What is the original model/manufacturer of Intelbras WRN-150 router?
Intelbras used to be a OEM customer of other manufacturers. Maybe this model was just "renamed". I wanna know if it is compatible with DD-WRT/Tomato firmwares.
  • 7,733 Answers
  • 15 Answers
SOURCE: 3rd party firmware broke my router!
did you check whether you have downloaded the correct firmware for your linksys???
Posted on Dec 04, 2007
jeicrash
  • 320 Answers
SOURCE: wrt150n dd-wrt firmware slow loading pages
First off thanks for using fixya.com
Second, I too am a dd-wrt user and found a similar problem when using dd-wrt with my IPCOP. You may want to go into the "Security" section of your dd-wrt and disable any fire walling or access-restrictions. Since you are already running zonealarm. Or remove zonealarm if you plan to use dd-wrt as your firewall.
Running multiple firewalls will slow down your network/Internet traffic.
Hope this helps you out.
Jei
Posted on Dec 15, 2008
Roynice152
  • 88 Answers
SOURCE: Wrt150n, Flashed with DD WRT.
You probably need to update a newer version of firmware. Here is a link for you.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Posted on Feb 13, 2009
compucure
  • 61 Answers
SOURCE: I need a dd-wrt firmware for belkin f5d7132. Or if
Have you tried here:
http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D7132uk&aid=6357&scid=0
Posted on Mar 15, 2009
SOURCE: My linksys wrt54G v6 router has a blinking power
Understand that what you are trying to do, may permanently turn that router into a piece of trash. Firmware upgrades are hit and miss, and sometimes even doing everything correctly will result in a "Bricked" router. A bricked router is one that is about as useful to a computer as a brick. Proceed at your OWN RISK!
Read all directions BEFORE you try anything! First D/L the correct firmware for your router. Then D/L TFTP.EXE from the DD-WRT site. Put these files right on the desktop where you can find them and unzip the firmware. (I am assuming you are running Windows XP)
Now connect your router to the computer you are using with an Ethernet cable and plug in the power. DO NOT TRY THIS VIA WIRELESS!! Then you need to set your computer to a fixed IP address, Open your network connections (control panel - Network Connections) right click your local area connection and select properties. Highlight Internet Protocol(TCP/IP) and again select properties. Under the General Tab select "Use the following IP address" enter 192.168.1.99 Under Subnet mask enter 255.255.255.0 Click OK and wait for the TCP/IP connection to be established. The router first must be reset to the factory default configuration BEFORE you flash it.
Resetting the router means, with the router plugged in to a power source hold down the reset button (on the back of the router) for 30 seconds, then pull the power but continue holding the reset button for another 30 seconds. Then WHILE STILL HOLDING THE RESET BUTTON, plug the power back in and hold it for another 30 seconds. Now you can let the button go and allow the router to reboot.
If you still have only the power light blinking, try pinging the router. Open a command prompt, (Start RUN CMD [Enter]) and type PING -t 192.168.1.1 Leave this window open and dbl-click the TFTP.exe program. There are three empty boxes in the TFTP program. Enter the IP address of the router in the server box (192.168.1.1) enter ADMIN (all lower case) in the password box and click the dots next to the file box, browse to your desktop and select the firmware image you downloaded (.BIN)
Now if your ping command is only returning "Request Timed Out" try resetting the router again only this time watch the ping window for a response from the router. If you get a response, immediately click "upgrade" on the TFTP window. If all goes well you should get an "Upgrade Successful" message. This step is important!! RESET THE ROUTER again after waiting 10 minutes. Now if the router was not initially reset to the factory default configuration before someone tried to upgrade the firmware, it is possible that the router is hanging while it tries to boot and the firmware image was corrupted. If that is the case then you will need to read the DD-WRT Wiki under "Bricked Router". Good Luck!!
Posted on Dec 11, 2009
What is an OEM cartridge?
