System too Lean - Bank 1.
P0172 System too Rich - Bank 1.
P0261 Injector Circuit Low - Cyl. 1.
P0262 Injector Circuit High - Cyl. 1.
P0264 Injector Circuit Low - Cyl. 2.
P0265 Injector Circuit High - Cyl. 2.
P0267 Injector Circuit Low - Cyl. 3.
P0268 Injector Circuit High - Cyl. 3.
P0270 Injector Circuit Low - Cyl. 4.
P0271 Injector Circuit High - Cyl. 4.
P0300 Multiple/Random Misfire detected.
P0301 Misfire detected - Cyls. 1-4.
P0302 Misfire detected - Cyls. 1-4.
P0303 Misfire detected - Cyls. 1-4.
P0304 Misfire detected - Cyls. 1-4.
P0325 Knock Sensor Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range/Performance - Bank 1 or Single Sensor.
P0335 Crankshaft Position Sensor Malfunction - Circuit A.
P0336 Crankshaft Position Sensor Range/Performance - Circuit A.
P0340 Crankshaft Position Sensor Circuit Malfunction.
P0342 Crankshaft Position Sensor Circuit Low Input.
P0343 Crankshaft Position Sensor Circuit High Input.
P0400 EGR Flow Malfunction.
P0403 EGR Circuit Malfunction.
P0404 EGR Circuit Range/Performance Malfunction.
P0420 Catalyst System Efficiencyicon1.png below Threshold - Bank 1.
P0422 Main Catalyst Efficiency below Threshold - Bank 1.
P0440 Evaporative Control Malfunction.
P0441 Evaporative Control System - Improper Purge.
P0442 Evaporative Control System - Small Leak detected.
P0443 Evaporative Control System Purge Control Valve Circuit Malfunction.
P0446 Evaporative Vent Control Circuit Malfunction.
P0447 Evaporative Vent Control Circuit Open.
P0448 Evaporative Vent Control Circuit Short.
P0450 Evaporative System Pressure Sensor Circuit Malfunction.
P0452 Evaporative Control System Pressure Sensor Low Input.
P0453 Evaporative Control System Pressure Sensor High Input.
P0455 Evaporative Control System - Large Leak detected.
P0470 Exhaust Pressure Sensor Malfunction.
P0500 Vehicle Speed Sensor Malfunction.
P0501 Vehicle Speed Sensor Range/Performance.
P0505 Idle Air Control System Malfunction.
P0506 Idle Air Control System Malfunction - RPM Lower than expected.
P0507 Idle Air Control System Malfunction - RPM Higher than expected.
P0510 CTP Switch Malfunction.
P0561 System Voltage Unstable.
P0562 System Voltage Low.
P0563 System Voltage High.
P0601 Internal Control Module Memory Checksum Error.
P0604 Internal Control Module RAM Error.
P0703 Torque Converter/Brake Pedal Switch Malfunction - Circuit B.
P0705 Transaxle Range Sensor Circuit Malfunction (PRNDL Input).
P0706 A/T Range Sensor Circuit Range/ Performanceicon1.png.
P0710 Transaxle Fluid Temperature Sensor Circuit Malfunction.
P0711 A/T Fluid Temperature Sensor Circuit Range/Performance.
P0715 Input/Turbine Speed Sensor Circuit Malfunction.
P0722 Output Speed Sensor Circuit No Signal.
P0726 Engine Speed Input Circuit Range/ Performance.
P0727 Engine Speed Input Circuit - No Signal.
P0731 A/T Gear 1 Improper Ratio.
P0732 A/T Gear 2 Improper Ratio.
P0733 A/T Gear 3 Improper Ratio.
P0734 A/T Gear 4 Improper Ratio.
P0740 Torque Converter Clutch System Malfunction.
P0743 Torque Converter Clutch Circuit Electrical.
P0750 Shift Solenoid "A" Malfunction.
P0753 Shift Solenoid "A" Electrical.
P0755 Shift Solenoid "B" Malfunction.
P0758 Shift Solenoid "B" Electrical.
P0760 Shift Solenoid "C" Malfunction.
P1000 Readiness Function Code.
P1115 Engine Coolant Temperature Signal from ECM to TCM.
P1121 Throttle Position Sensor Signal Malfunction from ECM to TCM.
