Require user manual
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
SOURCE: viera link pop up problem...ANNOYING
You need to (either or both) change from Shop setting to Home, and turn off Viera Link demo.
Go into the menu, choose set up and re set to shipping settings.
SOURCE: Windows 7 media centre is
You need to connect the tv on the network, press the green button on the remote, follow the instructions and the code will appear on the screen. But only few models of selected countries of these tv's have the Media Center Extender capability - if the tv that you bought doesn't have the Green button then you can't pair it up with your pc. In that case you will have to connect it to a router and configure it just like another pc - not directly to your pc.
SOURCE: Panasonic TX-P50G20B How to connect Panasonic
You need to run a DLNA server on your Windows 7 PC, I recomend using a program called Serviio:
http://www.serviio.org/
Simply download and install, select the folders that you want view on your TV and you should be viewing your films and pictures in no time.
SOURCE: Panasonic Viera 50" TV (THP50S20A) The
Most major manufacturers supply manuals
online so if you were to log on to the manufacturer's web site, you
may be pleasantly surprised as usually, if available, one is able to
download, by model number, Customer
Instruction Manuals, Dealer
Network for spare part supplies as
required. The information is normally free of
charge. I hope this helps.
