Question about Optics
Walters GSP.32 S&w long wadcutter Serial #102108
Lever jambed open with 3 wadcutters in it. how do i clear it?
Remove the magazine end cap with spring and follower. At least two rounds should fall out. If one is caught on the carrier, the lever has to be removed, then trigger plate and then carrier.
It sounds like a shell stop is out of time.
Mar 06, 2015 | Optics
I bought it used and it shot well put 4 38sp wadcutters in it when i pulled lever back it locked up one shell fell out. can i tak it apart? what do i do?
Still this Marlin '92? It's not made to shoot wadcutters in. Try 158 gr. round nose. The overall length of the cartridge has to be long enough to give the shell stop time to work. You see what happens when it doesn't.
I have a breen world GSP-72T and i need a new thermostat but cand find where they sell any
http://parts.turboairinc.com/index.php?cPath=4 follow this link to the Turbo Air parts page. See if these match your thermostat. If not then call the number listed there to order yours...hope this helped you
Jun 09, 2012 | Turboair Turbo Air Sandwich Salad Table...
I have a crate cpb150 amp i want to connect it to my digitech gsp2101 via livewire stp-202 cable what is the correct way?
I can understand your confusion... and a lot depends how you are going to use this. There are some caveats regarding the connections,
If you use the 1/4 outputs on the GSP, there is a speaker modeling like function that is NOT available, that IS available IF you use the XLR outputs.
The STP is an "Insert Snake" which is not really what you want as it is intended to send and receive (audio going both directions in the cable.
If you want that speaker function, then you should get two XLR to 1/4 TRS cables and go from the XLR's on the GSP to the Left and Right inputs on the back of the Crate. Your audio or guitar then is connected to the GSP guitar input.
If you connect the guitar to the crate and then use the STP, Plug the TRS single connector into the Left/Mono/send/rtn on the Crate. The Send cable of the Y should go to the Send jack on the back of the GSP and the return should go to the left return jack of the GSP. This connection I would NOT recommend as it will be noisier and you will lose the stereo effect capabiltiy since the effect is inserted as a mono.
I believe you would be happier with using the XLR's to carry left and right to the Crate and run your inout to the GSP. In short, you have the wrong cable to do the best job.
Jan 30, 2010 | Crate Music
Optics Logo
56 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