P1170 Front Heated Oxygen Sensor Stuck.
P1195 EGR Pressure Sensor (1.6L) or Boost Sensor (1.8L) Open or Short.
P1196 Ignition Switch "Start" Open or Short (1.6L).
P1250 Pressure Regulator Control Solenoid Valve Open or Short.
P1252 Pressure Regulator Control Solenoid Valve No. 2 Circuit Malfunction.
P1307 Chassisicon1.png Acceleration Sensor Signal Malfunction.
P1308 Chassis Acceleration Sensor Signal Low.
P1309 Chassis Acceleration Sensor Signal High.
P1345 No SGC Signal (1.6L).
P1386 Knock Sensor Control Zero Test.
P1402 EGR Valve Position Sensor Open or Short.
P1449 Canister Drain Cut Valve Open or Short (1.8L).
P1450 Excessive Vacuum Leak.
P1455 Fuel Tank Sending Unit Open or Short (1.8L).
P1457 Purge Solenoid Valve Low System Malfunction.
P1458 A/C Compressor Control Signal Malfunction.
P1485 EGR Solenoid Valve Vacuum Open or Short.
P1486 EGR Solenoid Valve Vent Open or Short.
P1487 EGR Boost Sensor Solenoid Valve Open or Short.
P1496 EGR Stepper Motoricon1.png Malfunction - Circuit 1 (1.8L).
P1497 EGR Stepper Motor Malfunction - Circuit 2 (1.8L).
P1498 EGR Stepper Motor Malfunction - Circuit 3 (1.8L).
P1499 EGR Stepper Motor Malfunction - Circuit 4 (1.8L).
P1500 No Vehicle Speed Signal to TCM.
P1505 Idle Air Control Valve Opening Coil Voltage Low.
P1506 Idle Air Control Valve Opening Coil Voltage High.
P1507 Idle Air Control Valve Closing Coil Voltage Low.
P1508 Idle Air Control Valve Closing Coil Voltage High.
P1523 VICS Solenoid Valve.
P1586 A/T-M/T Codification.
P1608 PCM Malfunction.
P1611 MIL Request Circuit Voltage Low.
P1614 MIL Request Circuit Voltage High.
P1624 MIL Request Signal from TCM to ECM.
P1631 Alternator "T" Open or No Power Output (1.8L).
P1632 Battery Voltage Detection Circuit for Alternator Regulator (1.8L).
P1633 Battery Overcharge.
P1634 Alternator "B" Open (1.8L).
P1693 MIL Circuit Malfunction.
P1743 Torque Converter Clutch Solenoid Valve Open or Short.
P1794 Battery or Circuit Failure.
P1795 4WD Switch Signal Malfunction.
P1797 P or N Range Signal or Clutch Pedal Position Switch Open or Short
F150 4wd will not engage
Manual shift or Four-Wheel Drive Systems - Electronic Shift I'm assuming you have electronic shift because you refer to relay clicking behind the instrument panel . Principles of Operation Transfer Case - Electronic Shift
  • ignition switch
Do you know what DTC'S - diagnostic trouble code's are ?
Your best bet , take it to a qualified repair shop .
1helpful
P0446
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0109 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Petal Position Sensor/Switch A Circuit Malfunction
P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Petal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Petal Position Sensor/Switch A Circuit Intermittent
P0126 Insufficient Coolant Temperature for Stable Operation
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Exhaust Gas Recirculation Flow Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfuction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stuck Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
Where should the choke lever be to start my craftsman 5 hp tiller. Should it go toward the engine,or back toward the handle.
it is normal to have small graphic items at each end of the lever. Tortoise and a Hare.
To start from cold, move the the lever fully towards the Hare (choke Position) when started and the engine begins to hunt move slowly towards the Tortoise until the engine sounds HAPPY. When the engine is warm move the lever towards the Tortoise until the engine attains a smooth tickover speed. If you move the lever fully toward the Tortoise the engine may stop depending upon the carburettor setting.
Try this:- Push your lever fully forward and try to start having made sure that the petrol valve is open (if it has one) and that the carb has been primed (if you have a primer button). If the engine does not start after 3 good attempts leave the machine to rest for 15 minutes. Then; push the handle fully back towards the handle and try to start it as above. I presume that you will have a spark at the plug and correct fuel for the engine in the tank also the engine oil is at the correct level. Some garden equipment also has a switch to allow the power from the battery to the starting mechanism.
