Question about Magimix 3100 1057 Cups Food Processor
Does not run properly. Makes a humming noise like it is stuck and runs very very slowly or just sticks
How do I fix my Kitchenaid food processor? Motor hums but center shaft is stuck and won't turn.
Hi Eric, you are going to have to get the motor out and yes it will be because of the spilled liquid fusing/rusting the motor armature shaft into the bronze bush. Those motors are very expensive so worth a go to save it. You will have to get the plastic sleeve off that shaft first before you can get the motor out. Removal will destroy the sleeve. I drill a hole through the top of the sleeve, side to side leaving about 5mm of meat at the top. I shackle a chain through it and attach it to my bench leg and then accelerate the whole motor unit away in a straight line. The shaft needs to be pointing at the attachment point on the bench or it can slip from your hands creating more grief. It will only take 1 to 3 pulls, 1st one doesn't work do it harder, same with second pull and harder for the 3rd. The chain needs to have welded links or the chain will break. That is far the easiest removal method I have found, other methods could involve hacksawing it down one side being careful not to damage the metal shaft or melting a line down 1 side to split it open with a soldering iron. Once that is off then remove base, detach motor wires from pcb and remove the screws under the plastic caps on top of the top housing. Then it will be working away with levers and a spanner on the shaft and CRC, sweat and time. If you strike trouble after that email me
screaming_skull@hotmail.com Cheers Ross
Apr 03, 2015 | KitchenAid KFP600 Ultra Power 11 Cups Food...
Machine won't run
plz get it serviced as it is having hardware problem
Jun 26, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
The Magimix makes a terrible (loud and harsh but short) clicking sound when turned on, either regular or pulse. It sounds ok when running and performs its functions as usual. This is happening ever since I...
you might have damaged the gear-train, Depending on what you payed for this unit it might be best to put up with it for as long as you can and purchase a new one when it brakes down
cost of repairs can easly equal or exeed the cost of a new unit with warenty
Best regards Falco
Nov 04, 2013 | Magimix 18527 5200 Food Processor, Chrome
I bought a peanut butter maker (model #PBM-200) for about $85 and it does not work. After trying several times I even tried grinding up the peanuts in a food processor before putting them in the peanut...
Where did you buy it? Return it, pretty much everything you buy has a certian warranty. Get your money back or replace it with a new one...............
Jan 04, 2011 | Food Processors
When i open the door only the light is supposed to come on. the light comes on but the fan and turntable run also.
This is a very hazardous condition. DO NOT stick you hand inside the unit as you may well get yourself burnd by microwave radiation. It appears that there is either a problem in your control panel assy or that you have time on your timer and the unit has a defective door switch allowing the magnetron to keep running with the door open. There are at least 3 protective micro-switches in the door closed and latched circuit. Very slowly depress your door open button or pull the door open slowly (depending on unit type) and listen for 3 distinct switch clicks. All 3 click should happen in less than one one half inch of the door opening. Try is sevral times and listen for the 3 clicks repeatedly. If you do not hear 3 clciks then you have a bad micro-switch If you hear all 3 clicks, more than likely your controll panel has a failed relay on it.
Jan 06, 2010 | Food Processors
My magic bullet wont spin. It makes the noise but does nothing?
Your black plastic blades, which are on the bottom of the black blade attachment, that interlock with the blades on the base of the machine may be worn down. When the bullet is turned on and these are not interlocked properly they rub on each other causing the interlocking part to wear down so it no longer catches to turn the blades. As far as I know the only solution for this is to get a replacement part.
Dec 13, 2009 | As Seen On TV Magic Bullet Food Processor
Need a manual on an Excalibur dehydrator
excalibur 4526t 5 tray
Makes a very soft hum does not turn on can you help
cheers scott
Oct 20, 2009 | Food Processors
Makes humming sound motor will not spin
Did you replace the start capacitor or start relay first ? This is the most common problem & a hell of alot cheaper than a new motor. Did you replace the motor shaft seal (around the shaft on top of the unit ? if not you will be replacing the motor sooner than you need to because the acids from veggies eat these things up & is the main reason why the motors fail, next in line is overloading or forcing product.
Sep 15, 2008 | Robot Coupe Blixer BX6 Food Processor
My food processor just stopped working?
A Cuisinart food processor doesn't start before the top is assembled properly, that is a safety feature. Their strong motors can withstand also hard to cut ingredients.
Aug 27, 2007 | Cuisinart DFP-14BC Custom Food Processor
Magimix 3100 1057 Cups Food Processor Logo
123 people viewed this question
Top Magimix Food Processors Experts
Ross Keen
richie46
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