OEM (pronounced as separate letters) is short for original equipment manufacturer
The Cartridges for the HP DeskJet 3740 InkJet Printer are:
HP 27 Black Original Ink Cartridge
HP 28 Tri-color Original Ink Cartridge
These can be purchased from your local store that sells HP Printers & ink or by going to HP.com and ordereing direct from the Manufacturer
May 01, 2014 | HP DeskJet 3740 InkJet Printer
Tip
IPhone 5 LCD Screen and Digitizer Assembly
Product description
Reviews
Part: Apple iPhone 5 LCD digitizer
Manufacturer: OEM (3M)
Condition: Factory new
Warranty: N/A (consumable)
Parts Origin - OEM
The term OEM stands for 'Original Equipment Manufacturer', the exact meaning differs in several industries.
To us, OEM means that the part is the same part used within your device, using the same materials and specifications.
We use the term OEM to cover many parts from refurbished, used and new components, the exact condition will be stated in the items description.
In some cases when the part supplied is made up to several components (for example an LCD assembly) the part may have been assembled by a 3rd party vendor using OEM parts meaning that consumable may differ (such as adhesive used)
Although strict testing procedures are put in place to ensure the quality of the part these testing practices and procedures may differ from the checks manufacturers use.
Any hardware supplied as OEM will not have any quality loss or loss of features and covered under our extensive returns policy.
As in many cases we dont obtain directly from the devices manufacturer, nor in some cases are we affiliated with device manufacturer in any way and they are not involved in the testing or sales process of the component we sell.
on May 08, 2017 | Apple iPhone Cell Phones
I cannot reset my password
Im presuming its your internet connection password ?
Your Internet service provider (ISP) requires a username and password to access service features, including Internet and email.
Your ISP should provide this information when you set up your Internet service.
Typically, once you complete the setup and save the information, your router or modem transmits it behind the scenes when you try to access the Internet.
As a result, the username and password can be easily forgotten because they are not used daily.
If you reset your router or simply forget the password, gaining access to network resources and the Internet becomes a challenge.
Call your ISP's technical support department.
Many ISPs set a default username and password for their routers.
If you didn't change the username and password, your ISP can provide the original information.
Before you hang up, make sure the information is correct by entering it and trying to connect to the Internet.
If the information is incorrect and you still cannot get a connection, keep the information for later reference.
Call your router's manufacturer.
The manufacturer of your router sets a username and password prior to shipping the device to your ISP.
Look at the router for the contact information of the manufacturer.
Call their customer service or technical support department and ask for the default information.
Reset your router.
If you changed your router's username and password and cannot remember what you entered, you may have to reset the router.
Insert the resource CD into your computer's CD drive.
When the software installation program starts, search the screen for "Resources" or "Documentation" or "User Manual."
Click the documentation link and search the table of contents for resetting the router.
When you reset the router, the username and password return to the default set by your ISP or manufacturer.
Enter the information provided by your ISP or manufacturer.
Hope this helps.
Nov 15, 2012 | Computers & Internet
Circuit board repair
ACS repairs most makes and models of circuit boards. If you do not see your manufacturer in our LIST OF OEM MANUFACTURERS, don't worry. We can probably repair your item. Call to speak to one of customer service reps for help, 1-800-605-6419, email at service@acsindustrial.com, or use our Contact Page
bathroom light
May 08, 2012 | Dyson Dryers
I need manual book for intel desktop D865GMR motherboard
This board isn't listed on Intel's download center under 865 chipset models. This typically means your board was specially made for an OEM (original equipment manufacturer). OEM boards often have custom connectors, modified hardware, and different BIOS functions than the retail versions. You can try downloading some of the manuals for other 865 boards and see if any of them look close to your board, or you can try the computer manufacturer's website and see if they have more detailed information available.
Jan 30, 2011 | Intel LAD865GMR Motherboard
The Dlink DIR 601 N 150 is using 802.11g to connect to my new laptop, rather than 802.11n. The router is set for mixed mode. The laptop supports 802.11 b/g/n. Shouldn't the router switch up automatically...
Yes it should.
Be sure that you have installed and are using the manufacturer's drivers and support software for the WiFi adapter in your laptop.
If you're using stock Microsoft drivers and support software, you'll only be able to use the 802.11G at the best.