Give it a try, I hope this helps.
Chris
2helpful
My c6 in bronco starts off in 2nd gear performs ok every other way.
P0700 Transm.Contr.System Malfunction 17084
P0702 Transm.Contr.System Electrical 17086
P0703 Torque Converter/Brake Switch B Circ Malfunction 17087
P0705 Transm.Range Sensor Circ.(PRNDL Inp.) Malfunction 17089
P0706 Transm.Range Sensor Circ Range/Performance 17090
P0707 Transm.Range Sensor Circ Low Input 17091
P0708 Transm.Range Sensor Circ High Input 17092
P0710 Transm.Fluid Temp.Sensor Circ. Malfunction 17094
P0711 Transm.Fluid Temp.Sensor Circ. Range/Performance 17095
P0712 Transm.Fluid Temp.Sensor Circ. Low Input 17096
P0713 Transm.Fluid Temp.Sensor Circ. High Input 17097
P0715 Input Turbine/Speed Sensor Circ. Malfunction 17099
P0716 Input Turbine/Speed Sensor Circ. Range/Performance 17100
P0717 Input Turbine/Speed Sensor Circ. No Signal 17101
P0721 Output Speed Sensor Circ Range/Performance 17105
P0722 Output Speed Sensor Circ No Signal 17106
P0725 Engine Speed Inp.Circ. Malfunction 17109
P0726 Engine Speed Inp.Circ. Range/Performance 17110
P0727 Engine Speed Inp.Circ. No Signal 17111
P0730 Gear Incorrect Ratio 17114
P0731 Gear 1 Incorrect Ratio 17115
P0732 Gear 2 Incorrect Ratio 17116
P0733 Gear 3 Incorrect Ratio 17117
P0734 Gear 4 Incorrect Ratio 17118
P0735 Gear 5 Incorrect Ratio 17119
P0740 Torque Converter Clutch Circ Malfunction 17124
P0741 Torque Converter Clutch Circ Performance or Stuck Off 17125
P0748 Pressure Contr.Solenoid Electrical 17132
P0750 Shift Solenoid A malfunction 17134
P0751 Shift Solenoid A Performance or Stuck Off 17135
P0752 Shift Solenoid A Stuck On 17136
P0753 Shift Solenoid A Electrical 17137
P0756 Shift Solenoid B Performance or Stuck Off 17140
P0757 Shift Solenoid B Stuck On 17141
P0758 Shift Solenoid B Electrical 17142
P0761 Shift Solenoid C Performance or Stuck Off 17145
P0762 Shift Solenoid C Stuck On 17146
P0763 Shift Solenoid C Electrical 17147
P0768 Shift Solenoid D Electrical 17152
P0773 Shift Solenoid E Electrical 17157
P0790 Normal/Performance Switch Circ Malfunction 17174
2helpful
Hi sir, i want some details related to the gear
5helpful
2answers
Powerstroke 7.3 2000 two fault codes p0603 and p1211 my reader tells me but i have no manual
p1111 System Pass (No DTCs Available)
P0107 BARO Circuit Low Input
P0l08 BARO Circuit High Input
P0112 IAT Sensor Circuit Low Input
P0113 IAT Sensor Circuit High Input
P0122 Accelerator Pedal Sensor Circuit Low Input
P0123 Accelerator Pedal Sensor Circuit High Input
P0197 EOT Sensor Circuit Low Input
P0198 EOT Sensor Circuit High Input
P0220 Throttle Switch B Circuit Malfunction
P0221 Throttle Switch B Circuit Performance
P0230 Fuel Pump Relay Driver Fail
P0231 Fuel Pump Relay Driver Circuit Failure
P0232 Fuel Pump Relay Driver Failed Off
P0236 Turbo Boost Sensor A Circuit Performance
P0237 Turbo Boost Sensor A Circuit Low Input
P0238 Turbo Boost Sensor A Circuit High Input
P0261 Injector Circuit Low - Cylinder 1
P0262 Injector Circuit High - Cylinder 1
P0264 Injector Circuit Low - Cylinder 2
P0265 Injector Circuit High - Cylinder 2
P0267 Injector Circuit Low - Cylinder 3
P0268 Injector Circuit High - Cylinder 3
P0270 Injector Circuit Low - Cylinder 4
P0271 Injector Circuit High - Cylinder 4
P0273 Injector Circuit Low - Cylinder 5
