Question about Garden
How to test the coil when removed from device
    Master:
  • 426 Answers
Actually a coil can be tested. All you ave to do is ohm it out by connecting the meter to the two wires coming from the coil. if it is bad, it will either read infinite/open or the ohm value will fluctuate alot and not settle to one low reading.
Posted on May 03, 2015
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 134 Answers
You can't
Is this the coil for my 1971 250 yamaha?? What is the black chip? Will this stop plug from sparking?
without a wiring diagram for you bike we all will just guessing what that is but. it mite be a fuse link. if you are not sure. see if any type of markings, part#######, and go to www.ask.com/ or
www.wiki.org/ or www.infolinks.com/
/what is this device and put the numbers [enter]
it looks like a fuse link, remove any hot wires and test it with ohms meter, if it pegs out or the needle moves, than it okay, if the needle doesnt move than open, or burned out., i would check with the yamaha shop, bap auto part, or foreign auto parts store, or NAPA auto parts store. you see that red round piece is the coil, you have to remove the hot wire and test with ohms meter too.
www.youtube.com/how_to_test_coil/
/how to test fuse link with ohms meter/
/how to test coil under normal use/
/how to adjust points and condenser/
Apr 22, 2015 | Motorcycles
I have a 2001 roadking it has no spark
Remove the plugs and visually check the condition of the plugs and then reinstall them and leaving both plugs installed remove the spark plug cable from one of the spark plugs and THEN attach the HT cable to a SPARK TESTER and clip the tester to the cylinder head bolt and crank the engine over looking for spark and repeat the procedure on the other cylinder also. Be aware that the Engine will not spark with both spark plugs removed, so when checking for spark, use a SPARK TESTER with both plugs installed.
If you have no spark test the coil first. There should be power to the coil primary all the time the run switch and ignition switches are ON. If not check all switches, relays and fuses.
If the CKP is defective you will also get no spark so check it last.
Test the primary coil resistance on your coil. Disconnect all the wires going to the small terminals (primary) on your coil. Using a good ohmmeter on Rx1 setting, test the resistance between the two small terminals. You should read somewhere between 2 and 3 ohms. If you read more, the coil is bad. Before you do this test short out both leads of the ohmmeter and if the reading is not zero you will need to write down or otherwise remember the number and subtract it from the reading you get from the primary circuit test or you will have an incorrect resistance reading for the primary wires because you will also be reading the ohmmeter internal resistance and/or the wire and lead resistance added to the primary wiring resistance.
You can also test the coil by leaving the "hot" wire on the coil and replacing the other side (ground side) with a short piece of wire. Turn the ignition on and temporarily ground the short piece of wire you put on the "out" (ground) side. When you take the wire away from the ground, (which will collapse the primary current into the secondary) you should see a spark at the plugs if it is a wasted spark system or at one of the plugs if it is not a wasted spark system. If you have current to both sides of the primary of a two part coil both plugs should get a spark whether wasted spark system or not as you are energizing both sides of the primary and collapsing both into both secondaries at the same time when you remove the ground wire from the cylinder head ground.
MORE:
Ignition Coil Primary Circuit Test
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is 0.5-0.7 ohms. If primary resistance is not within this range check out test results below.
Ignition Coil Secondary Circuit Test
With the ignition coil removed from the motorcycle and the ohmmeter set to the RX1K scale place the ohmmeter leads on the secondary coil windings B (middle terminal) to
R (rear secondary terminal/socket), B to F (front secondary terminal/socket) and check for secondary coil winding resistance which normal resistance range will be 5.5-7.5K ohms. If secondary resistance is not within this range check out test results below.
Test Results
A low resistance value indicates a short in the coil winding which requires coil replacement.
A high resistance value might indicate that there is some corrosion/oxidation of the coil terminals requiring the coil terminals to be cleaned and the resistance test then repeated and if after the test is repeated the resistance is still high after the terminals were cleaned the coil must be replaced.
If there is an infinite ohms or no continuity) resistance value the coil is open and must be replaced.
Sep 29, 2014 | Harley Davidson Motorcycles
How do I check the ignition coil
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is zero point five and zero point seven ohms. If primary resistance is not within this range check out test results below.
Test Results
Jul 30, 2014 | 2003 Harley Davidson FLHTC Electra Glide...
BIKE RAN GOOD BUT HAD BACK FIRE ONCE IN A WHILE REPLACED COIL RAN GOOD FOR 100 MILES SHUT IT OFF NOW HAVE NO SPARK TO PLUGS
Could be an ignition module. Check the coil first.
Check your pick-up sensor located inside the timing cover, behind the adjustor plate. If the filament is not intact you will have no spark.
A defective coil, cam position sensor, or stator will also cause a no spark condition.
First check for diagnostic trouble codes (DTCs). THEN check the condition of the battery and do a voltage test
and recharge the battery if it is below 12.60V. THEN check the condition and tightness of the battery connections
and perform either a conductance test or a load test and replace the battery if and as necessary. THEN remove the spark plug cable from one of the spark plugs and remove the plug and visually check the condition of the plug. THEN attach the HT cable to a SPARK TESTER and clip the tester to the cylinder head bolt and crank the engine over looking for spark and repeat the procedure on the other cylinder also. Be aware that the Engine will not spark with both spark plugs removed, so when checking for spark, use a SPARK TESTER with both plugs installed.
Test Results
May 13, 2014 | 2001 Harley Davidson XL 1200 S Sportster...
Bike has no spark
Test Results
May 09, 2014 | 2002 Harley Davidson XL Sportster 883
How to check for spark, harley springer
Test Results
May 03, 2014 | 2003 Harley Davidson FLSTS Heritage...
Throttle cable install
What year????
For some models and years, but do not know if it fits yours as I do not know what year you have:
Test Results
May 03, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
I have an 05 softail duece with manual choke, engine will turn over fine but I have no fire at the plugs, installed new plugs, still no fire
Test Results
Apr 28, 2014 | 2005 Harley Davidson FXSTD - FXSTDI...
How do I remove and test coils from boxer engine?
This type of coil is tested with specialized scan equipment.
Mar 22, 2014 | Cars & Trucks
Hi... how can we test the coils for the 1.8, 16 valves, pontiac Vibe 2003? and or which device we need to verify those coils?
you can test the coil the same way you would test a plug, remove a plug from your car , once its out, hook the wire back up to it, and with insulated pliers hold the threaded portion of the plug against a grounded surface on the motor ( usually any bolt head will do ) as you hold it, have a friend turn the car over, check for spark at the tip of the plug, is you see spark, the coil is doing its job. if your car has multiple coils you can repeat this procedure
Jun 27, 2011 | 2003 Pontiac Vibe
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
