Question about Danby DDW1899WP Portable Dishwasher
My portable danby dishasher only runs the prewash and dry cycle, regardless of the setting. Is this a timer issue or something else?
2 Suggested Answers
BElectric
  • 1140 Answers
SOURCE: My salt light stays on
HI,
You can buy dishwasher salt in almost every supermarket. It can usually be found in the section with other household cleaning products such as soaps and washing powders. Make sure you are buying dishwasher salt. Do not use table salt or any other type of salt not designed for use with dishwashers.
You have not been charged for this information ;)
Regards,
BElectric
Posted on Dec 12, 2010
Danby portable Dishwasher advances from pre-rinse to dry and then beeps continuously and dry light continues to blink. Doesn't proceed, reset or stop cycle. Just continues to blink.
I actually found out (one of) the solution to this by accident. It could be the water source is not providing enough pressure
I purchased a Danby DDW1899W-1 and, using the connector screwed into my utility sink in the basement, I connected the water. When I tried to run a cycle, I had the same results (filled/emptied 4-5 times, beeped and went to dry cycle).
My alternate, long term plan was to put a Y-splitter (with shutoffs) on the hot water line for my washer, and have one hose go to the dishwasher when needed. I purchased a washer line hose from Home Depot and a 3/4" to Quick Connect fitting from Ace Hardware and then connected the dishwasher to this.
And, Voila! Problem solved!!!
To confirm this was the solution, after the first completed cycle, I connected back to the faucet and, once again had the fill/empty/beep/dry problem. Reverting to the split washer water feed, it was able to run the cycles properly (again!!!)
So you may just need a line that will supply more water pressure to the dishwasher.
Good luck and, hopefully, this solves the problem.
MP
Oct 18, 2014 | Danby Dishwashers
Danby DCD5505W Electric Dryer: Regardless of the setting at the beginning - Very Dry, Ironing, Mildly Damp, Dry for Storage - as soon as the start button is pressed, it automatically switches to...
The first thing to try is to disconnect the vent hose, and run a drying cycle. If warm air comes out of the exhaust vent, the hose or the vent jack is blocked. If it does'nt warm the air, we need to find out why. Please post back with the result of this test, and we'll go from there.
Aug 12, 2011 | Danby Dryers
Regardless of the setting at the beginning - Very Dry, Ironing, Mildly Damp, Dry for Storage - as soon as the start button is pressed, it automatically switches to "Machine Ironing". How to fix...
Aug 07, 2011 | Danby DCD5505W Electric Dryer
My salt light stays on my dishwasher. Where do I buy the salt suitable for the Danby Portable Dishasher? I DO NOT WANT TO HAVE TO PAY ANYONE FOR ASKING THIS QUESTION, AFTERALL, I HAVE PAID FOR THE...
HI,
Regards,
BElectric
Dec 12, 2010 | Danby Dishwashers
I have a Danby DDW1899WP portable dishwasher. I just got it yesterday. I had a lot of dirty dishes so I did 1 cycle first and it worked perfectly, I was impressed. I then started a 2nd cycle for the rest...
I realize the above question is almost 4 years old, but I am sure others are still having this problem. My Danby was behaving the same way: drying cycle light would flash like it was having a myocardial infarction, and the cycle would stop. I could only get the light to stop flashing by turning the unit off. What you didn\'t say above is what happens then: everything most likely returns to normal-- or at least, so it seems. I have now had this happen to me two times in a row with my Danby 1899WP. Each time the machine has started up just fine, drains water out, loads in fresh water, and begins the wash cycle, only to freeze up with that damn flashing red light on the dry cycle and the dishes not clean. I have owned it for about two months, and so far this is my only complaint. I am running it again right now, for the third time, and we shall see what that light does now.... Will report back afterward!
Nov 14, 2010 | Danby DDW1899WP Portable Dishwasher
Kenmore machine won't do more than fill on SOAK setting;won't run
I'm unsure how the normal operation was restored. I attempted to correct it by setting the machine to SOAK+PREWASH overnight to assure that the SOAK timer had run out. Then My wife (who never uses SOAK or PREWASH options) made a clockwise trip around the TIMER control stopping at each of the "detents" (I did not witness this) one of the spin entry points worked to empty the washwater and the NORMAL wash cycle resumed normal function.
I'm not confident that my description above contains all the essential information needed to correct this problem and am disappointed that
I cannot find SUPPORTING LITERATURE that shows how to use these alternate cycles and combinations without another hang-up like these two that I have experienced. That which is supplied with the washer is pathetically inadequate and the Sears site has little else to offer. Document #8566913 was not delivered with the machine but I did find it somewhare on the INTERNET printed parts of it for additional help. *ALERT* #1: Just now I discovered that it does cover the Model series 110.2692* of which my machine is part ... and it ALONE warns of the 20 minute mandatory wait when two controls are set to obtain SOAK+PREWASH function.
*ALERT* #2: Last nite I discovered that the lid switch makes NO SOUND when the lid is lowered normally but can be made to click by pressing on the left rear of the lid. Feeling under the lid, I found no switchpad (?) on the operating arm as shown in diagrams found elsewhere.
FINAL QUESTIONS: 1) could failure to FULLY operate the lid switch allow partial function of this machine, e.g. to fill, agitate, rinse and spin normally but not to soak or prewash? 2) can anyone direct me to a place where I can obtain breakdown diagrams repair directions for this machine?
Dec 28, 2009 | Kenmore Washing Machines
Danby Dishwasher stuck in drain cycle after wrong soap use
There might be water in the overflow sensor. I unloaded the dishwasher and lifted the front so the dishwasher rested on its back. There's a narrow gray tube that runs down from the bottom right of the door. The tube runs into a white piece of plastic with some wires coming out of it. There is a rubber plug that covers a nipple on the plastic. Pull the rubber plug off. Mine was quite tight. Tip the dishwasher back onto its casters to drain the water from the overflow. Check to see if the dishwasher functions normally, then put the rubber plug back on.
Dec 10, 2009 | Danby DDW1805W Designer Series...
Bosch shu5304uc/u06 does not drain
sounds like the pump has something in it or the drain line is clogged or kinked some how
Jun 07, 2009 | GE Nautilus 24" Built-in Dishwasher
Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 16, 2008 | Danby DDW1805W Designer Series...
My Amana Model NDG5800AWW dryer has ceased to dry clothes dependably. The Only setting that still sort of works is HIGH timed drying, and this heats up to what used to be the "delicate" setting....
if you are using the auto dry setting and the dryer is still running after 5 hours you either have a timer issue or a thermostat problem.
The timer is driven by a motor, if the timer motor is bad the timer wont time out.
in the auto dry cycle the thermostat has to cycle off and on which then sends power to the timer again advancing the timer.
set the timer in a timed dry cycle for say ten minutes, if the timer advances and turns off then you know the timer works. if it doesnt advance you have a timer motor issue,
if the problem is the auto cycle, you could replace the thermostat, about $20 american. however a clock timer would be cheaper.
Based on how old is your machine and do you want to stick a timer in it after already paying the service man is up to you.
A basic bath towel load should be dry in about 50 minutes, this varies on how good your seals are and how long a vent you are running, if the dryer vent was plugged you already have shortened the life of your heating element.
Sep 22, 2008 | Amana Dryers
Danby DDW1899WP Portable Dishwasher Logo
124 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