P0274 Injector Circuit High - Cylinder 5
P0276 Injector Circuit Low - Cylinder 6
P0277 Injector Circuit High - Cylinder 6
PO279 Injector Circuit Low - Cylinder 7
P0280 Injector Circuit High - Cylinder 7
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Injector Circuit Low - Cylinder 8
P0283 Injector Circuit High - Cylinder 8
P0284 Cylinder 8 Contribution/Balance Fault
P0301 Fault Cylinder A-Misfire Detected (CYL 1)
P0302 Fault Cylinder B-Misfire Detected (CYL2)
P0303 Fault Cylinder D-Nlisfire Detected (CYL 3)
P0304 Fault Cylinder E-Misfire Detected (CYL 4)
P0305 Fault Cylinder F-Misfire Detected (CYL5)
P0306 Fault Cylinder G-Nlisfire Detected (CYL 6)
P0307 Fault Cylinder C-Misfire Detected (CYL 7)
P0308 Fault Cylinder H-Misfire Detected (CYL 8)
P0340 CMP Sensor Circuit Malfunction
P0341 CMP Sensor Circuit Performance
P0344 CMP Sensor Circuit Intermittent
P0360 Glow Plug Circuit Malfunction
P0381 Glow Plug Indicator Circuit Malfunction
P0460 Fuel Tank Level Indicator Circuit Malfunction
P0470 Exhaust Back Pressure Sensor Circuit Malfunction
P0471 Exhaust Back Pressure Sensor Circuit Performance
P0472 Exhaust Back Pressure Sensor Circuit Low Input
P0473 Exhaust Back Pressure Sensor Circuit High Input
P0476 Exhaust Pressure Control Valve Maffunction
P0476 Exhaust Pressure Control Valve Performance
P0478 Exhaust Pressure Control Valve High Input
P0503 Vehicle Speed Sensor Noisy
PO541 Manifold Intake Air Heater
P0542 Manifold Intake Air Heater
P0662 System Voltage Low
P0666 Cruise 'On" Signal Malfunction
P0566 Cruise "Off' Signal Malfunction
P0667 Cruise 'Resume' Signal Malfunction
P0668 Cruise "Set' Signal Malfunction
P0669 Cruise "Coast' Signal Malfunction
P0571 Brake Svdtch A Circuit Malfunction
P0603 Internal Control Module KAM Error
P0605 Internal Control Module ROM Error
PO606 PCM Processor Fault
P0640 Manifold Intake Air Heater
P0670 Glow plug control circuit malfunction
P0671 Glow plug #1 circuit failure
P0672 Glow plug #2 circuit failure
P0673 Glow plug #3 circuit failure
P0674 Glow plug #4 circuit failure
P0675 Glow plug #5 circuit failure
P0676 Glow plug #6 circuit failure
P0677 Glow plug #7 circuit failure
P0678 Glow plug #8 circuit failure
P0683 Glow plug diagnostic signal communication fault
P0703 Brake Switch B Circuit Malfunction
P0704 Clutch Pedal Position Switch Input Circuit Malfunction
P0705 TR Sensor Circuit Malfunction
P0707 TR Sensor Circuit Low Input
P0708 TR Sensor Circuit High Input
P0712 Transmission Fluid Temp. Sensor CKT Low Input
P0713 Transmission Fluid Temp. Sensor CKT High Input
P0715 TSS Sensor Circuit Malfunction Fault
P0717 TSS Intermittent Failure
P0718 Noisy TSS
P0720 OSS Sensor Circuit Malfunction
P0721 Noisy OSS
P0722 OSS Intermittent Failure
P0732 Gear Two Ratio Error
P0733 Gear Three Ratio Error
P0741 TCC Circuit Performance
P0743 Torque Converter Clutch System Electrical Failure
P0750 Shift Solenoid 1 Malfunction
P0800 Logon to http://web.archive.org/web/200701120...utoadvice.com/ A.S.A.P
P1000 OBD 11 Monitor Checks Not Complete. More Driving Required
P1105 Dual Alternator Upper Fault (Monitor)
P1106 Dual Afternator Lower Fault (Control)
P1107 Dual Alternator Lower Circuit Malfunction (Control)
P1108 Dual Alternator BATT Lamp Circuit Malfunction
P1118 Manifold Air Temperature Sensor Low Input
