Question about Honda Gx340 Gas Engine 11hp Motor Pressure Washer Ect
It will crank and run good for 10 minutes and shut off. Once it shuts off when you restart it, it will only run for a couple of minutes and shut off again ?
I have replaced the Carburetor, fuel and air filter, changed the oil and replaced the spark plug.
    Sergeant:
  • 157 Answers
I would start by getting a can of carburetor cleaner and have it 'at the ready' and try the 'start, run stall, start run stall' operation again. Only THIS time, once the engine begins to stall, give it a couple of quick shots of the cleaner into the air filter to see if it stays running on the cleaner.
If it does, then it's still a fuel problem. If it doesn't, then it probably an ignition problem. I would be sort of leaning towards the ignition coil getting weak. The reason I'm saying that is your statement about it running (I'm assuming cold start) for at first, 10 minutes then it stalls. Start it again and it runs for a couple of minutes and stalls again.
This could possibly be from the coil getting warm/hot and not producing the needed spark. After a 10 minute run it simply gets too hot and stalls the engine. After the next restart, the coil is already warm from the engine and so it don't take as long for the coil to get hot and stall the engine again.
Hope this makes sense and helps you out.
Posted on Apr 25, 2015
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
Runs good for 10 minutes and then shuts off after it cools off it restarts
It is either the cam sensor or the crank sensor both will set check engine light, and shut car down. If the light is on get it scanned Any auto parts store will do this for free! po340 is camshaft sensor, if car stops and starts in 10 to 20 minutes ( a bad crank sensor will cause this.
Oct 14, 2015 | Cars & Trucks
Does chevy s-10 have afuel shut off button or switch
Might be air sincere try blocking air filter hole and starting,check fuse,
Sep 16, 2014 | Chevrolet 1999 Chevrolet S10 Pickup fuel...
After I drive my jeep some, if it is somewhat warm or not cold weather, my jeep has a hard time starting. It may crank but run a little ways and cut off going down the road.I have had the coil, plugs, plug...
if it shuts off after running for a while and will not restart for about 10 min,a bad crank sensor will cause this. abad crank sensor will make car shut off and not restart for about 10 min. put a scanner on to make sure. a check engine light does not allways come on. if you do not have a scanner, any auto parts store will scan it for free.
Feb 27, 2010 | 1997 Jeep Grand Cherokee
Jeep liberty will shut off and gives a no buss indication light on dash. sometimes restarts and sometimes you have to wait 10 or 15 minute to restart
a bad crank sensor shuts off while going down road. then restarts after 10 minutes, but only until it happens again.
Oct 13, 2009 | 2005 Jeep Liberty
87 Ford Taurus 3L engine shut down when warm - will not restart
after it has shut down check for gas at the fuel rail with the key on their should be gas squirting out constantly it sounds like the fuel pump is going out
Jul 28, 2009 | 1987 Ford Taurus
Flooded starting
I have the same truck, my motor went south blew the head gaskets, but right befor that i was having the same issue. It qwas a bad spark pulg and a O2 Sensor, i just changed the plugs and it was all good after that.
good luck
Jun 18, 2009 | 1993 Isuzu Trooper
Engine Quits
sounds like a tipical crankshaft position sensor will fix your car
Sep 26, 2008 | 1993 Chrysler Concorde
Open Questions:
See all Honda Gx340 Gas Engine 11hp Motor Pressure Washer Questions
Honda Gx340 Gas Engine 11hp Motor Pressure Washer Ect Logo
151 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