Tell us the make and model of the laptop and I'll try to find the appropriate drivers.
Dec 24, 2010 | D-Link Wireless N 150 Home Router 4Port...
Send us front panale led's conection please
we need to know the pc manufacture and model along with if you are using a OEM case (the original pc case) or a custom built pc case
Dec 12, 2010 | Computers & Internet
Nokia 5800 OEM
OEM generally means "original equipment manufacturer." Sometimes it is referred to as "bulk packed", "white box", "brown box" and "gray market".
Almost all PC component and software vendors make two versions of the same product based on a difference in the distribution channels. Retail ("distribution") is the main consumer channel, whilst OEM (to various systems manufacturers) is another.
The retail channel typically uses colourful retail boxed products, with installation manuals, software CDs etc. Of course the cost of making the nice-looking packages is passed on to you, the customer. Retail packages are also more voluminous, and therefore cost more to ship. The OEM channel distributes products mainly to system builders and integrators, for example Dell, HP and Sun (the OEMs) and many small ones such as the mom-and-pop shop on the corner and embedded systems designers. These bulk-pack products do not have fancy packaging materials and are often produced in much higher volume, both of which result in much lower prices that are not generally available to the public. The OEM products are of the same quality as their retails counterparts. However sometimes the manufacturer warranty is different, shorter or non existent. They also tend not to include supporting materials such as manuals and drivers when applicable, however these are available for download (which tend to be more current versions anyway). Where ever possible DiscounTechnology.com distributes and sells the OEM versions of products (e.g. SCSI hard drives). This allows our customers to benefit from substantially reduced capital costs and much improved return on investment (R.O.I.). Besides the packaging and prices, there are sometimes other subtle and not-so-subtle differences between the retail and OEM versions of a product. Here are a few examples.
Warranty: Many types of OEM hardware components come with the same warranty as retail boxed ones. One well-known exception is hard drives. Retail boxed hard drives often come with a three or five year warranty, while the warranty of OEM drives is the responsibility of the reseller. Please check the product page for Limited Warranty information where applicable. We believe the substantial price savings of OEM hard drives easily justifies the difference in the warranty. Some of our OEM drives are 50% the price of a retail drive. That means you'd have to have more than two drives fail after the end of our warranty, but before the end of the retail warranty before the retail warranty would save you any money. That assumes that the replacement drives are the same price in the future. However as we all know, technology price continually drop. So in 5 years when your drive is likely to fail, how much will a replacement be? Will you want the same "small" capacity in five years anyway?
N.B. Many computer systems manufacturers (e.g. IBM, Dell, HP) will ONLY warranty drives installed in their systems if the drives have their OEM part numbers. So if your server or system has an active warranty, it may cover our OEM drives, if you select a part with a OEM part number from that same manufacturer (meaning Dell OEM for Dell servers etc.).
Bundled Software: Sometimes the retailed version comes with bundled applications software, whereas the OEM version may not. This is especially true for high-end video and audio cards. How useful such bundled software is to you needs to be carefully weighed against the price difference.
Manual and Support: The hard-copy manual for the OEM version may be limited to one per shipping box. However, the vast majority of information is on the manufacturer's web site. Some manufacturers claim that they do not support their own OEM products. The OEMs are supposed to do the support. In such cases, discountechnology.com will provide the technical guidance to help you install the product.
Thanks.
Sep 07, 2009 | Nokia 5800 XpressMusic Smartphone
What are OEM cartridges
Hi mjohn542, In inkjet printing, an OEM (original equipment manufacturer) cartridge refers to the ink cartridge that comes with an inkjet printer, or replacement cartridges that are manufactured by the original manufacturer of your printer Hope this answer's your question, and don't forget to leave a rating. Thanks Mark
Apr 23, 2009 | HP DeskJet 6450 Printer
Stk392-110 chip replacement
stk392-110/150/180 all have same fit, form function except the 150's and 180's are basically upgrades for they're more stable (more heat tolerant than the original 110's); I'd buy the 150/180 myself; you can get the stk392-180 for just under 10 bucks on eletronix.com.
Mar 24, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