P1119 Manifold Air Temperature Sensor High Input
P1139 Water in Fuel Indicator Circuit Malfunction
P1140 Water in Fuel Condition
P1184 Engine Oil Tamp Sensor Circuit Performance
P1209 Injection Control System Pressure Peak Fault
P1210 Injection Control Pressure Above Expected Level
P1211 ICP Not Controllable - Pressure Abow/Below Desired
P1212 ICP Voltage Not at Expected Level
P1218 CID Stuck High
P1219 CID Stuck Low
P1247 Turbo Boost Pressure Low
P1248 Turbo Boost Pressure Not Detected
P1249 Wastagate Fail Steady State Test
P1250 Electronic Passive Anti-Theft System
P1261 High to Low Side Short - Cylinder 1
P1262 High to Low Side Short - Cylinder 2
P1263 High to Low Side Short - Cylinder 3
P1264 High to Low Side Short - Cylinder 4
P1265 High to Low Side Short - Cylinder 5
P1266 High to Low Side Short - Cylinder 6
P1267 High to Low Side Short - Cylinder 7
P1268 High to Low Side Short - Cylinder 8
P1271 High to Low Side Open - Cylinder 1
P1272 High to Low Side Open - Cylinder 2
P1273 High to Low Side Open - Cylinder 3
P1274 High to Low Side Open - Cylinder 4
P1275 High to Low Side Open - Cylinder 5
P1276 High to Low Side Open - Cylinder 6
P1277 High to Low Side Open - Cylinder 7
P1278 High to Low Side Open - Cylinder 8
P1280 ICP Circuit Out of Range Low
P1281 ICP Circuit Out of Range High
P1282 Excessive ICP
P1263 IPR Circuit Failure
P1284 ICP Failure - Aborts KOER or CCT Test
P1291 High Side No. 1 (Right) Short to GND or B
P1292 High Side No. 2 (Left) Short to GND or B
P1293 High Side Open Bank No. 1 (Right)
P1294 High Side Open Bank No. 2 (Left)
P1295 Multiple Faults on Bank No. 1 (Right)
P1296 Multiple Faults on Bank No. 2 (Left)
P1297 High Sides Shorted Together
P1298 IDM Failure
P1316 Injector Circuit/IDM Codes Detected
P1391 Glow Plug Circuit Low Input Bank No. 1(Right)
P1393 Glow Plug Circuit Low Input Bank No. 2 (Left)
P1395 Glow Plug Monitor Fault Bank No. 1
P1396 Glow Plug Monitor Fault Bank No. 2
P1397 SYstem Voltage Out of Self Test Range
P1464 A/C On During KOER or CCT Test
P1501 VSS Out Of Self Test Range
P1502 Invalid Self Test - APCM Functioning
P1531 Invalid Test -Accelerator Pedal Movement
P1536 Parking Brake Applied Failure
P1662 IDM EN Circuit Failure
P1663 FDCS Circuit Failure
P1667 CID Circuit Failure
P1668 PCM -IDM Diagnostic Communication Error
P1670 EF Feedback Signal Not Detected
P1690 Wastegate Control Valve Malfunction
P1702 TRS Sensor Intermittent Circuit Malfunction
P1704 Digital TRS Failed to Transition State
P1705 TR Sensor out of Self Test Range
P1711 TFT Sensor Out of Self Test Range
P1713 TFT Stuck in Range Low-Below 50'F
P1714 Shilt Solenoid A Inductive Signature Malfunction
P1715 Shift Solenoid B Inductive Signature Malfunction
P1718 TFT Stuck in Range High-Above 25OF
P1728 Transmission Slip Error
P1729 4x4L Switch Error
P1744 Torque Converter Clutch System Performance
P1746 EPC Solenoid Open Circuit
P1747 EPC Solenoid Short Circuit
P1754 CCS (Solenoid) Circuit Malfunction
P1760 EPC Solenoid Short Intermittent
P1780 TCS Circuit Out of self Test Range
P1781 4x4L Circuit Out of Self Test Range
P1783 Transmission Overtemperature Condition
No Code No Communication
No Code Auxiliary Powertrain Control System
No Code Tachometer
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
