Question about Wahl 9307-1301 Cordless Mini Pro 14 Piece Touch-up and Trim Haircutting Kit, Chrome/black, Chrome/Bl
How would I put it back together?
I disassembled it to clean it, but now I have a lot of pieces that I do not know how to put back together.
Stiebel eltron thermostat in pieces
Replace it, when you disassemble it, there may be a problem with the way that it handles current.
Apr 16, 2013 | Water Heaters
Disassembled imac 21.5 late 2009 cleaned fans put back together powers up fans go everything sounds normal but it dosent come on my external monitor I can't use imac screen as it is broken
Assuming you had a working machine prior to cleaning it, I would suggest you visit this site to follow instructions for the 27". The procedures are very similar (and nothing currently available specific to 21.5 yet) Understand that the process requires very tedious gentle handling of several cable connections that CAN EASILY BE DAMAGED if you are not extremely careful. I have performed several disassembly procedures on these models and they MUST be done with the proper tools and precise attention to detail. If not you can easily damage the delicate connections. Every screw, fastener, piece of tape, has a specific purpose and any item left out will likely result in a failure. Retrace your steps using the instructional guide (linked to above) and you may yet save the day. good luck and take a deep breath before starting!
Apr 09, 2013 | Apple 21.5" iMac Desktop
The lense for my Nexstar 6se was taken apart and I don't know how to put it back together properly. HELP!!
The eyepiece should NEVER BE DISASSEMBLED! Since it has multiple lenses inside no one can tell you how they go back together. This also voids the manufacturer warranty.
Go and buy another eyepiece and NEVER ever disassemble them. Only the OUTSIDE surface ever needs cleaning,
Here is one retailer who sells eyepieces.
http://www.agenaastro.com/
Sep 05, 2010 | Celestron Nexstar 8i Special Edition (480...
Putting glass and washer together
  1. Place glass container upside down on safe working area.
  2. Place rubber gasket/ring on top of opening first.
  3. Place stirring or mixing blade on top of rubber gasket/ring.
  4. Take the plastic retainer and screw it on over everything previously assemble.
  5. Hand tighten only enough that you can reverse the whole operation when comes cleaning and disassemble time.
Feb 13, 2010 | Elite 072-04-1198 Blender
My 9t eye piece was rattling and mislined. I took it apart cleaned lenses and wondered is there a lense location or direction?
Never disassemble an eyepiece unless you know exactly how to put it back together. Only the outer glass lens ever needs cleaning.
Without knowing exactly what link of eyepiece you have (they are all different designs) it's impossible to tell you which way the internal lenses go.
Your best bet may be to simply purchase another eyepiece.
http://www.agenaastro.com/Telescope-Eyepiece-s/3.htm
Nov 07, 2009 | Tasco Astronomical 302675 Telescope
Timer knob assembly, how to disassemble and assmble back together
It sounds like the only thing you are missing is the circlip to hold the whole lot together.
With it de assembled you should see a cut out part on the timer stem that's where the circlip goes when it's all back together
Jun 11, 2009 | GE Washing Machines
Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
May 20, 2009 | Conair GMT200TD
Trying to figure out how to put back together an old 1950's Merritt and o'Keffe stove that someone took apart to clean and couldn't put back together again. It worked before they tore it apart but is in...
Good luck. I would myself try to find a general stove schematic and work out how different it is. There may be a few different rated thermostats and elements, but the bulk of the wiring pattern will be similar.
It may have to come a bit of trial and error as well.
(also, they disassembled the wiring to clean it? that's thorough!!)
Hope this helps, let me know.
May 09, 2009 | Kitchen Ranges
Taking out the color wheel
Well, if you could hang on for a few hours, I could ask my husband. I know he had to pull all the little plugs out of everything and basically remember where they go after to put it back together. I know after unhooking everything, and undoing the plug wires, the whole piece slid out and then he was able to disassemble the casing and get to the wheel. Then he just used a lens cleaner cloth to clean everything. Let me know if this helps.
May 23, 2008 | Toshiba 52HM95 52" HDTV Projection...
Wahl 9307-1301 Cordless Mini Pro 14 Piece Touch-up and Trim Haircutting Kit, Chrome/black, Chrome/Bl Logo
361 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
