Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: zenith zn110
1. hold in "code search" till light stays on
2. press channel up until tv changes channel
3. press enter as soon as channel changes
note: if you pass the right code just use channel down to get back to it
SOURCE: toshiba tv code for Zenith remote
Check the manual for your Zenith; many of the Zeniths (and many others) have a 'scan' mode you can call up, in which you can repeatedly press one key (^ for example), then the Power Button. That will force the remote to set every code it has available, step by step.
If you no longer have the manual, you may find it here or several other sites that offer these.
SOURCE: programming
push the tv button then hold down the code search button till the light becomes solid. point the remote at your tv while it is turned on and push the channel up or down til the cannel changes. once it does push the mute key to save. so u know this works like that on all device and if you pass up the right on from pushing the button too fast you can just push the opposit direction rather than waiting for full circle. also be aware that there are multiple codes for some devices and some work better than others.
SOURCE: programming my RCA311B remote control
Here are the codes themselves: http://www.thompsontv.com/rcarc.html
Here's the manual with how to do the input (as suggested by TVtechmechanic):
http://157.254.235.130/public/IBRCR311BREVA.pdf
That's how I did it.
SOURCE: Programming a RCA Remote to a Zenith TV
this link will take you to the RCA site where you can access your remotes codes and instructions (model # of remote is listed on the back or under/inside the battery door in not on the face)
Thanks for using Fix Ya, please take the time to rate this solution.
clarkco.
[2] Point the remote control towards the
television
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
