How to fix the on/off switch on a Brownie 8 movie projector model A15 ?
The on/off switch is stuck from not using it for years. It's plastic.
2 Suggested Answers
gopakumarg43
  • 75581 Answers
SOURCE: Need relacement buld for Brownie Movie Projector Model 1, bulb 300-watt, 120-volt,T81/2. S.C. bayonet base, C-13D projection lamp
Hello
You haven't specified anything about your projector or other detalis about it. jsut get into this link, and see whether the lamp you want is available there or not. You have to search with its number. It will have a model number on it. OK
http://www.visualapex.com/accessories/lamp-projection-tv.asp?MFR=DNGO
Posted on Dec 13, 2011
Will the bell and Howell model 256 dhow super 8 film
No it won't.
http://store.tvedenlampmodules.com/Vintage-BELL-HOWELL-256-AB-8mm-HOME-MOVIE-FILM-PROJECTOR-w-LAMP-CONVERSION-P5123061.aspx
To be crystal clear; This is a Regular silent movie projector. It will not run, or play Super8, or Super 8mm movie films, with or without sound.
Bell howell autoload 8mm projector user manual english
Dec 05, 2016 | Cameras
I am doing the right sequence for the maintenance wash cycle on my Kenmore HE4t but it won't start. It used to work but haven't had time to do it in over a year... What should I do?
Have someone with an electric meter and some washing machine knowledge release the top of the machine to access the lid switch. The lid switch being stuck can prevent it starting.
These are cheap plastic units, easily replaced.
God bless your efforts.
Sep 08, 2016 | Kenmore Washing Machines
My dishwasher Fagor fi-80 just fills continuously, till overflowing. How should it know its full? I cant see any sensors.
It uses an air bell to turn the depth of water into air pressure, then a pressure switch senses this pressure.
Down inside the wash tank, you'll see the air bell. Usually grey, a flattened rounded rectangle tapering wider towards its lower end, stuck to the side of the tank.
Take the panel off the machine, and on the dry side of the tank you'll see a little hose leading away from the bell towards the pressure switch.
Four of the more common failures....
1) Water valve stuck open. It'll keep filling even with the electricity turned off.
2) Air bell leaking. Crumbling plastic bits not unknown, this machine could be 15 years old by now.
3) Pressure switch stuck. Blowing into the switch you should hear a 'click'.
4) Most common - a build up of fat in the top of the air bell, blocking the sensing tube. With the machine empty of water, take the pipe off at the pressure switch end, and blow into it. This should dislodge any fat/debris. In extremis, slacken the nut holding the air bell to the tank, rotate the bell upright and give it a good wash out.
Mar 07, 2016 | Dishwashers
How do I fix brake lights stuck
For a number of years, automakers have used a "standard" type of brake light switch set-up.
That is, they put a plastic switch in a metal or plastic holder above the brake pedal arm under the dashboard, so that when the driver pushes their foot on the brake pedal, the arm goes toward the floor, and the brake light switch is "closed", (the plunger in the switch extends) allowing the current to flow to the brake lights.
Common problems then, are:
The plastic switch comes out of the holder, allowing the push button to extend, and keeping the brake lights lit.
Or, the switch fails, same as above.
Or the plastic stopper on the brake arm fails, again causing the plunger to stay extended.
Find a tiny person to stick their head under the dashboard, and you should see the problem.
Jan 01, 2016 | 1991 Toyota Corolla
Hi, my dad's Kodak Brownie 8 A15 regular 8mm film projector has an issue with the knob. It will turn to the rewind position but not Project. Does it have to be pushed in ? I hate to force it.
http://www.grantmillar.net/kodak-brownie8-manual-15-g-version1.pdf. Doesn't seem to need it. Check to make sure the knob hasn't turned ie off is project and rewind is off and there is another setting after rewind.
Nov 18, 2014 | Kodak Office Equipment & Supplies
Kodak m67 8mm movie projector struck in rev lever can be move to forward but miss run backwards
it is hard to explain but there is a metal pin on one of the mechanisms it can become bent out of place. you need to remove it and heat it up and put back straight. dont try to bend it straight as it will snap or the pin will come out of the metal part.
Oct 13, 2013 | Kodak 1950s/60s Brownie 500 8mm Movie...
Control knob on kodak brownie 8 will not turn
Hi Don,
I have the same problem with my dad's Brownie 8 Model A15 projector...however, the knob will turn to "Rewind", but not to "Project". Did you ever get yours to work? Thanks! Jon
Sep 02, 2013 | Kodak Cameras
? Is the sprocket wheel in the middle of the projector supposed to move? The film seems to be locked up in there, and only the few inches of film in the gentle curve above the lens seems to feed thro
I know this post is old but I found a solution. The axle going to the sprocket is locked up with something sticky. You have take out the two screws holding the white plastic piece around the sprocket. Then loosen the small bolt on the big wheel on the other side. Remove the big wheel. Try to push the axle through to the other side. If it doesn't budge easily, hammer it out. That's what I had to do. Then clean it up real good with solvent, like alcohol. Lube it with grease and put it all back together. Worked for me.
Jul 19, 2012 | Kodak Antique Brownie 300 Movie Projector
135 people viewed this question
k24674
jasbo
jasbo
