Question about Building Materials
Is the rail suppose to level upon completion of installation or at roughly a 30 angle?
    New Friend:
  • 130 Answers
You want if you can the have the motor end a little lower than the front.. This way when the opener starts down its shoving the top section up a little instead of shoving down on it..
Posted on Apr 27, 2015
1988 Pontiac Lemans Runs Rough
i can recommend to RUN scanner/computer for easy diagnostics and fix . God bless you
any components can be faulty32cbf899-f6e4-4700-9849-2f8e8911acec.jpgd28e17fa-ceac-4b84-b842-b66ec79f6c63.jpg
Jul 11, 2013 | Pontiac LeMans Cars & Trucks
1995 ford 7.3 powerstroke automatic shifts rough after transmission installed after replacing rear main seal
-check your transmission fluid level. park the truck on a level surface with the engine running and pull your dipstick and read the level in regards to the engine and trans temp (hot or cold)
-if that checks out i would go under the truck and check all of the electrical connectors that go to the transmission making sure they are secure and making good contact. also check the wiring to the tcm(normally located on the right side frame rail if i remember correctly)and make sure they are all secure and in good condition
Did you do the rear main seal yourself or did you pay a garage to do it? and is there anything else that was done at that time?
Jan 22, 2013 | 1995 Ford F350
I have seen many nails that supposedly fit the senco sn4 nail gun. Some are 31 degree, some are 33 degree. All have paper collating. What angle nails should I search for to fit the senco sn4?
Senco uses 33 degree paper tape clip head, however many generic brands will label their box 30-34 degree to fit several nailers. This practice causes jams in some guns and others work fine. The goal is to save money but could cost more in the long run if gun is damaged. You can use generic (other than 33) if you take a strip of nails and place them against the outside of the rails aligned with either the line of driver path of angle of the rails. This will give you a visual as to the alignment. Best result is when the complete nail is in line with the path of driver. Next best result is when the head is in the path of driver and point of nail is slightly away from path, worst is when point hits path and head is back. Good luck
Mar 26, 2011 | Senco Air Tools & Compressors
Rough idle and backfire at low end RPM
Spark plug or plug wire
After that look to your coil
Mar 30, 2010 | 2000 Suzuki VS 800 Intruder
I have a 2003 Coachmen Freedom Class C. I want to
I have a Coachman "Road Trec" class C and I installed my scissor jacks near the frame member for the front just to the rear of the bumper. I installed a length of angle iron from the left frame rail to the right frame rail then installed the jacks on the angle iron as close to the frame a possible.
On the rear I cut a piece of 3 " angle iron and bolted it to the outside of the frame then mounted the jack on the angle iron for each side.
Nov 06, 2009 | 2003 Chevrolet Express
When i backspin the arm is forcing itself off the vinyl
IMO the problem can be solved in 2 ways, either move the counterweight on the back of the arm towards the turning point of the arm ( by just adjusting it 10 - 20 % of an whole spin you can adjust a lot), or buy an other needle which is heavier then this one...
Jan 29, 2009 | Technics SL-1210 Turntable
Screen flickers for about 20-30 seconds sporadically
Try looking at the LCD screen at a sharp angle to see if ghost-like video can be seen during the 'off' time of the flicker.  If video is still present even though not that visible, then either the backlight or its power supply are failing. The color problem could also be caused by a backlight lamp that is not ionizing completely.
Dec 14, 2008 | Acer AL1912B 19" LCD Monitor
Window A/C drainage
a little more than 1/4 inch per foot. or a 4/12 pitch.
Jul 21, 2008 | Heating & Cooling
Marking out for steel railing
need more info. are you trying to mark the wall or figure out your bend angle for the railing? if wall, measure your rise in one foot of section[ use a level to get the number.one end of level on point of line one foot from corner, measure up to get #] then start from corner and restart your line with rise found.
Mar 23, 2008 | Grilling
Building Materials Logo
119 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
