Question about Dodge 2008 Dakota SLT
I need to know how to fix my passenger side window will not work is there a fuse somewhere
    Genius:
  • 1,552 Answers
Yes, there is a fuse.
But, it could be a broken wire between the control and the motor.
Or, it could be a dead motor that moves the window.
Posted on Jun 05, 2015
How do i find my passenger window fuse my window want come down
Your fuse box will have a diagram inside the removable lid. The fuse box should be at the side of the steering wheel open the drivers door to gain access. If not there then maybe on the underside of the dashboard (above your knees) on the driver or passenger side. Otherwise it may be either side of the central console. Just imagine all the wires behind the dashboard have to be connected inti it so it will be somewhere convenient. The window fuses will be separate front/rear and their numbers will be given inside the fuse box cover.
good luck!
Jun 19, 2014 | 2003 Saab 9-3
Driver side window / door lock buttons not working?
a wrecking yard door switch is probally your fix ,but a proper diagnosis is the best way as the window motor may have gone.
know someone how can take the door apart without breaking the door panel ? remove door panel plug switches back in. unplug motor test with test light for power( power flips + becomes - ,- becomes + )as you test (up, down)if you have power its the motor if you have no power its the switch ( u stated others work so its not a fuse issue). my money is on the switch good luck
Jun 03, 2014 | 2002 Pontiac Bonneville
Television was turned on with remote and 10 minutes later it turned off and would not power back up. tried another outlet and it still would not work. also red doesn't light up at the bottom.
well.. sadly with electronics, is alot of times they honestly just instantly stop working, id plug it in and search for a reset button if it might have one. with prices of tv's these days, honestly probably cheaper to get another one then pay to have that one fixed.
If you know how to take some of it apart you could see if it has a fuse somewhere, most people dont think about it but alot of electronics have fuses to protect them from surges etc, and its as simple as replacing the fuse, would be inline with power cable somewhere
Nov 01, 2013 | Dorman 749-707 Mercedes-Benz C Class Rear...
Passenger side automatic window switch is not working in my 2004 Chevy Aveo. The window is operational from the driver's side master switch but not the passenger side. Im thinking its a fuse or a relay,...
Make sure the window lockout button is not depressed on the master window switch. This will turn off the other switches and not let them control there respective windows.
Power is supplied to all the windows from one fuse and one relay. So if the master switch operates the window than we know the fuses and relays are o.k. We know the master switch will operate the window so that tells us the window motor and ground side of the passenger window motor circuit are also good.
Which leaves us with a bad switch or no power to the switch. The passenger window switch gets its power to operate independently from the master switch window lockout button. When the button is off power is supplied to the passenger switch and allows the passenger to operate the window themselves.
The only thing you need to do is check for power at the passenger switch on the brown wire with orange stripe. If there is power there then you have a bad switch.
Oct 08, 2010 | Chevrolet Aveo Cars & Trucks
Passenger window won't work its elelectric, acts like no power to it. Is there a fuse I have no book and can only find the master fuse box under hood?
Hi their is only one fuse for the windows and thats the one you have checked, if the other windows are working then the fuse will be ok.
if the drivers door has a seperate control for the passenger door try this and if it wont work from either the passenger side or the drivers side then the problem is going to be either the motor or the regulater and these are both inside the passenger door.
if how ever the drivers and passenger controls are seperate and you cant control the passenger side for the drivers door controls then what you can try is swapping the switches over from the drivers door to the passengers door, if the controls are the same then all you need to do is get a flat bladed screwdriver and pry the control up as its only pushed into place then unclip the wires and swap the switches over then if the passenger side then works you know you need to get a new switch of it still dont work then it will be either the motor or regulater at fault.
either way the door panel will need removing and you will need to test if you have any power going to the motor.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 15, 2010 | 2006 Dodge Grand Caravan
Passenger power window quit working...is it a fuse or breaker or what? The drivers window works fine.
hi, if the drivers window works fine then this suggests the fuse is ok, if you can control the passenger window from the driver side and it dont work and the switch on the passenger side dont work the window then this would point towards either motor or regulator at fault, if the drivers side and passenger side switch are the same then you can swap the switches over all you need to do is pry them out and unclip the wires and swap them over this way you can test if its the switch at fault or the motor.
let me know how you get on or if you need further assistance ok
Jun 13, 2010 | 1998 Chrysler Town & Country
Drivers side window wont work and power locks dont work ,mirror works, passenger window works
I have the exact same problem. Fuses look good, I have no idea what the problem is?
Jan 16, 2010 | 2005 Chevrolet Colorado
Passenger side elec window not working
try to take the passenger side and hook it up to the drivers side then you will know if its a fuse or the window switch it self.
Apr 26, 2009 | 2006 Suzuki Swift
Electric windows are not working,fuses ok and no power to switche
Have a '83 Porsche 944 and replaced the passenger side power window motor a while back and now have a short somewhere in the dash that I need to fix. But the passenger window is down and I need to know how to raise it without the motor.
Apr 10, 2009 | 1983 Porsche 944
Power windows
As long as the windows will work fine some of the time, it sounds like the problem is in the power supply and replacing the fuse should fix it, otherwise there may be a loose wire somewhere in the circuitry.
Jun 03, 2008 | 2005 Dodge Caravan
Dodge 2008 Dakota SLT Logo
315 people viewed this question
Top Dodge Computers & Internet Experts
Gene
D. E. Hev
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
