Mike is correct
In the header... Plumbing side
And wire plugs onto heat / control assembly board.
SNS indicates that the Temperature Sensor is out of range! There are two thermistors within that sensor, and if there is a difference of 2 degrees, the board will throw a Fault Code: SNS
check for good connection at board, and ensure the sensor is all the way seated properly in its well.
otherwise, it may be bad.
