Question about Toys
Kikkerland Awika wind up toy came stuck and just won't work. The main gear is blocked, how do I fix this?
Are wind-up toys dangerous for toddlers?
Usually wind-up toys should not be given to children under the age of three.
It is true that wind-up toys have the upside of moving and turning thanks to wind-up mechanisms and therefore don't need any electrical element that could be dangerous for kids. However, as wind-up toys are sometimes very small or have small parts that easily come off, whoever is taking care of the toddler should be aware of the wind-up toy's elements and make sure that they won't come off if the toddler puts the toy in his mouth, or that the toy itself isn't small enough to be swallowed, causing soffocation.
Dec 26, 2013 | Toys
Gator won't work in 2nd Gear
sounds like you have a bad motor, you'll need to pull the dump bed off to acess the motors and disconnect one and then see if it works
May 22, 2013 | Peg Perego John Deere Gator HPX Ride on...
My Syma S107 bottom rotors won't turn. What is the fix?
Probably just the cog on the motor not meshing with the main shaft gear.
Kind regards, Julian
rccontrolfreak.co.uk
Aug 07, 2012 | SYMA Toys industrial New Syma S107 Radio...
Lost my sons combination to open mini vault bank
Turn right 39, then left to 6. I used a screw driver to open the case then reverse engineered the combo.
May 04, 2011 | Kikkerland Mini Vault Bank - Red
Moto frenzy rc bike. fully charged. rear wheel won't turn. front will go left/right.
I also had this problem during christmas. The bike worked only the first battery then the rear wheel stoped turning. The dissapointment was huge. And I read that there are a lot of people around that have the same problem. So I tried to fix it
The problem was a wire that was wound up in the main gear of the rear wheel. This wire cames from the inside of the bike, so I can imagine that a lot of people will have this problem.
So how to fix it?
It is quite simple to remove the wire parts from the gear. But it is not so simple to open the bike. There are 4 screws but when removing the screws and you try to open the bike it will not open.
The reason is that the gas cap on top of the bike is glued in. So i worked a little bit around of this cap with a stencil scalpel knife. But be careful right under the cap are the wires for the steering wheel. So dont go too deep. Once opened you can easy remove the rear wheel and the gear to find the ugly wire wind up on the main gear. In my bike the wire was directly in the small gear on the main motor. It took a while to remove all parts of this wire.
But once removed the wire the main motor will turn again.
Put all gears in the right places and close the bike.
In my case all things are fine after this repair.
Good luck
Stefan
Dec 25, 2010 | Spinmaster Air Hogs Moto Frenzy R/c Stunt...
I have a takara godzilla egg and it no longer works properly. appears that one of the cogs slips. this cog is instrumental in winding up godzilla. any directions would be helpful. Regards, Bob
This is a very easy fix. I have a couple of these eggs and they all had the same problem. Count the number of teeth on the slipping main gear. do a google search on slot car gears and you will find what you need. The gear that goes on the slot car motor is what you want. Or, you can send it to me and I'll fix it for you! ckalkhof@oh.rr.com
Nov 19, 2010 | Takara Toys
Interactive r2 d2 gets stuck
There could be something blocking the drive gears to the treaded wheels making making the robot go backwards.
Apr 28, 2009 | Hasbro Star Wars R2 D2 Interactive...
Lens stuck and beeping
The lens is jammed.
This is a result of damage to the gear in the motor asssembly.
The gear teeth have been broken off & as a result the gears that drive the opening& closing of the barrel dont mesh together resulting in the jam and your 4 beeps!!
If your interested in selling it to me let me know.
Mar 03, 2008 | Samsung NV10 Digital Camera
Toys Logo
73 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
